New Octavia Pedal.........
the pedal is designed to be floor mounted due to new technology they have in the pedal..
ade
Ade, could you explain a bit :confused:
I thought there couldn't be technology in a pedal. It's a bit of plastic you push. It has a hinge at one end and a stopper measuring depression at the other :confused:
Ade' date=' could you explain a bit :confused:
I thought there couldn't be technology in a pedal. It's a bit of plastic you push. It has a hinge at one end and a stopper measuring depression at the other :confused:[/quote']
its what they use to measure which is the new technology they now use 2 electronic chips which generate a magnetic force aound them and the varible is measured by metal surface controled by the pedal postion the metal distrubes the magnetic field then the chip detects where ecxctly the metal surface is and coverts it to an electronic signal and sends it to the engine ecu.
ade
:jawsmall:
Err, are you serious ?!?
Edited to say I hope wearing metal-plate shoes doesn't interfere with all that magnetic stuff.
The day you wear your stormtrooper outfit to go to a fancy dress party and can't drive the car 'cos the force isn't with you would be a bit of a bummer :rofl:
:jawsmall:
Err' date=' are you serious ?!?
The day you wear your stormtrooper outfit to go to a fancy dress party and can't drive the car 'cos the force isn't with you would be a bit of a bummer :rofl:[/quote']
yes its abit more technical than that but too hard to describe on here.
lol of course nothing will interfear with the super dooper technology :rofl:
ade
This looks like a fork lift truck accelerator pedal :rofl:
I can vouch for the floor hinged pedal being more comfotable that the standard setup.
My Mini had the floor mounted pedal and it was a lot easier on the ankle than the Octavia. I find the pedal setup in the Octavia rather uncomfortable for us 6 footers with long legs!
The one in the pic looks rather hideous BTW!
I had read somewhere that the floor mounted pedals were easier for the drive by wire technology. ( no accelerator cable ). This might explain an earlier post.
But the Furby has D.B.W as well on the conventional pedal type !
Used this pedal type in a Honda Accord Estate TDi I drove last week, can't say I noticed much difference.
what did you think of the accord?
marc
