felicia over revving
help needed
the wifes car would start on saturday but would not tick over
so i cleaned the throttle body . drove the car everything fine sunday morning
car would not tick over , so i changed the crank case sensor because i was given 1 with the car. the car then drove fine this morning the wife tells me the car is over revving
and slowley going back to normal
any ideas folks the car has a 1.3 mpi engine
sean
sounds like you have an air leak somewhere... what did you take off when you cleaned the throttle body??
Did you completely remove the throttle body to clean it? If so i think you'll need to replace the inlet manifold gasket
all i done was jus sprayed the carb cleacer in to the throttle body
sean
this is my though, the engine's carb was tune to the not so nice carb, wen you sprayed the cleaner then the tuning had to be fixed, i would tighnt the idle screw all the way down (engine suppozed to stop at this point) then correct the accelerator screw, until engine stops and give it 1 turn more, then release the idle screw and adjust it until propper idle (i have mine from 850-900rpm)
My advice before taking anything apart would be to disconnect the battery for two minutes to clear the ECU and try again before ripping anything apart.
If this does nothing then i would suspect the Inlet Manifold gasket as previously stated. However, it may be the case that it is just the throttle body gasket that has been disturbed by carb spray. Either way it will not cost more than a few pounds and a couple of hours at the most.
i have disconected the battery and the ecu . the car went fine last night but the wife says its like a kangaroo this morning . i noticed when i left the car idling the revs waiverd
sean
