fan burn out - need help to replace
Smoking and then a small fire in the right hand fan, looking from the front (the fan on the left side looks different - do they have different functions?). Been quoted +£300 for the part, with fitting close to £700 total, so how difficult / easy is it to DIY? Direction to on-line guides / instructions appreciated......
haha, £700 for an engine cooling fan?
get a second hand part and fit it yourself/
few cars breaking in forsale section
I think one's for engine cooling, and the other for air con rad?? Not sure, though.
Both fans are wired in parallel and both blow through the radiator and condenser (if a/c fitted). Rectangular radiator, round fans. This arrangement also has the advantage that if one fan fails, you don't lose all the cooling.
Check the part number - hopefully available on the burnt one. But fans seem available on eBay for around £30. Assuming no wiring damage, could be a relatively easy DIY...
I'd be interested to know what's involved in changing the fan.
Mine is on the blink too.
Easy job, but a bit slow as you need to unhook fogs etc. Remove front bumper and you'll see how it is screwed together. Haynes has a guide and there are quite a few on-line. You don't need to remove the radiator. Be careful handling any burnt electrical bits as the chemicals created can be very nasty.
