Alignment - daft question.
Brian69
Recommended Posts
Are you having an Alignment Check and any adjustment required doing because the tyres being replaced show possible Mis-Alignment.?
Who is doing it, and how much are they charging, and do you trust them to know what they are doing adjusting your alignment.?
Then fill your boots if you do trust them.
Link to comment
Share on other sites
I've got uneven wear (inner) on the current tyres - down to 2mm on inner edges, so need new tyres - was just going to order tyres from Black Circles and get them fitted at a Tesco 'Pit Stop' (basically because they open late Wednesdays and Thursdays) - however, the Pit Stop doesn't do alignment - for the alignment I was just going to take the car to my local National Tyres.
Edited by Brian69
Link to comment
Henry's want 50 quid!
I'd rather go to a specialist but the problem I have for the next few weeks is the only time I'll have free will be evenings and Sundays (which severely limits my options).
Performance Tyres are good (and open Sundays) but they're hit and miss with regard to the attitude of some of the chaps.
Edited by Brian69
  • Like 1
Link to comment
Cheers Geo, but Dundonald is a bit out the way for me (I'm in Glasgow).
I'm at the Pit Stop in Silverburn - wheels (with new boots) are going back on as I type. Good location - can have a wander round the shops while the tyres are getting fitted.
Link to comment
I use these when I swap over from Cold Weather tyres;
http://www.vouchercloud.com/applink/1/q?offerID=193150
Mana the Infiniti dealership at Braehead. Unlike National Tyres, this is proper 4 wheel alignment. (I was only told after NT started working on my car, they can only do the front wheels). They will drop you off at Braehead, or you can do what I do and use the WiFi and absolutely HAMMER the coffee machine. They will, if you are so inclined, wash and clean your vehicle. Both Parks and Henry's quoted nearly £100 and I was told by at least one of them they don't do it onsite. This was before both had a major revamp, so things might have changed.
Link to comment
I just stuck it into Henry's this morning - mainly for convenience (within walking distance of my work), but also they should know how to set the car up properly - now waiting on the obligatory 'upsell' to tell me I need new discs and pads...
  • Like 1
Link to comment
No upsell but they can't get the track rod nut off (roughly speaking - got lost after a certain point...) and this will be an hour's labour (going to use heat).
It's amazing how many garages (not just Henry's) go straight from a water dispersant to a gas torch without trying a proper dismantling lubricant.
  • Like 1
Link to comment
Appreciate it's probably all in my head but the car seems to drive better after Henry's did the alignment (to the original settings - I suppose brand new tyres all round also help).
Re brakes and discs - I've only done 600 miles since the service and the rears have been downgraded from 'immediate attention' to advisory - the fronts weren't mentioned at all.
Edited by Brian69
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
