gumdrop
Everything posted by gumdrop
  1. My lower Grille has a different style to yours with less open area so I have just blanked off the top grille, I used zip ties as I had lost the magnets somewhere. Hardboard painted to match or contrast the car colour makes a good cheap muff.
  2. I had this the other day, I thought it was external frozen rain drops but it was the heaviest condensation I had ever seen Inside! I had put my frost shield over the windscreen and side windows, the car was parked facing uphill on my drive. I had done a couple of short distance family ferrying jobs during the day with all the windows shut, heater on, so I suppose the warmer moist air moved up through the car to my windscreen where it was cold enough to condense but could not freeze because of the frost screen keeping it just at the dew point. Hence the big drops of condensation.
  3. I found taking the cover off mine was a nuisance sometimes, so I tried hooks as were fitted to my Yeti grill cover and currently am fussing about with some "always in place magnets" so I can just pull the cover off and put it in the boot. I did find the grill cover helped when fording, helping to keep the bow-wave rolling nicely. You still need to be Sensible though!
  4. gumdrop replied to paco's topic in Skoda Yeti
    Cover up stuff that may catch overspray and anoint the joints with silicone spray or silicone polish. mine used to creak and squeak in hot, dry weather. Even a little water spray can make a difference as I found out with an old Avenger GT whose steering bushes shrieked if they dried out.
  5. Wading with a normal car; No deeper than the bottom of the hub cap or whatever the alloy wheel equivalent is. (below the sills?) Drive slowly keeping the *small bow wave* rolling in front of you. I rounded a shallow bend onto a straight section of road (a familiar daily journey to work) I was moving at around 30mph and found myself looking at a small lake, too late to brake so I aimed for the crown of the road and changed down a gear to avoid water intake. I aquaplaned across the water on the engine under panel the front wheels acting like rudders until they gripped the road again, safe, dried the brakes out and carried on. Seasons Greetings, Stay Safe. * PS my manager bent the con rods on his diesel engine.
  6. Unless it is obvious, I always clean out the under bonnet gutters, usually a good place to start
  7. I am always asked; Do the same bolts hold the steel spare on?
  8. I am running on the original tyres (they built a tyre factory next door to Skoda ) using the Eco tyre pressures and don't have a problem
  9. Thank you very much, it has been a long time since I drove at night!
  10. I had not noticed before but I started the car in the dark and the only lights on the instrument panel were the sweep needles. I turned the light control to first (on) position and the instruments lit up. Is this normal? I had not driven in the dark since March due to corona virus.
  11. Having had one air-con radiator holed and replaced at great cost I bought black aluminium grill mesh and edging strip. I made top and bottom grill guards which I zip tied discreetly in place on both my Yeti.
  12. PF Jones arranged, mobile towbar fitter arrived today in the rain and fitted a Westphalia towbar with a detachable towball. It needed a bigger hole in the skirt than the normal Fabias. The official plug in electrics were awkward but the fitter (Steve) made it look easy. I had this harness fitted as the car is under warranty.
  13. Have you stopped to wonder, what will take priority when there are more electric cars? Will it be homes and hospitals or cars that get the electricity when there is a "brown out" or even a full blown power cut. People must get to work after all .....
