Everything posted by gumdrop
Skoda Rapid Radiator fan not working
What would you caption the part you have photographed?
What does your temperature gauge read in day to day driving it should be around 90c , is your thermostat working, can the fan be run bypassing the normal connection.
- led lights, what happens when you are stopped at night because one or more have failed??
Substantial increase in fuel consumption
Don't trust gauges, use the fill at the same pump every time to keep the car as level as possible. Record the milage before filling and fill with the same amount or until the pump shuts off. I had a diesel Focus that showed fuel consumption and it showed an average. Same work run different traffic conditions higher consumption!
Inexplicable tyre deflation - no puncture, valve OK
I had a similar episode, took the tyre to a nearby tyre depot they took the tyre off the rim gave it a wipe around and fitted a new valve and inflated it no charge (slack day) no further trouble. There is of course the possibility that some twisted soul let the tyre down out of malevolence.
Droning noise above 50 MPH in cabin
I had a loose windscreen trim on a Yeti it droned, I drove up to Norfolk and it got hit by a stone then it whistled I took it off and had it replaced under warranty.
Fuel gauge staying at full
I had a problem with a sender float once, apparently the tank was all but empty. filling it from empty with the full volume petrol hose had bent the float causing a poor/non-existent signal.
Rubber v carpet vote...update as controversial mat debate rolls on!
With all the rain we get now Rubber mats are really a must as long as you take them out ocassionaly to let the carpets air
000051435AD Phone holder fit in the Yeti?
If you give dimensions, perhaps someone will measure up for you.
- Loading user profile takes 30s+
I've done a stupid thing - rear seat help
Once the panic has set in it makes its own problems, Sit down have a cup of tea then remove the other seats to give yourself room. Another pair of hands might be useful. Is the seat even on the runners and not twisted. Does the latch release completely. Can one person hold the chair square to the rails while someone gives firm blows with their hands on the chair frame just above the runners. I hope this is helpfull.
Electric cars SORN ed, Freedom of information request
https://www.youtube.com/watch?v=tiCGpdhN7Dk EV's being SORN ed and Diesels being restored to run again what is going on?
Glove box light missing
My last 4 cars have had no glove compartment light nor boot lights, so I carry a torch! I even resorted to stick on battery lamps in the boot which were very successful.
- Need help after an accident
I came across this today, a Ratchet Tool Test
Ratchet Tool test; https://www.youtube.com/watch?v=QP2AAEi3U6U
Fabia Mk4 phone mount - is there such a thing?
The mount I have has a rubber protrusion with 4 slots that fit over the vent slats, located near the top of the vent the adapter prevents droop by touching the vent feed pipe
- Unknown issue with AdBlue
Fuel estimation is different than the real consumption
Towing with a Yeti, going I had the wind behind me and it was mainly downhill, coming back I had the wind head on and a lot of hills to climb! That certainly made a difference to fuel consumption.
- Leak in boot - not tailgate rubber seal
Up grade all front bulbs
Do you have children? if they could clean chimneys surely replacing a lightbulb is an improvement in their conditions😀
I use a mount that clips to the dash vent it has been in 3 cars to date.
Wheel hanger alignment pin
Have a look here, https://www.google.com/search?q=Skoda+Wheel+hanger+alignment+pin&oq=Skoda+Wheel+hanger+alignment+pin&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIGCAEQRRg80gEKMTMxMzNqMGoxNagCCLACAfEFi-DH3v8_YW4&sourceid=chrome&ie=UTF-8
Battery drain
I caught a short video, a technician was trying to find a battery drain and had located a specific item i.e. a radio taking current. He was using an infra red scanner when besides the radio there was an even bigger hotspot plugged into the ODB. This item is fitted by some insurance companies to monitor driving skills and can result in lower premiums. But it is constantly looking for data and the power consumption goes up even when the car is not in use. I apologise if I have not quite got this right but I thought it might give a pointer to someone trying to trace a battery drain.
Stop/Start issue / Battery Question
I put my battery on charge around every 3-4 weeks (C-tek) my milage is lower than usual due to operation complications
- Towbar wiring query
