D.FYLAKTOS
  1. 1) Scanner (for error codes) ? What's the status of: 2) spark plugs-air filter-fuel injectors-fuel filter? 3) ignition coil test? Same gasoline station all the time? Have you changed the ECU? Catalyst converter and Lambda sensor is the original?
  2. I remember an older topic for Felicia engine start button which i wanted to install. https://www.briskoda.net/forums/topic/520850-skoda-felicia-with-engine-start-button/#findComment-5836781 The very next month that company (Chinese usually) may close and there is no way to find spare parts plus when a problem show-up and go to the electrician the most common answer is: ''i don't know this, there are no diagrams so i can not do anything about it". So you have to remove it or if you are possessed with that function you buy from another brand, you pay to install it and after few months or years again the same. The tragedy is when the problem show-up in a trip to the country or in National Highway, the solution is a tow truck and back home and your vacations are ruined.
  3. If i hidden Kill Switch has a led to show the On-Off function it's not a ''Kill Switch'' but a ''here i am disconnect me Mr Thief" device. 😄 There are some types of ''Kill Switch'', other cut the fuel other the battery other the ignition etc.
  4. This is what you have: Code Alarm Remote start and keyless entry system with 2-way LCD remote Code Alarm Security and remote start system with 2-way LCD remote It's not factory, this is the genuine:
  5. For sure the fuse-bulbs are OK since you have the blinks. As @R_U_AFA said check your alarm, discontinue it (remove it's own plug) and made a test, if the multiple blink stops the it's the culprit because it was giving the command. ''Retirez temporairement l'alarme de votre voiture (débranchez-la). Si les clignotements cessent, c'est bien elle qui est en cause''.
  6. In their site the Felicia was in their list, that's why i bought it. As you can see in the 3 photos (in the link) shows some Live data with no explanation.
  7. I have it, didn't helped me (one error code i have erased via this and nothing more) https://www.briskoda.net/forums/topic/524233-obd-reader/page/2/#findComment-5876506
  8. + 1 from me plus i would check the altenator. Many years back an aftermarket alarm beeper was causing me almost the same ''drain'' problem, i remove it and my battery was as it should be.
  9. Lambda sensor it's not for morning start only. https://www.briskoda.net/forums/topic/503246-confusion-with-bosch-lambda-sensors/ https://www.briskoda.net/forums/topic/503246-confusion-with-bosch-lambda-sensors/page/2/#findComment-5652665 Back then the car started-accelerated ''as it should be'' but due to that lambda sensor (which was ''OK'' by the parts catalogue) the fuel consumption was 14,7 ltr/100 Km or 19.21 UK Mpg which was far the worst number i had ever seen.
  10. IF it's the stock (NGK) a replace with a new (NGK only) would do only good.
  11. Yes, it's the only way to read them no matter if it's amateurish like OBD 11 or Professional like a VAG-COM scan tool in a repair shop. You also need an emissions check from a repair shop,will help you pass the MoT test.
  12. You can reset the ECU very easy by yourself BUT if there is an error code for a real problem this will show-up again. You have to make an ECU-test to see if there is a specific code that will guide you, changing random parts won't help to solve the problem, it's a ''guess'' job.
  13. Συμβατό με όλα τα βενζινοκίνητα οχήματα από το 2001 και μετά (Ευρωπαϊκή Ένωση) Did worked with Felicia?
  14. Ι saw that spring in a YT video long time ago: Is factory installed or aftermarket? Many times in idle i hear a ''kar-kar-kar'' noise from the engine bay, i press the clutch pedal-release it and the noise stops. I wonder @Papez that spring could help the reset or it's there for another reason?
  15. Pulleys and tensioners can be found but https://www.ebay.co.uk/b/bn_7118881588 https://www.ebay.co.uk/b/bn_1270946 i don't know details about @CptAhab model (cc, year etc). https://webautocats.com/etka/volkswagen/ca/181/109050 I have posted photos-parts etc in a topic, i had the same problem. https://www.briskoda.net/forums/topic/524227-skoda-felicia-gearbox-leak/ A simple pressure test in a repair-shop could show the problematic spot. A hose, the water pump gasket, a connention?
  16. Unfortunately olnly VIKA gaskets are available in a near by VW group parts store, i don't know if worth buy it. I wonder from where that sludge fall upon the bolt ? When i find time i will use a product ro remove that dirt and wipe it as much as i can,then in few weeks i will check to see if there is new.
  17. I found another photo a bit more helpful: I see no leak from the right side of the gasket (as we see the photo).
  18. Also visible below the spark plug. Do i have an oil leak and from where? Is dripping from previous procedure which didn't cleaned properly? A bolt tighten would fix this? Do i need a new gasket? And which one?
  19. Few years back i noticed below the valve cap (here in GR we call it ''pseudo-cap") some dirt, was after the valve adjustment. The mechanic said that he used the same gasket with the add of some gasket glue, i went to his repair-shop, he tighten the screws, clean the area and for some years everything were OK. The above photo is from internet, below is mine as is now. Take a look from the left side as we look the engine bay. Although the gasket show some signs of wear i don't think that oil or fumes dripping from it but take a look in the base, some gunk (dirt) is gathered. Things are worst on the right side.
  20. Those small led lights are ON only for a while, few seconds only. The amber for a set of extra warning light (while parking), the green for the rear camera (ON while the car is in reverse) and the blue for those extra bulbs on the front lights (that \ / shape small beam that i have discribed in the past for very dark one way roads) which are ON only for 2-3 minutes. At daylight all of them are in OFF mode.
  21. Here is how it looks since 2021: In low light and dark:
  22. Those photos are old, about 13-14 years ago. When i decide to change the centra console for 2nd time then the 1st project cancelled. So i bought another used ashtray, i marked-drilled and made round holes for the switches which this time would have round shape and a led light when they were in ON position. Unfortunately due to an USB crash i have lost some of my pictures and among them were those with the procedure so i have to show only the final results. Things didn't went 100% right, i could made the holes 1 mm lower so the ashtray (as a drawer) could go full back and fit perfect but now it's very difficult to do it.
  23. Many years back after damaging both my rear light while try to parking i decise to go for a parking sensors but my car's electrician prevented me. Yes it's in many cars but that ''beep-beeep-beeeep'' is extremely annoying plus you don't have a completely image of what is going on in the back. A rear vier mirror with an 180 degrees camera is a Saviour,i have posted photos from mine, no matter if it's night-rain-for you can park far better than with parking sensors.
