D.FYLAKTOS
Joined
Last visited
Currently
Viewing Topic: Skoda Felicia rear light, I saw something strange
Skoda Felicia hood scoop?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere is another example of why i want a small hood scoop in my car. Every few weeks the sponge filter is full or leafs, small branshes, dog bristles etc that pass easily from thet black grill on the hood.
Kill Switch in a Skoda Felicia
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThat's why i do not believe that cutting a cable from the main switch to the relay won't always stop a thief. Anything that can ''close the circuit" no matter if it's a piece of cable or a paper clip can start your car from the start relay. Go to 3:33 Go to 2:22 Go to 4:08. This is not panacea but works with many cars and i don't want this to happen to mine.
Felicia 1.9 D completely dead after rain
Use a soft brush to clean all the ''female'' part of the contacts, water-leafs-branches-mud can be everywhere. Be patience, don't make moves ''in a hurry", take your time and clean everything. Check for burned fuses or relays that does not work properly, DO NOT try to start the car you may make things must worst. Go to a repair-shop and asked them to clean the area behind the wind shield gasket and then apply a special sealant so in the next rain you won't have the same problem. Plus ask them to clean the drain holes of your car (left-right side) because after so long they will be clogged.
Do not attempt to start the car or open lights etc now ! Take a good picture or draw them and the remove ALL the relays, the plugs and the fuses, let the whole thing dry naturally or help it a bit with a head gun (in lower scale). Use Contact cleaner (No Oil edition) spray everywhere. The water may came in from the wind shield ''gasket'', i had that problem in the rear wind shield.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI saw a video with a guy removing the start relay (which was in the fuse box), then connenting with a cable 2 pins (you have to know which) and ''brooom'' the car started (of course with no key). That's why i don't want to do anything inside the cabin for example with the main switch cables because i know that this is the first place that the thief will start working. How many Ampere must this relay be for the solenoid cable? 100-200-240?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI don't want to ''break'' the fuel pump circuit because i have heard that the thieves first will insist many times cranking the engine and if they don't hear the sound of the pump after the first scale of the ignition key will start searching for a hidden switch. I had the thought that when the car is parked in the street (among others) and after cut-off the ignition the thief can not manage to start the car and since has not the space to push it-engage gear-start it, then he will abandon any try. In the ''how-to'' videos with the remote control system it's easy to ''cut-off'' the negative cable to the pole but if the thief raises the hood then he would easily see the relay.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have tried to cover all the aspects, simple kill switch, with 2 or 3 functions, with remote control. I am sceptical about the Ampere that this (remote control) relay may consumes in ''stand by mode" and i have found these: In theory but practical so if you move your car after few days (according to him) won't drain your battery.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThere is also a Remote Control version of this Kill Switch, here are some examples. I wonder doesn't drain the battery after some days in ON position? How about cutting the power to the Solenoid (and not the batteries negative cable), would be effective too?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanCar Truck Ignition Fuse Hidden Cut Out Kill Switch To be honest i don't want to mess with fuses. Cigarette lighter coil wire kill switch Although it's for old style car it's an amazing patent !
VIN etching or Logo engraving to prevent car theft?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanEven the Department of Transportation can provide some informations to any one. So it's a few minutes work from them to search for any brand-car and unlock it.
We all have heard about it more or less, in the beginning they put that switch to cut the power to the gas pump but latter they extend it. Nowadays via internet the thieves can get many electronic devices, there are sites and even applications in smartphones to help them so is the Kill Switch ''the last line of Defence" ? How to wire a Kill Switch - theft deterrent
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHow To Steal And Dodge And Other Cars With Just A Vin Number! He says he can do it for BMW,Mercedes etc. Some trying to protect their car use VIN Cover Example: https://qualityscooterparts.com/-71671.html Although the Police says otherwise. https://www.ksat.com/news/2015/02/18/will-covering-your-vin-keep-thieves-from-stealing-your-car/ Officer Marcus Trujillo with the San Antonio Police Department explains why you don't want to cover it up. "Another common myth that's been circulating around and now through the popularity of social media it seems to have resurfaced again is that operators of vehicles should, as a precautionary measure, cover their VIN on their dashboard to prevent anyone from copying down their VIN number and going to the dealer to get a copy of the key to that vehicle. However, number one, you can't do that unless you prove ownership and show a picture ID when you go to the dealer. Two, blocking your VIN from display is actually against the law. So you need to have your VIN number displayed."
Remote Central Locking
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman
Felicia with a central lock-unlock switch?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda Forman@Papez you mean switches like these? When i bought my Felicia looked like this https://www.polychronou.gr/wp-content/uploads/2023/09/DSC09128.jpg same crappy gear knob and gaiter-hand brake handle-central console etc. Still have those first windows switches, were in green colour with no good feeling when you pressed them.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanStill can be found in red colour https://www.soundstreet.gr/products/51585.html also in green (i had them) and white (i have them now), the problem is if you try to find one after few years the answer is ''Out of Stock''. Example here but all of them are 6 pin.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFor the electric windows.
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe factory keys from mine don't have button for lock-unlock, only a button which works as a switch for the light (very thin). Never had a key fob from the seller, usually here in GR those days the seller asked you for a free radio-cassette or free alarm system (both were low quality).
- [Question] - Felicia 1.3 MPi Alex HVAC unit
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI also found them in english, now he has no excuses !!!
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanOh, was a copy from Haynes manual. I will print the new ones.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI just returned from the electrician, i gave him all i had but he said that has a problem to find from where the main cables are coming. I told him about the relay which is behind the gauge cluster plus i don't want to remove it. He said he will search about it when he find the time, i am not optimistic.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have printed your image plus the text and tomorrow morning i will give them to my electrician. I already have provided to him the wiring diagram from manual and the switch so the order will be one and simple: "Make it work" !!!
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDo i need an electric diode?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanCorrection: the above is for windows but maybe can do the jod as this one: https://b.scdn.gr/images/sku_main_images/045376/45376003/20230831133208_diakoptis_parathyron_aytokinitou_universal_991801104.jpeg https://d.scdn.gr/images/sku_images/081695/81695401/20230831133209_d2158899.jpeg Looks good as an alternative solution.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanDoes any of @Papez @Thefeliciahacker @R_U_AFA or any other fellow Skodian knows if i need a 4 or 5 pin switch? I have seen even one with 6. IF i need 4 only can the job be done with 2 spring buttons (Off-push ON) ? Here is an example: https://static.rapidonline.com/catalogueimages/product/78/15/s78-1570p01wj.jpg
