D.FYLAKTOS
  1. To be honest never measured this, seeing the brake performance and the clicks of the hand brake to get (much) higher in number i was ready for change. I don't think must be a lower limit to alarm you, all are in the road performance and not in the caliper.
  2. I used a wrong word, i ment it's better for the fuel to be in higher temperature entering the combustion chamber or not? By insulating that tube the inside temperature will be one click lower, that's good for the fuel flow or does not matter at all?
  3. This is a photo of the (injection) fuel rail of Skoda Felicia. https://www.ekodiely.sk/photos/1/1012695/rijroe49tm.jpg Since the years as a student have passed long time ago, i wonder: what is the effect of engine bay's temperature on fuel flow? The gasoline in low or higher temperatures flows or evaporates faster? Here in Greece we don't have heavy winters but we have quite hot summers, what effect does the rising temperature have on the fuel flow? There is a pressure regulator, yes, but if with insulation we lower the temperature a little bit in this cylindrical tube, does this have anything to do with the easy flow of fuel to the injectors? There would be a (even the tiniest) benefit by heat insulating that tube from A to B? or i must leave it as is because that tube must let cool normally?
  4. As ΓΑΠ said: '"there is money" (λεφτα υπαρχουν).
  5. In Czechia an owner was asking for his Felicia with only 14.144 Km on the odometer the amount of 1.000.000 CzK or 41.000 eur back in 2022. https://autogreeknews.gr/nea/polla-diafora/diafora-nea/giati-ayti-i-skoda-felicia-poleitai-41-000-eyro
  6. 2019 Aston Martin Vantage front grille. NO WAY !
  7. Yes but down there what can i do?
  8. Here is what i saw in my smartphone when i connect the OBD 11 in the port. Idle Engine temperature or coolant temperature? Lambda sensor? Value 4 is? What are these indications? Makes my nervous that i paid for this reader and does not say what it measures (plus does not have that fancy applications with digital gauges).
  9. As for the incoming air and the benefits from it: https://www.facebook.com/NASCARonNBC/videos/how-air-moves-around-differently-in-the-next-gen-car/754923579285107/ An everyday driver can not do this simulation-measurements.
  10. Yes but only a car company's RD can do this. An every day driver does this (it's for his filter, not the radiator): bought from here. https://www.aliexpress.com/item/1005006056151522.html 😃
  11. This only in laboratories. An amateur like me can make some simple tests with a powerful fan and an anemometer but even this demands space (a repair garage with no other cars or a backyard not affected by the wind).
  12. II GR a hood car means ''i have a new car and i want to protect the paint" and ''i have a car that it will be left too much time under the sun". No matter what the young thieves soon will make a check, you can understand it when you see the hood to be partially removed a bit. They also make marks as Γ Δ / etc which in the local gang slang means ''checked" ''no interested" etc. If you have parked you car (with hood) in wide road the very next night another car will park beside because the driver believes that you will not remove it soon.
  13. No i will not do anything to that grill, looks nice with the chrome and after i have seen so many fake grilles-vents in other cars (modern one) i decide to leave it as is. The cold air goes low so the lower part of the bumper concerns me, i wonder if i have any gains make it "more through" for the incoming air.
  14. @Papez i wonder if i rermove this and install a ''robust'' mesh like this or like this from ABS there would be any benefits? I mean more incoming air to the radiator that the stock? Of course i don't want to think the senario or a small crash because that spot would be weaker that the stock with those two plastic bars.
  15. Many times i had the thought to modify that front grille, to cut those IIIIII plastics and install a mesh (Like the Milotec style) so more air will come inside. There would be a problem with the round chrome badge area but when i saw this in a Toyota modern car ''i lost my appetite". HUGE front grille with useable only the small upper part of it.
  16. How to change serpentine belt on SKODA Felicia I Pickup (6UF, 6U7) – replacement guide This video shows the replacement procedure of a similar car part on another vehicle Autodoc.co.uk How To: Check & Change Your Vehicle's Serpentine Belt, Tensioner & Idler Pulley
  17. I won't remove the panel, i have done it so many times that damages on it start to occur.
  18. I have done it many times, first by myself (no internet) and then via Haynes manual, the photo above is from my car. For repairs, install insulation, remove the alarm cable, change switches, fix the tachometer cable etc. Sequentially there are some squeaking noises and tolerance plus a broken O style screw base (that behind the TC-6 but i made a patent) so i put some windshield glue and everything are tight and quiet. It can be removed if something has to be repaired but otherwise i want to leave it as is because now i have almost not crackle noise. Behind the driver's door panel?
  19. Thank you so much for the infos but i can't do this, i can remove the panel by my self but its too much work these days. Is there an alternative way? Can my electrician remove the driver's panel and work there with the electromagnetic mechanism?
  20. Oh, so i must remove the instrument panel? is this one pointed by the white arrow?
  21. @nta16 here is a today's (mine) sample for the extra charges from UK to GR. Buying from ebay.co.uk that latest years it's a economic disaster.
