looking for advice understanding felicia front wishbones.
1.3 MPI was in the Felicia 1.4 MpI was in the Fabia, have you made an engine swap?
Temperature gauge - fuel level gauge - clock not working
Check also the fuse box, sometimes dust-corrosion-not proper contact create problems. Contact cleaner (the No Oil edition), light brush is a solition.
First what you can see from outside (engine bay, fuel pump connections etc) and IF everything fail you have to remove the dashboard. Check each gauge individually, i will try when i get home some electrical diagrams.
Bonsoir Monsieur, comment allez-vous ? Marseille (France) ,for sure we the GR know your city. https://as1.ftcdn.net/v2/jpg/04/77/95/86/1000_F_477958646_ZtEBjrkH8YP5U8RZnKOXHhZPkojcInK2.jpg You have to check all the plugs first (good contactivity, possible corrosion etc), then for wires (twisted, cutted a bit etc). Changing the gauges is the last option.
''Glitters'' inside my coolant expansion tank
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHm...before the heat core of after the expansion tank?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI found something similar: In-Line Coolant Filter Radiator Hose Filter Kit for 1 1/2" hose If you are installing on a dual heater application you will need to install two filters one before each heater core. The coolant filter needs to be installed into the inlet hose of your heater core and is easy to install.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe first filter has a wire mesh too?
Felicia with Heat Shield in the Intake Manifold
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIf you say so, this way.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI forgot to check my father-brother car when i was on vacation to check if there are any black spots on their expansion tanks. 100% stock cars, nothing aftermarket and normal use no Sport style.
Engine cover, do we really need it?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThe climax was going from top to buttom, was a snapshot. Was an (general rule) example of how the hot incoming air affects the performance.
Online catalog with PART NUMBERS and ILLUSTRATIONS
Hello, Dimitrios! We are pleased to announce a significant update to our catalog of original parts for VAG vehicles (Audi, Porsche, Seat, Skoda, VW). The updated catalog now includes parts for all the latest models up to the 2025 model year. You now have the opportunity to find the necessary components for the most modern VAG vehicles. The new catalog offers: A complete range of original parts for VAG brands: Audi, Porsche, Seat, Skoda, VW. Convenient search by model and year of manufacture. Up-to-date parts information. High-quality illustrations of components and parts. We strive to provide you with the best service and only genuine products. Visit our website to explore the updated catalog and find the parts you need. If you have any questions or suggestions about the website's operation, please contact our managers and technical support specialists through a special request form on the site. Best regards, 7Zap
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanSince we talk about covers, air intakes etc i have found this. For every 10 'F colder air some engines can take 1 HP. As for the cutted cover take a look how it was and how is now. In the past i couldn't work-maintenance-check things beneath it as i can do now. By the way i saw a spot from the exhaust manifold that has been ''uncovered'', i will fix it soon.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere some photos from the side. For sure it's not ''perfect'' but tall the previous expansion tanks were in terrible condition.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI took some photos this afternoon, i shed some light with a led pocket lighter and i saw that still there is some sort of muck stuck in the bottom of the expansion tank. It's not on the walls, is in the bottom where there is a hole which send via hose coolant in the radiator, the cap is very clean, no detritus at all. I didn't had a long screwdriver or similar tool to scratch that muck to see if it's ''removable". I have to admit that i am a bit disappointed, i thought that the whole content of the expansion tank would be almost clear.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have take a measurement from radiator hoses (external touch with the digital thermometer's metal nose). Looked very normal, i will post photos tomorrow.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIn that test the 80 'C were in the cavity between the fuel injectors, it's few cm below the Heat Shield covered area (on the top of that area are the 60 'C measurement).
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere are some measurements that i took few days ago, keep in mind that i am not interested for an ''ultimate test'' nor for ''exactly numbers", i am just trying to see the effectiveness of the Heat Shield so 1-2 'C more or less it's not significant for me. With Heat Shield left-right side and without. The difference is about 20 'C which leaves me satisfied and i think this would be reflected in the Fuel Consumption in long term use. ____________________________ Here is in the front of the air manifold Heat Shield which has a bigger gap, it's not so tight as in the two braces.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAnother very interesting video about High-Low (and Wake) pressure surfaces in car's body from Julian Edgar. https://www.youtube.com/watch?v=F1ZWBlHhR9s I don't regret even for a second for cutting that part of plastic, helped me to install easier the Heat Shield, lubricated easier the cable, cleaning the throttle quicker etc. Unfortunately i didn't had the chance yet to locate the exactly point (behind the bumper) that brings fresh air inside the air filter box but i think the extra hose in the grill mesh did it's job. The summer Fuel Consumption tests are over, photos and comments in a new topic.
Three G11 coolant mixtures, boiling-cooling time comparison.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanThese? Mixture - water/coolant concentrate! Observe concentration ratios according to repair manual and climatic conditions. • The frost resistance of the coolant must be guaranteed down to -25°C, • in countries with arctic climate conditions -35°C
Felicia Gearbox oil level?
The gap is on the description of the spark plug, nevertheless you have to check them one by one with the special tool. https://www.championautoparts.com/Technical/Tech-Tips/choosing-the-right-spark-plug-gap-tool.html https://www.championautoparts.com/Technical/Tech-Tips/Spark-Plug-Gap-Tip.html
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanGear oil change, gear rubber bushing change and coolant flush in the same day at the repair shop.
Questions About Favorit / Felicia 1.3 Oil Cooler
With 20W-50 in 300msec and with 20W-60 in 100msec. Tested, approved and with certification in a frame for the wall in the house.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI don't have HEPU G12 with me now.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI will post some photos There when i return, let's hope that i wouldn't find any signs of muck.
