Paint colour please
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere: https://www.briskoda.net/forums/forum/406-skoda-classic-cars-parts-for-sale/
Questions About Favorit / Felicia 1.3 Oil Cooler
https://www.merlinmotorsport.co.uk/knowledge_base_articles/view/laminova-oil-water-heat-exchangers-319 Like this?
Paint colour please
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanFelicia Pick-up White/Dove Mixing code 1021, Skoda code T7T7 , Aerosol No HFA381058.
Paint colour please
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIt's not in the service manual, it's written in the car's paper that you bought it, says the VIN the paint code and the description of the vehicle. Is on the Registration that you show in the traffic Police stop, an example: https://d23vfvjlkuzpf0.cloudfront.net/wp-content/uploads/sites/3/2023/03/adeia-kykloforias-paradeigma.webp
Paint colour please
D.FYLAKTOS replied to sparticus-84's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIn GR is written in the car registry paper, for example in mine says: Silver 431 (not sure for but is a 3 digit number) so any painter in reoair shop can find the proper colour from his supplier. ______________ Where is the color code on a Skoda Felicia? The paint code for all Å KODA models can be found in the boot of the vehicle. _______________ Where is my Skoda paint code? Paint Code Location Check under the boot lid, inside the rear compartment, under the mat, or on the spare tyre wheel well. A Skoda Colour Code is typically 2,3 or 4 numbers long, but can also be a letter/number combination. If you can't find the sticker on the car some dealers will put it inside the service log book.
Old specifications, doesn't mean that we must follow them forever. When Felicia created no one knew the G12, the 98 octane gasoline, the aramid-fibre brake pads etc, dosen't mean we can not use them now.
Very interesting article about the Oil Cooler. https://club.autodoc.co.uk/magazin/oil-coolers-how-they-keep-your-car-cool Oil cooler: leaks, failure symptoms, problems and how it works
Was, is and it would be as long the Felicia exists. With Synthetic oil and 80-85 thermoswitch it would be OK, 75-80 is too low and the radiator will work overtimes.
See? That's the cause Next time use a Synthetic 10W-40 (tested and approved) and everything will turn back to normal (which means Good).
Skoda Favorit clutch cable
D.FYLAKTOS replied to garyheath69's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanAutodoc.uk will have the proper codes. https://www.autodoc.co.uk/car-parts/clutch-cable-10177/skoda/favorit In GR those codes maybe different. https://kritosparts.gr/SKODA-FAVORIT-(781)-05-89-09-94-1.3-135-(781)-781.135-(58hp)-12-91-09-94/Ntiza-symplekti/m106_a398_t3034_r478_v2
Engine Mounts - 1.6 Felicia (2000)
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYou mean these? https://www.autodoc.co.uk/vika/13156318 https://www.autodoc.co.uk/vika/13155733 I have asked in the past for my 1.3 and they told my it's the same trouble.
No problem at all to mention it, what you see as "war" it's an every day forum conversation in GR. I have the same thermostat but in 80-85 'C.
I don't know if @R_Blue drives under so heavy load that needs an oil cooler (isn't turbocharged). Nevertheless that oil cooler needs careful placment, maintenance because if something goes wrong the results could be catastrophic, worst that an overheating that may face now. One click lower thermoswich won't help? An extra radiator?
Locked out of Felicia - Help!
Same method is used ever from Police in USA to open doors from seized or absndoned cars.
Differs than ours in the North Greece for example? Like your birthplace.
Disable Felicia immobiliser?
A serious locksmith or someone with speciality in cars can programme you a second key. Example: https://www.jdpower.com/cars/shopping-guides/how-to-program-a-car-key-chip The cost for that programmed second key in a shop is about 20 euro.
Thermostat Housing - 1.6
D.FYLAKTOS replied to TrentBarton's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanUnfortunately that is the sad true for many parts, only after market are available and sometimes only VIKA. So many owners if they want Original the buy used parts.
Felicia with Heat Shield in the Intake Manifold
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI will use a combination or IR gun and IR camera photos. Both can not go so wrong.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanApplication installed for IR photo, in few days i will give that app a try.
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanNo OBD II in Felicia, the OBD 11 fits in us but i don't have it with me now. I am traveling, in the stop (Cafe parking lot) for coffee i can touch the shield with bear hands, the air intake absolutely not. I will take measurements in the next days.
Fuel pump problems
- Felicia with Heat Shield in the Intake Manifold
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI have family obligations, unfortunately no money for such luxuries.- Locked out of Felicia - Help!
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanHere are the results from the today's test. I use this digital thermometer (not a IR pistol) and as you can understand i had to wait some minutes to take each measure. For sure i was not looking for the ''perfect'' result, it's not a F1 laboratory here but i wanted to see the difference between the Shielded and the No Shielded air intake. Now the Shielded area. As you can the there is a significant difference and i think this is good for the performance. 💪 More photos from a test when i return from my vacations trip, the engine will run hotter,the temperatures would be higher and i will use a Laser Thermometer like this. Till next time...''Stay Shielded". 😃- Engine cover, do we really need it?
D.FYLAKTOS replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanToday was the day for the final test of FC with the modified air filter box in hot summer City conditions. The next would be after i finish my vacations trip in the country so no City traffic conditions. From 92023 the indication reached the 92133 ,actually from 94,9 Km reached the 205,4 Km in the odometer which means 110,5 Km distance mainly in City traffic and some kilometres in Mountain road till 3rd gear only, so no 4th gear or no red line rpm zone. The ''drawback" of the not good acceleration with 3rd gear in 2000 rpm in uphill was present of course, after the modification is "taken for granted" and i can not do anything about it but let's see the results of the FC. For those 1110,5 Km the gas pump shown 8,670 ltr which means the Total FC was 7,84 ltr/ 100 Km or 36.03 British MPG. 🤩 The modification WORKS and all these tests approve it, after the vacations trip (Highway, Mountain roads) there are some tests to do in the winter (City traffic) and i have covered all the seasons and all situations. - Felicia with Heat Shield in the Intake Manifold
