Felicia Combi 1.3 - what oil?
Many years back the repairs shops here promoted the Valvoline for Skoda. Later some of them start ''pushing'' Aral for engine oils-coolant ''because it's from Germany" (trying to tie VW Germany,Skoda-German product). I have tested 2 Motul and Amsoil Synthetic oils. Unfortunately no Morris Multivis in Greek e-stores. Skoda / VW Group Engine Oils
I tried a synthetic oil 10W-40 and i saw that I didn't have good results in turning at high revs, i was nervous because i was forcing the car, i was burning more fuel, i had a bit of higher coolant temperature. Why? I don't know. Amsoil was not available in that country-town so i decided to do a temporary test on 5W-40 and so far i have only seen positive results. So where's the weird thing of saying my impressions in a Skoda forum where other members can post their opinions? Where is the problem anyway; I didn't tell you to remove the injection system and go back to the carburetor. Bee Gees: Stayin' Alive.
Some thoughts (translated) from a Cz Skoda Felicia forum. https://forum.skodahome.cz/topic/54506-motorový-olej/#comments
https://www.duckhams.com/uk/find-my-oil/?country=GBR&typeid=a8187c2b31540d9bae842be3b07a74cc For Felicia 1.3 latest model suggests only one type of oil, the 5W-40 Duckhams QS 5W-40 MRV and oil change every 15.000Km / 12 months https://www.duckhams.com/uk/duckhams-qs-5w-40-mrv/ I think they do it in purpose to make @Thefeliciahacker nervous. 15W-40 or 15W-50 Synthetic or Semi-Synthetic?
Haynes (for Felicia) was promoting Duckhams oils.
Then B is for 1.3 According to the green colour chart (W.Manual) 10W-30 and 10W-40 have the same characteristics, you believe it?
Next time i will give a try to Synthetics as ENEOS Premium 10W40 or Shell Helix HX7 10W-40 ENEOS Super Plus 15W-40 and i don't know if Mobil 1 FS X1 5W-50 is good for my engine.
https://www.caranddriver.com/news/a34762175/synthetic-oil-classic-cars/ As i have seen now, should i close my eyes or say a lie? I have lower motor noise, less fuel consumption, the car rev-up better, should i ignore all these and say what? I have tested Motul Synthetic and Castrol-Valvoline Semi-Synthetic, they didn't work for me, i don't want them any more in my car !
An Amsoil 10W-40 Synthetic can do this? I can not do an oil change now, i can't pay 70 euros at the moment, i will in the future but till then i drive my car normally in a city.
👍 In the chart that @Thefeliciahacker posted: Petrol engines A - Light Multi type oils specification VW 500 00 B - Multi type oils specification VW 501 01 specification VW 502 00 specification ACEA A2 or A3-96 The viscosity class of the oil must be selected based on the diagram. If the temperature exceeds the indicated values for a short period of time, there is no need to change the oil. Important Notes: Because engine oils are constantly being improved, the information contained herecorresponds only to the situation valid at the time of publicationof this book.
Skoda recommended Semi-Synthetic and not Mineral. Also in manual said for coolant to use G11 for Felicia, in an older topic i remember that the other guy suggest to another Felicia driver to use G12. That wasn't a "split hair" case? Amsoil has a 5W-40 European formula oil but unfortunately not 10W-40. Have you or a friend of yours ever use in an old classic car a Synthetic oil?
Yes, they are available here. https://oilsmotoauto.gr/el/98_millers https://www.skroutz.gr/c/1228/Ladia-Autokinhtou/m/22964/Millers-Oils.html This one. https://www.skroutz.gr/s/8217133/Amsoil-Synthetiko-Ladi-Aytokinitou-Premium-Protection-Synthetic-Motor-Oil-10W-40-1lt.html Very expensine now, you need about 72 € at least for an oil change.
Was an example. You can have both the factory switch and the oil pressure gauge together, all you need is an adaptor with new thread https://m.media-amazon.com/images/I/51uSmRtICaL._SL1000_.jpg and some Cooper washers. May look a bit ugly inside the engine bay but if you are a driver that likes to monitor things it's good.
The 1.3 engine has it also. https://kritosparts.gr/Code/028 919 081 D https://kritosparts.gr/Part/BALBIDA-LADIOU-047919081-PSYLI-BOLTA-115094201/eG18115094201
@Breezy_Pete Here it is in a Favorit, it's in the right side of the block in the lower section of the picture.
I know only for one, looks like this the part code is 028 919 081 D, has one cable and a plastic cover for protection.
You mean the red indicator in the dashboard? Yes i have it. No warnings so far, the engine oil level is OK. IF (i say if) i had an Oil Pressure gauge with scale from 0 to 100 what would be a ''normal'' indication and what a ''warning'' one?
Once upon a time i had an Oil Pressure gauge but after some years cause me a huge problem and i remove it. It's red light was going on-off and i was in a summer vacations, i thought i had problem with my engine oil level but it was fine so i throw that gauge away.
That applies to any brand Synthetic or Semi-Synthetic? 5W-50 has Mobil-1 about 50€ the 4Ltr.
That kind of ''danger'' with the 5W is bigger in Winter or Summer? Yes few seconds more or less was never an issue but the weird thing is that now with the 5W the car runs better the few hundred meters after Cold Start, has one click better fuel consumption and don't forget that is revving-up far better in Sport style driving. All i am trying to understand is that the 5W will cause so much friction inside the engine parts?
I saw it, 3:50 minutes from the 1100 rpm to 750 rpm which is the standard. With 10W-40 mine has 3:40-45 minutes, so what's the improvement with 15W-50? With 5W-40 till now it's about 3:40 alhtough i haven't test it yet in Winter because the temperatures here are still like Summer.
Wheel arch liner fitment / manufacturing
Since mine looks identical to yours why you want to make that cover? Aerodynamic (Ground effect) ? As is now you can work in the for light area (changing bulb etc).
