pab567
FREEDOMTech
Everything posted by pab567
  1. @SirDaff I am not aware of any bug with 'autodimm 10 seconds' feature, could you pls elaborate a bit more?
  2. Nope, this is the latest available SW for your unit.
  3. @Anderon-l you have not followed manual... @mladjan check your PM
  4. Exact model number and current SW version?
  5. @adrianu possible, requires soldering @emilio_Poland Octavia possible, Fabia not possible unless you exchange glove box unit All check your PMs
  6. I am not sure if Blues can handle speakers in rear doors but for sure you have no cables to have them installed.
  7. Use SD card, not pendrive, and start update from Service menu (long press MENU button)
  8. @DanielMoise you already have the latest available SW version @sto PM
  9. @foxtrotoscar19 you must start the update from Service menu (long press MENU button) @amr1 PM
  10. Thanks for sending VIN over PM. Your unit is Bolero MIB2 with DAB/DAB+ receiver and RVC support, model number 5Q0035842B: The problem you described is typically caused by EMMC failure but it can also be flash or iMX6 processor problem. Flash and EMMC error can be fixed by replacing flash or EMMC chip respectively (in case of EMMC it als requires patching the unit). If the problem is caused by iMX6 then unfortunately you can just throw it away. I can try to repair it if you deliver it to me (Poland).
  11. Splash screen is just a question of coding. Pls post VIN on PM so I can see what is the unit and let you know available options.
  12. I don't think so... download link on PM Is the SD card original? hae you unpacked files directly to the root of SD?
