pab567
FREEDOMTech
Everything posted by pab567
  1. This is one of very few problems that these units have which is extremely hard for troubleshooting and repair. Very often it ends with unit replacement :(
  2. One again - 5E0919605N will NOT work with your current glove box unit. If you cannot PM use [email protected]
  3. NO!!!! 5E0919605B is MIB1 display unit and it will NEVER work with any MIB2 glove box unit which 5Q0035842C is. If you want to use SmartLink you must replace both glove box unit, e.g. to 5Q0035842C, and display unit, e.g. to 5E0919605N. Glove box unit must be hacked. Is it cleared now?
  4. Old screen - old unit. Both MIB1, No SmartLink. New screen - new unit, e.g. the one you listed (5Q0035842C). Both MIB2. SmartLink possible only if unit is hacked.
  5. .What @PetrolDave wrote is not entirely truth. The way described will not allow you to use any features that are not supported currently, e.g. SmartLink. To have new features enabled you must have MIB2 unit hacked. If you are intrested in getting such unit, in P&P version, pls contact me on PM.
  6. Come on, 605B is MIB1 display with resolution of 400x240 pixels, you cannot have it replaced with MIB2 display that has resolution of 800x480 without replacing glove box unit.
  7. Visit your Skoda dealer to have it activated.
  8. Downgrade MIGHT be possible (although I have neer done it) if you turn on developer mode (in adaptations) and then use Testmode / manual SWDL.
  9. @Stevejd58 use SD card. ALWAYS.
  10. @jay01600 looks like your unit is electrically broken now... As any SW update can go wrong this is one of the reasons why I do NOT recommend to make any SW update as long as unit works without any major issues.
  11. @Stevejd58 are you doing it from pendrive (USB) or SD card?
  12. You should start it from Service Menu - long press MENU button.
  13. To test pls connect phone directly to USB, not via any external module
  14. Over Wifi? 5Q0035840B does not support WiFi, I think you messed up something...
  15. What is your phone? Have you tried another cable?
  16. And make sure metainfo2.txt file and all folders are directly in the root of SD, not inside any folder!
  17. I believe the correct device part number is 5Q0035874C... aLL CHECK pm
  18. MIB2 amplifier will be locked with Component Protection as soon as you have it connected. With your reuqirements you can install any (listed from cheapest to the most expensive) Amundsen MIB2/MIB2.5, Columbus MIB2, Columbus MIB2.5. Amudnsen and Columbus MIB2 work with 6.5 or 8" displays, Columbus MIB2.5 requires 9.2" display.
  19. As far as I know - not. Unfortunately I don't have it :(
  20. What maps - OEM or via SmartLink?
  21. Let me know your VIN and I will decode it.
