pab567
FREEDOMTech
Everything posted by pab567
  1. 5Q0035842C is Bolero and Boleros do not support OEM navigation. Full stop.
  2. Nope, this is the latest version for your units.
  3. It is available only for cars equipped with additional sound system DSP amplifier. It seems your car is not fitted with it.,
  4. Links on PM. You can use VW map update use Bettle then Discover Media
  5. Download link sent via PM. Update procedure has been described multiple times, pls use search.
  6. 1. reflash your unit with the same firmware, using Manual SWDL (select all to be updated) 2. try another phone 3. if problem still exists then it's probably faulty BT module inside the unit
  7. All check your PMs
  8. Nope, this is the latest version All others check you PMs
  9. Nope, this is tle latest SW I know :(
  10. 0367 Download link sent via PM
  11. There is no newer SW update available (although there were manufactured units with SW up to 0363). You can have SmartLink activated by your Skoda dealer or the unit must be hacked. Yes, I beleive from end of 2019 there are 32GB original navi SD cards available, e.g. 5L0051236BJ
  12. Nope, this is the latest firmware
  13. Bull****, no additional module is required, just the activation. Unfortunately you already have the latest software.
  14. Yes, you can use SmartLink if it is activated (if not you must have it activated). For SW update link check your PM.
  15. Unfortunately this is not possible :(
  16. Such sound issue is typical for HARMAN MIB1 and MIB2 units. In most of the cases it's enough just to resolder both power amplifier chips, if it doesn't help then have them replaced. Depending on the option cost is 100-150 EUR...
  17. Check your PMs
  18. @Golanl1978 I beleive the process should be explained in your car user manual. If you don;t find it then rather check with your local Skoda dealer as I am not into MIB3 infotainment systems at all.
  19. I recommend to find in your area someone who has ODIS or VCP (Vag Can Pro). You can also visit your local Skoda delaer and ask to programm your unit using ODIS.
  20. Everybody has to answer by himself / herself. Features are the same, just HMI (UI) is more "modern"
