Colin170CR
Everything posted by Colin170CR
  1. After my annual mileage dropped from 30k to around 6-8k I decided to switch from a S2 Superb 170 Diesel to a 66 reg 280. Double the power & no wheelspin in any weather conditions, which was quite common in the old 2WD 170 diesel on damp roads. The extra power of the 280 is very useful when needed, even more so now I've had a REVO stage 1 remap done. The only downside vs the old diesel is the increased fuel consumption which hovers around of 25/26mpg around town & up to 36mpg on a run also, 99RON fuel is needed for best results. That said with far fewer miles being covered I can live with higher the fuel consumption & now I've experienced the capabilities of 4WD I don't think I would go back to 2WD unless it was a much lower powered model.
  2. Snap. Really good & lasts quite a while.
  3. Sounds like a sticky / squeaking electric damper / flap in the vent system. Or the damper / flap is scraping the duct - perhaps when it operates going from outside air to recirculated air. Spraying said WD40 or something similar into the ventilation intake might do the trick but is a bit hit & miss. If you can narrow the noise down to a more specific location then applying WD40 or similar might be more effective especially if you can get a long straw to get to the working parts. I suspect a bit of digging & investigation will be needed to expose the offending item.
  4. I gave up after 2 sets of replacement Skoda emblem wheel centres which all corroded within 18 months & went with all black plastic ones, nothing to corrode & they match the car colour.
  5. Think I'll do a pre-emptive strike. I have just ordered
  6. OK. Mine is at 47k & 16 reg so just about in the same window. TBH I haven't noticed any hiccups - yet, but you never know.
  7. Good work. I think this is an issue many of us will face at some point if we keep our cars long enough. What age / mileage is your 280 when it started playing up?
  8. After a message came up on my dash a new battery went into my key fob yesterday. This is the 2nd battery that has gone into this particular remote during my ownership. The spare has not had one yet as it's never been used. For safety both keys live in a RFI proof tin in the house when not being used. I have also recently fitted a K&N engine air filter & replaced the pollen filter.
  9. Very snazzy Alan. Difficult to do?
  10. At least you get to eat the culprit.
  11. I guess Carfile don't have the overheads of a You Tube channel, TV advertising, & an excitable presenter waving a "stick of truth" & throwing suitcases & rear parcel shelves into hedges..
  12. I don't do finance deals to buy cars but I see no reason why this shouldn't work more than once. Alternatively, if you have the cash just play hard ball with a dealer & ask for the same terms or better, or use a broker. A quick check on Carwow indicates the average savings below on new Superb's & I wouldn't mind betting you might even get more discount on a 280.
  13. Try turning AC off. If noise disappears then it could be the compressor clutch / belt tension. Noise seems to be coming from left front side of the engine & if it's speed related then look at the belts & pulleys. Engine mileage? Is it manual or auto?
  14. Looks like my front wing L&K badges are trying to come off by themselves! The lower curly bit has come loose on one side so I'm now considering removing them as they keep getting caught on cloths when washing the car. As for your rear end (so to speak), I think I favour some badging but not too much, to keep people guessing.
  15. It could be a bunch of reasons but it sounds very similar to the "Saw toothing" problem I & many others had on S2 Superbs which resulted in an on/off resonance at 60-70mph caused by cheaper tyre makes &/or wheel geometry problems. Check the tyre wear, tyre pressure (front & back) & have the front & rear wheel tracking / camber checked. Out of whack tracking / camber can result in tyre rumbling which is more audible on certain types of road types e.g. concrete sections of motorway. A 4 wheel alignment & tyre change finally sorted my 2010 S2. Not sure if this problem has been carried over to current S3 models but it is entirely possible for a similar problem to exist - especially if cheaper tyres are fitted. My current S3 rear wheel camber was out of whack which resulted in dramatic inside rear tyre wear down to the canvas & a slow puncture while the outside tyre tread depth was still at 3-4mm so don't take anything for granted. A 4-wheel alignment has hopefully cured the problem. It could also be a rumbling wheel bearing - mileage? Jack the car up & spin each wheel & see if you can detect any noises or grumbling. However, wheel bearing noise is normally a more continuous rumbling & not an on / off resonance.
  16. I can see why it took 1.5 days!
  17. Nice. What products have you used?
  18. Try using some rubber gloves for extra grip on the fitting & pull straight back. I had similar problems when I did mine. In the end it's a case of controlled brute force but the gloves give you better purchase on the fitting. My wife's marigolds did the job for me.
  19. Yep.. However, being Black, mine warms up quicker than a gas stove even on mildly sunny days. Thank god for the AC. Just ordered a new pollen & K&N engine air filter for mine. It also badly needs a wash after the Sahara sand that we got last week.
  20. Have them on my 2016 L&K. Previous owner probably spec'd them as an option. Never used them as I sit in the front & rear passengers are few & far between.
  21. If related to pressing the clutch pedal then it could be the clutch thrust bearing. If related to the accelerator pedal then then perhaps a squeaky alternator, water pump or lose belt. Video of noise would be helpful.
  22. I got a text message from him on the 24th March to say goodbye & confirming he had been banned for life. He didn't say why & I didn't ask.
