ords
Everything posted by ords
  1. Still won't play for me. Can others play it?
  2. OP says it's not water as it's not evaporating.
  3. I'll bet he's used Google translate.
  4. Which it what it says in the manual
  5. No. I never have to enter the country
  6. Does the OP have Amundsen or Columbus? I don't know if the Columbus also has 2 SD slots.
  7. If you do get the card out and it's damaged, you have to replace it with an original Skoda SD card . An ordinary SD card will not work.
  8. This is my version and the DAB option
  9. Mine has the DAB option and it had it before I updated the software. Bluetooth speaker quality is also ok.
  10. Can you explain that in more detail? I'm confused by what you mean.
  11. Modularer Infotainment Baukasten or Modular Infotainment System
  12. See if the expansion tank has the wording "mat silikat" on it. If it has then your car is fitted with it
  13. Are you in eco mode? If not try it. It's far less sensitive to gear changes.
  14. That puts all the security systems in place.
  15. Looking at my V5C, it's 102g/km and 77kW, also DSG. Seems the higher output engine is cleaner.
  16. I pay £20.00. Am I being cheated?☹️
  17. You can visually check the belt and it may appear ok, but you can't do the same for the tensioner as far as I know. That can fail. If Skoda in your country recommend changes at the figures you quoted then you've got nothing to worry about.
  18. Skoda UK recommend the cambelt is changed every 5 years along with the water pump.
