Everything posted by chrisgreen
CarPlay Display in Fabia II
Evening all Many of you will have seen adverts all over social media of late promoting these 10-inch widescreen CarPlay/Android Auto display screens that are being marketed as a low-cost and neat way of adding modern connectivity to an older car, or to a car where it's difficult (or where you simply don't want to) replace the factory-fitted head unit. Well, I bought one. After shopping around, I actually found one on Amazon that in the end only ended up costing me £50, and it even doubles as a dash cam. Backstory: The Fabia II Combi I now have (which I inherited from my mum when she passed away earlier this year) originally came with a Swing radio. I retrofitted an Admumdsen+ to it (having already done the same retrofit on the Rapid Spaceback I owned at the time) not long after mum bought it, as this not only added nav, but also Bluetooth (I also retrofitted the genuine mic into the roof courtesy light cluster). Mostly because it's my mum's car and I don't want to do anything that might dmagae it or that can't be reversed later, I was reluctant to buy an aftermarket Android headunit. I was tempted by the RCD330, but trying to find a reasonably priced real one (there's a lot of crap clones out there) was proving to be too much ard work. So I decided to go down a different route. The CarPlay display comes with a choice of stick-on or windscreen mounts. I used the stick on mount, which very securely stuck to the top of the dash directly above the centre air vents (I cleaned the surface with an IPA wipe first and allowed to air dry). It's powered via a USB-C port, and a USB-C to 12v power cable is supplied. It does draw up to 3amps, so doesn't seem to play well with using a USB-C cable and a 12v accessory socket USB adapter (as these tend to only output up to 2.4amps per port). I've wired in a hidden 12v accessory socket behind the dashboard, piggybacking off the rear wiper fuse, with the power cable running straight out the back of the display and down the back of the dash below the windscreen. I've secured the hidden 12v socket and the excess cable in the void space at the end of the dashboard on the drivers side, next to the fuse box. The amount of visible cable is minimal (just over a foot coming from the back of the display and heading straiught to the gap between the end of the dash and the windscreen before disappearing from view). I also did one loop around the stand, to act as a stress support so that any pulling on the cable while I was pushing it down the back fo the dash (it's beyond the windscreen vents so not blocking or interfering with those) wouldn't tug on the display. Connection to the phone is very simple. After doing the initial connection via Bluetooth, the screen then sets up the CarPlay connection using Wi-Fi. Audio options are to either use the built in speakers on the CarPlay display (I wouldn't), connect the CarPlay display to the 3.5mm input socket on the Amundsen using the supplied 3.5mm to 3.5mm cable (too messy, can't hide the cable) or - and this is the option I went for - allow your phone to connect to the car's own bluetooth as normal, and connect to the CarPlay screen for display only. This works really well. While you still get full CarPlay control on the new display (including calls control), all the sound, as well as track data and caller data, goes to the Amundsen. You can see in the pic above that I've got Waze running on the CarPlay display, but the audio (and track info) from Apple Music are going via the Amundsen (but controllable from both the CarPlay screen as well as the Amundsen screen. And as mentioned earlier, on the back of the display is a 4k Dashcam (whether it really is 4K remains to be proven, but the camera output is clear and sharp, and copes well with low light. The height and angle of the camera can be adjusted independently of the angle of the screen. It also came supplied with a 64GB MicroSD card. A 1080P wired rear/reversing camera is also included. I decided not to fit this, but have kept it in case I change my mind in the future. Anyway - all in all - I highly recommend these screens if you want to add modern CarPlay/Android Auto capabilities to your Fabia, but don't want to do a full head unit replacement. The one I purchased (https://www.amazon.co.uk/dp/B0DHSDG63B) has now gone back up to £90 (£130 with a £40 discount voucher on the page. Worth keeping an eye on it (or shopping around on Amazon, eBay, AliExpress etc. for alternative models) in case it comes down again, as things often do on Amazon.
1.2 HTP New Battery Time - Recommendations?
Battery update - finally got round to fitting the Bosch S5 005 on Saturday morning. Immediate difference, car no longer strugglingt to fire up on inignition. Gave it a few good motorway runs over the weekend to get some charge into it as well. Used Liqui Moly battery terminal grease (and gave the positive and negative terminals a clean up at the same time).
Small world, My dad worked for Lex for a while back in the 80s, before he moved on to become a fleet buyer for Budget Rent a Car. You probably stayed at the Barn Hotel in Ruislip. It closed down earlier this year. Currently hosuing asylum seekers ahead of being redeveloped into flats.
Advice needed on new headlight bulbs - 1.2 HTP
Fitted the Nightbreaker 220s on Saturday - has made a significant difference over what I believe were the factory Philips bulbs that I removed. Was driving on some very dark roads in Surrey on Saturday night, and had much better visibility.
I've already gone ahead and ordered the Nightbreaker 220s - they are coming at some point today, so we'll see how they perform. If they are not up to the job I'll definitely give he Philips ones a try.
Hi - alignment is fine and the car sailed through its MOT last month. The outer lenses are also - surprisingly - in tip top condition, no cloudiness or haze, no condensation inside. As for the opaque lens over the projector lamp fitting, it doesn't appear to have degraded, but no idea how or if it could be removed to do any work on it without separating the entire headlight (won't be doing that any time soon). Plenty of spare standard bulbs to hand and I keep a Lidl set in the boot, so emergency need is covered. TBH I have lost track of how old the bulbs are in the headlights currently, so it could be that they have simply degraded over time. But given the stock headlight bulbs in my Rapid were just as bad, I suspect it's more down to whatever bulbs are in there being rubbish and/or being impacted by this headlight design. Won't be doing any mods like fitting additional lights - the car was my mum's up until she died, so won't be messing with any significant modifications. The only things I've done to to it have been fitting a stick-on phone holder (so completely non-destructive and reversible) and one of those 10inch widescreen Carplay additional screens - got one very cheap during the Black Friday sale (again, stick on mount so non-destructive and reversible) and it not only looks very good and tidy in the car (barely any visible cable (about a foot, after which I've made it disappear behind the dash, running to a hidden 12v socket by the fuse box), it adds some much needed modern tech without having to swap out the factory Amundsen nav (which I actually retrofitted in place of the Swing radio when mum first bought the car). It also interoperates well with the Amundsen, as the phone connects to the carplay screen via wifi, and still connects to the Amundsen via bluetooth for audio and calls output.
Thanks
I don't know - there's three bulbs in the headlight. I know the one in the projetor bit on the outside edge is a H7 fitment, and the tiny one is a W5W. No idea of the size or spec of the remaining bulb alas, hence the question.
I've gone ahead and taken a punt on a pair of Nightbreaker 220 H7s to go in the so-called projector part of the headlamps. Arriving tomorrow (Wednesday). Hopefully they will make some difference. The other two bulbs in there, I know the tiny one is a W5W, but the one next to it, is that another H7 or a H4?
2012
Yeah, I don't think it's worth the cost or effort to try and do a HID conversion on a 12-year-old entry-level Fabia II. Similarly, not worth the risk of rendering the headlights illegal. Would be just my luck that I would get nicked for them. Am I likely to see any meaningful improvement if I swap these out for a set of, say, the latest Nightbreakers?
Was looking at the Nightbreakers. Seems the latest conventional ones are the Nightbreaker 220, which the Osram site suggests are not compatible with the car (which seems odd - available in the usual H4 and H7 varieties). Osram's bulb checker is saying the Nightbreaker 200 is as high as I can go. Doesn't sound right, wondering if the bulb checker just hasn't been updated. Anyone know?
Grabbed a pic of my headlights for reference. Couldn’t get any of the bulbs out as it’s freezing out there and I was struggling a bit with my hands trying to I clip them.
Hi all Was out in the Fabia this evening (it’s a low spec 1.2HTP - no front fogs, don’t think there’s anything fancy with the headlights it has), driving down quite a few unlit country roads. TBH, prior to inheriting the car, I had mostly only ever driven it in the daytime or, if driving at night, in areas that actually had street lighting. So, the fact the bulbs in the headlights are about as useful as two tealights, I need to do something about it. Need to fit something much brighter. I had the same issue 10 years ago when I bought the Spaceback. But also mindful that bulb tech has hopefully improved in that time, not to mention the possibility of LED bulbs. So, my questions are: 1) recommendations pleas for the brightest conventional halogen bulbs to fit to the car. 2) does anyone have experience of replacing the conventional bulbs (I think they are H7s in these, need to pull one and check) with LED equivalents? Are there any that are any good, do they fit, how did you deal with the extra cable and/or transformer box that some seem to have? Not an issue I have with the Superb, which has factory LED headlights that are like someone has captured a pair of neutron stars in a pair of headlights. But I really need to improve the headlight performance on the Fabia. Genuinely concerned driving it this evening in the dark. Thanks Chris
So, ended up ordering a Bosch S5 005, which is arriving on Wednesday. Got a good price on Amazon for it - just over £70. One last question - what’s the best grease to use on the terminals?
It’s the first time I have put a Varta battery in a car and I won’t be using one again. I know it’s not a regularly driven car; but I agree the lifespan of the Varta has been very poor. It replaced the factory battery and that was 8+ years old by the time it was done. My Rapid Spadeback was 9 years old when I traded it in, still had the factory battery in it and it was fine.
Evening all The battery on my Fabia II Combi is on its way out. Not surprising sadly. It's currently using an 027 Varta, fitted in 2020 during the pandemic, and the car has only done an average of 3,000 a year since. Was warned in June when I had it serviced that it was on its way out, and in the cold it's really struggling to crank. Any recommendations on what to replace it with please (in terms of brand, CCA etc.) given the car gets only occasional use and low annual mileage (my daily driver is my Superb). Car is stored on the drive, so it is open to the elements and the cold. Thanks Chris
Making a few improvements to my Superb III
Which ones in particular, there’s a lot I’ve referenced in this thread and they’ve come from a few different outlets.
Tire recommendations
As some above have said, if you are in need of new boots, go with all-wather tyres. I would recommend either Goodyear Vector 4seasons, or Michelin CrossClimate - have had both fitted on my cars recently and both have performed well.
Is this the ultimate tyre for Superbs in the UK climate?
Completely agree - Dunlop SportMaxx tyres are horrendously noisy - I had them as the factory boots on my Rapid and the sound was beyond belief. When I eventually switched to the Goodyears, the road noise drop off was incredible. Same more recently when I had a set of Goodyear EffecientGrips put on my Fabia II Combi. A significant reduction in road noise.
SOLD - Skoda Rapid Spaceback genuine boot nets - mint condition
Price now reduced to £20
Compass Currently Unavailable
You don’t have built in sat nav? I didn’t think any of the Superb IIIs were sold in such a low spec? What head unit does your car have? Also, what instrument cluster do you have - is it MFD or Virtual Cockpit?
Is a Skoda Superb SE L Executive longer than other models?
No, you were just sent mats for a different car. Probably a Golf or possibly an Octy. Most likely a Golf. All based on the same MQB platform so the mats are the same, just different lengths in the back.
"Front Assist Unavailable"
That's the thing, had it been heavy rain I wouldn't have given it a second thought, as I would expect something like the front radar to be impacted (exactly the same way a Sky dish drops out in heavy rain), but on this occasion it was quite light rain, not enough I would have thought to disrupt the radar, which is why it stuck in my mind to keep watching it. First time it's happened since I bought the car at the end of May (and not the first time I've been out in rain). Fingers crossed it was just a rain-related one-off. Car has been bulletproof otherwise. Good to know you experience this in adverse weather. Makes it less likely there's an actual issue.
Experienced this on Monday - was heading down the M40 from High Wycombe towards London on my way back from Marlow. Doing 70 with cruise control on and had the Front Assist Unavailable warning pop up. Was in place for a couple of minutes then cleared itself and started working again. There was very light rain at the time. will be keeping an eye on it to see if there's a recurrence, if there is it'll be going in to the dealer.
