Everything posted by gm73
Creaking on full lock
My car is making a creaking noise too when turning at low speeds - a three point turn for example. Also the power steering is very crunchy at the end of travel and makes a rubbing noise into the bargain. I suspect the steering rack but a split CV boot cover would be a good bit better.
Fuel pump replaced under warranty. New one is buzzing now
Wondering if anyone else has a fuel pump that buzzes loudly on idle? Had mine replaced under warranty last week as the dealer agreed it was faulty. Now the new pump is doing the same thing. I’m beginning to wonder if this is down to E10 fuel. Anyone else experiencing this - it’s a 2020 1.5 TSi.
Help with fault code P023B?
Hi. I had the electric coolant pump replaced but it turned out it was a broken wire as the code came back. So I would check the wiring before buying a new pump. I’m not sure what the part number was but he got a good deal on an original part from TPS.
Oil temperature and DPF
A motorway run is no use. You need to give it an absolute thrashing down a B road dropping gears at high revs to get the correct temperature - what’s called an Italian tune up. My DPF light came on at 120k, I stuck in some DPF cleaner and super diesel thrashed it down country roads for an hour and it cured the problem. Car is now on 220k (with a different owner) and there’s been no DPF issues since. I had the same car as you - a 2015 Octavia 1.6 TDI CR.
Loud knocking from rear underside of car..
I have numerous noises coming from the front suspension on a 35k 2020 car. Mechanic can’t find anything wrong so I had a shock absorber changed to see what happens and it was still noisy over rough ground. As a taxi driver it is driving me mental and I don’t have unlimited funds to change out every part of the suspension.
Is this normal from the 1.5 TSI electric steering rack?
After only 35k miles? - creaking/clicking when manoeuvring at low speeds - ie a three point turn - a rubbing noise from the steering, again a low speed turning/manoeuvring, at certain points in the turn. - a horrible (intermittent) crunching noise when the steering approaches/reaches the end of travel (full lock) (I know it’s not advisable to put on full lock but often there’s no choice). And if there is an issue with the rack/pump will it be covered under the Skoda warranty??
Suspension knock 2015 VrS
I have a similar issue. Went down a pothole and have a noise when going over rough ground. The only thing the mechanic could find was a slightly weeping shock absorber which he changed but the noise still persists. He can’t find anything wrong at all. I asked him to change the strut top mount as there is a creaking from the steering but he didn’t as he said there was nothing wrong with the top mount. I wish he had just changed it as it’s only £25 and at least would have eliminated that possibly. There’s nothing more frustrating than a noise that can’t be diagnosed especially when the car is a taxi and I’m driving it for 10 hours a day.
Fuel Filler Flap sticking
I simply bought the new solenoid from Skoda (£25) and swapped it out in a couple of minutes.
Tyre wear and wheel spin
Sorry Pirellis of course. It has Michelins on the back which I mixed up with the Pirellis. Yip. What an eejit I am.
My 1.5 TSI wheelspins like mad. I put it down to the tyres - Michelin Cinturato P7s - as you hardly get loads of power in first gear (I've got to rev the guts out of it to get it away quickly and then all the power is delivered in 3rd gear when I don't actually need it). Might contact the dealer.
what do you like and dislike about your Octavia?
I like the styling on my 2020 SE Technology, the boot space, the interior is slightly bland but effective. Apple car play is good as are the little extras on the SE such as heated mirrors and centre arm rest. It handles quite well and is smooth on the motorway. I don't like the juddery clutch, the noisy and intrusive 1.5 TSI petrol engine, the crappy acceleration from zero on a 150bhp car, the creaking top mounts, the notchy and uneven steering, the poor paint finish, the cheap, horrible carpets, the horrible drive at low speeds, the unstable nature of it when it's windy and so on.
Front top mounts.
My 2020 (31k miles) 1.5 TSI is making this noise. It’s especially noticeable when making a three point turn. Mines is in at the dealer just now as the fuel pump is noisy so I might chance my arm and see if they’ll replace the top mounts as well.
Battery life for 2019 Octavia VRS
Yes. The mechanic coded it for me.
Octavia MK3 Estate VRS stiff steering
I'd like to add to this thread and state my 2020 1.5 TSI Octavia is doing this now. Steering is fine at low speeds but anything above 40mph it's notchy and sticky.
Thought I’d share my experience. The original stop/start battery on my previous 15 plate Octavia lasted just over 100k miles. A replacement cost £140 supplied and fitted.
Loud engine buzz cabin
Mystery solved. Took it into a different dealership and the fuel pump has been diagnosed. Changed under warranty next week.
I’ll check this out thanks, I’ve got my own mechanic looking at it later this week. Skoda can’t even send a technician out to the car park to listen to the noise for two weeks.
My 1.5 TSI has an annoyingly loud engine “buzz” in the cabin at idle. It sounds like a loud heater fan but the tone changes up and down. It isn’t always present and the start/stop masks it. You can’t hear the noise outside the vehicle or with the bonnet open and strangely enough it feels like it’s coming from the rear of the vehicle but I can’t be precise. Anyone have the same issue?
2020 1.5 TSi - some gripes/worries
I don’t use full lock, I can only compare it to my previous Octavia and the power steering was quiet on that. It’s possible the clutch is slipping, but after 9k miles? I think the engine is just really unrefined. I can’t believe Audi owners put up with it for the extra you pay for one. All In all I’m just really disappointed in this car after 15 years of buying Skodas. The paint finish is poor in places as well and the car is really jerky when it’s cold.
I've had my '20 1.5 TSI since May when it replaced a '15 1.6 CR TDI. I acquired it with 9k miles, it's now on 29k. I've had several Octavias, dating back to a '05 plate 1.9 PD which did 410k without being annoying. I'm not sure I'm enjoying the ownership experience of this car however. So if other owners can confirm the below is normal, I'd be grateful... - acceleration out of 1st gear isn't quick, how they get the 0-60 time is beyond me, it only starts to motor in 3rd gear but by then you don't need the power. For a car with 150bhp (more power than an RS Turbo) it's pretty slow. I own a 27 year old Ford Escort that has a more consistent drive. - It's noisy above 70mph, I think thge 139mph top speed is optimistic. - Power steering is really loud when nearing full lock, much louder than any car I've ever owned. - the engine note is always changing - there's sometimes a loud buzzing in the cab at idle and it can sometimes be as loud as a diesel on tickover but sometimes you can't even hear it. - clutch sometimes judders in quick first gear pull aways. - It's really lumpy on cold mornings. - I've got brand new Pirelli Cinturato P7s on it, yet it can wheelspin in the dry. - you can't use OEM brake pads on it as they clunk, you need VAG original parts. - oil is super expensive - front suspension is creaking at low speed manoeuvres. - fuel consumption is atrocious, the ACT is pointless. - Front assist is very erratic and the auto wipers choose when to work. Apart from that I like the interior and the spec, not sure I can live with it for another 3 years. Kinda wishing I'd just bought a Mondeo now.
One loud "CLUNK" noise on acceleration
I had a clunk (amongst other noises) on my previous Octavia (15 plate 1.6 tdi). Started about 100k and was still there when I sold it at 200k. Was pretty annoying and like you couldn't find any play anywhere. Put it down to the brake pads clunking as they weren't original equipment.
Start off revs
Would this explain the slight judder I get from the clutch occasionally when I pull away quickly under load? It was happening at 9k miles and now the car is on 27k and it’s not got any worse but it’s not great either.
Is my DPF regen too often?
I sold my 15 plate 1.6 TDi CR with 200k miles on it and it it constantly regenerated so I wouldn’t worry about it. The new owner has covered another 10k and it’s still going strong with no DPF issues.
Air Filter change interval
Just like me then. I recently changed my 2015 Octavia 1.6 TDi for a petrol 1.5 TSi only due to LEZ regulations. The car had just under 200k miles when I sold it. Oil, filter, air and fuel filter changed every 9k miles. Original engine, turbo, clutch, dpf, no issues with EGR or injectors, original glow plugs. Only things changed was one drop link, two front shock absorbers and an exhaust sensor. Oh, and heater blower motor.
Servicing
I did my own services on my old 2015 1.6 CR TDi. I must have changed the fuel filter about 10 times and I never topped up with diesel and the car is still going strong on nearly 200k miles.
