Everything posted by djmartzian
Retrofit rear tailgate LEDs?
@milloo24 , Can you please share the 7204 dataset that you have witten to your car? Is this a RHD dedicated? I would like to do a diff with mine: XXXSBBR8VQXX Really appreciate your support! Cheers
Thx for the info @milloo24 To clarify, my car has rear top LED from factory. I just need to find an inner lamp assembly 5E6 945 308C(RHD) at good price to complete "both fog lamps" tiny retrofit.
Correct! Feeding all these information to an AI agent, he conducted that for a LHD car I'll need a top LED assembly from a RHD car in order to have both fog lamps working, since the actual led and power supply are missing, same principle apply for an RHD car. In your case you have made a mix of TOP led assembly units from both LHD and RHD cars, what I'm now looking for. Thanks @milloo24
OK. So to enable both fog lamps only a coding/adaptation OR dataset change is required. I'm trying to figure them out. For sure there is a small difference between LHD and RHD cars, and merging them will results in both fog lamps on. Can you share a BCM backup of your current state? Thank you
Hello @milloo24 , Congratulations on your work with the retrofit! I have couple question regarding the actual behavior with both rear fog lamps steady on: Can you share a backup of adaptation on BCM unit? Is your car RHD? I'm working on finding out how to enable both on my car, which is a LHD vehicle. Based on the investigation I did so far it seems that this is a wiring harness tweak. Can you confirm you have connected both: T6y/5 and T6x/5 (NSL signal) to BCM: T73a/72? Thank you
Volume keeps turning up??
Hello @LivornoBart , That's really amazing. Thank you for sharing with us. Can you also provide more details about the sensitive touch PCB being replaced(Part no, web link where we can buy it)? All the best
Potential Root Cause(AI generated based on the information and investigation): Finding that the left corner of the Flexible Printed Circuit (FPC) had delaminated (un-glued) from the plastic front lens perfectly explains the random behavior. In capacitive touch systems, the sensor relies on a uniform dielectric layer between the copper traces and your finger. When that FPC lifts, it introduces a variable air gap. Because air has a completely different dielectric property than plastic or adhesive, any change in cabin temperature, vehicle vibration, or humidity causes the capacitance to swing wildly, triggering those annoying "ghost touches." To secure your repair and prevent the FPC from lifting again under the intense heat of a summer dashboard, you need an automotive-grade solution. The Professional Solution: Kapton (Polyimide) TapeThe best technical solution to overlay and seal the back of that FPC is Kapton Tape (Genuine Polyimide tape). Excellent Temperature Resistance: It easily handles continuous temperatures up to 260°C (and short terms higher). Dashboard components can easily exceed 70°C–80°C in direct sunlight; standard tape will melt, slide, and leave a sticky residue. Low Static / High Dielectric Strength: It is an exceptional electrical insulator and does not build up or retain static charges that could interfere with the capacitive sensing traces underneath. Ultra-Thin Profile: Looking at your layout, the green main PCB with the LEDs sits incredibly close to the black trim piece when clipped back together. Kapton tape is incredibly thin (usually around 0.05mm), meaning it won't add bulk or create mechanical pressure points against the LEDs or components on the green board. How to apply it:Cut a piece of Kapton tape wide enough to cover the lifted corner and extend slightly onto the solid plastic frame. Use a plastic spudger or your thumb to press it down firmly from the center outward to ensure zero air bubbles are trapped between the FPC and the plastic housing. Seal the outer edges of the FPC completely to prevent future moisture or cleaning sprays from creeping under the circuit. What to AvoidStandard Office/Packing Tape (Cellophane/BOPP): Do not use this. It degrades quickly under heat, the adhesive dries out rapidly, and the act of unrolling/applying it generates massive static electricity (ESD) which can glitch or permanently damage the sensitive touch controller inputs. Thick Foam Tapes: Avoid thick double-sided foam tapes on the back face. They can compress unevenly and push back against the green PCB, potentially flexing the main board or cracking solder joints over time.
Travel assist retrofit
Hello guys, Can we summarise what is the best config for Point_of_intervention flag? TIA
Skoda Octavia infotainment update
Guys, The above unit (if the picture provided by @shadyk2 is indeed from his car) is the SWING MEN3 "low infotainment" system. Bolero + Built-in Navigation = Columbus = MIB3 Hight infotainment system. The file that I shared above is for MEN3 unit. As far as I know the upgrade procedure is the same for both system types. If the unit doesn't recognise the USB stick please follow the steps to debug: Recommendation is to use high quality brands(e.g Sandisk, Kignston ...) Type-C is better to eliminate bad adapters extFAT format Large capacity because the files for MIB3 are ~10G If the unit fail to load the files, try with another USB stick. Hopefully this quick guide will help you. Good luck
Hello, Short answer, Yes. For more details please read related thread: https://www.drive2.ru/l/692089794200617469/ Keep in mind, do it at your own risk! Cheers
@shadyk2 , https://disk.yandex.ru/d/CdhzYkPKTOskBw Good luck
- ORU3 - OCU - SW0311 – Octavia (O3A8)
Last evening, OTA 03A8 has been sucesfully installed on my car, too. Despite, you need to login with your Skoda account, insert S-PIN, save your favorites radios station again, everything went back to normal operation. I've also quickly checked with OBD11 dongle and the Telematics module has been uptated to v0311.
Octavia MK4 MY2023 OTA update went wrong (03A8)
@Giannis20 , I'm so sorry to hear that fuse trick didn't work for you. Then you have a real hardware issue with the display unit, maybe try to clean it! Good luck
Hello @Giannis20 , This OTA update is for OCU unit. Please see below related thread for more information: https://www.briskoda.net/forums/topic/537961-oru3-ocu-sw0311-octavia-o3a8/ Have you check the version was correctly installed(no weird DTCs are present) using an OBD11, VNCI or VCDS ? You can try a hard reset of both Telematics + MIB3 control units, by removing Fuses 19 & 30, leave it for couple of minutes then re-connect. Good Luck Cheers
Another update!
Hello everyone, It seems that a rolling OTA update is on-going for SOS module which accordingly to the below information started a few days ago. Has anybody received it? Any kind of information will be highly appreciated. You can easily look up by typing your vehicle VIN number on: https://www.dieteren.be/en/recall Cheers.- MIB3 randomly going in the hidden menu
Hello @Stanciu09 , This is know hardware issue on early-on touchscreen units! It has been solved with HDD v49! For more details see related thread: https://www.briskoda.net/forums/topic/516103-volume-keeps-turning-up/page/4/#comments RO: Success in rezolvarea problemei! EN: Good luck! Cheers- Edit Sound settings - dataset export (OBDeleven, Car Scanner Pro?)
Guys, ^^ settings are for MIB2 unit. Bear in mind this thread is for MIB3, so it can create confusion. 🙂- Airbag error (B200000)
Hello @scotthugh3s , As 2-d DTC stated, your Airbag CU is hardware faulty, caused by the electrical drop failure (probably). From top of my head I remember I saw this kind of error on another forum. Maybe @East_Yorkshire_Retrofits , jump here and based on their expertise will provide next step to proceed with investigation and resolution. Cheers- Edit Sound settings - dataset export (OBDeleven, Car Scanner Pro?)
Hello @wellaflex , No I haven't. I restored to stock data-set before my VcTool Pro Subscription expired. Cheers- Coding of Steering Wheel controls
Hello, I've managed to create a new(hopefully correct) date-set that activates "Sport" FPA profile with "Voice" button (short press). Source: https://www.drive2.ru/l/722508608016755839/ Cheers DA_0019_7208_38K_MZ0N_010FPA000003_MQB37WKONV_voice_button_1push_sport.xml- Edit Sound settings - dataset export (OBDeleven, Car Scanner Pro?)
Interesting article with 72xx audio data-sets attached 🥳 https://www.drive2.ru/l/625312054999264406/ MIB3 72xx data-sets: https://disk.yandex.com/d/u9D-RNvpFuMsXA- Coding of Steering Wheel controls
Hello @Cairus , I've created a dataset based on the instructions from above article. Based on my logic, when "Voice" button is short pressed it should switch to "Sport" FPA profile without the UI interactions on MIB3. Based on your expertise, is this correct? Thank you DA_0019_7208_38K_MZ0N_010FPA000003_MQB37WKONV_1push_voice_button.xml
