Everything posted by Kenny R
Skoda tyre pressure monitor
Just goes to show you don’t need a fancy complicated all singing and dancing, bells and whistles, expensive system to be effective.
Air Con - Never Getting Cold Issue
Well, it’s not a sealed unit and automotive ac systems are well documented as to leaking up to 10% of gas per year, through compressor seals, and flexible hoses etc.
Aircon gas needs topped up?
Service changes needed at 80k miles
At the least, it will require a brake fluid change, cam belt and water pump, pollen filter, air filter, fuel filter. And if it’s DSG, DSG oil change.
No, it should be reset immediately after checking/ resetting tyre pressures before driving.
Caravan Tow / Tow Bar
I think when you show the Mrs how wee a caravan your car will tow, I think the notion might subside somewhat
Skoda Connect renewal costs.
There’s a link to one on eBay in my post above.
If you don’t use Connect much, buy a connect lite dongle from eBay, you can get VW branded ones for under £5. You can the use the Skoda Connect Lite app which may have enough functionality for you. https://www.ebay.co.uk/itm/264747012721
Wires in Boot Area
- had my battery checked?
The micro hybrid 2 section is relevant in this link… https://www.yuasa.co.uk/info/technical/micro-hybrid-hybrid-vehicles-explained/- Yeti spare wheel coversion
The thing is to get a true resting voltage from the battery, you either need to disconnect the battery and check a good few hours after charging. Or you need to connect your meter to the battery ( and place somewhere it can be read with bonnet shut) , close the bonnet, lock the doors, and leave for a few hours. If you are checking the battery after unlocking the car opening doors etc, the fuel pump will have primed, interior lights come on and the car systems woken up, so you will not get an accurate reading.- had my battery checked?
The ac being on is only one item in a list of prerequisites for stop/start to operate.- had my battery checked?
If the ac was on it wouldn’t.- had my battery checked?
Stop/ start system batteries are normally only charged to approximately 80% by the system to allow for some capacity from the regenerative braking.- Front Assist
That is manoeuvre braking, that works of the parking sensors, nothing to do with front assist.- Coolant drop to minimum after 4000km
Quite common for small air bubbles, introduced in the factory fill process, to disperse causing the level to drop. Unless level keeps dropping nothing to worry about.- Front Assist
The front assist only applies the brakes at the last minute to avoid a collision. Believe me if it does deploy you will certainly know about it, imagine an emergency stop x10.- Yeti Door Loom
- Parking Brake Superb Sports Line
Surely if it’s a manual you need to depress the clutch to start, on DSG it’s the brake you depress, you don’t need to do both. The autohold applies the brakes same as you pressing the brake pedal and is not an automatic handbrake.- Columbus Map Update 2021-2022 (MIB1/2 HIGH)
- Coasting
Does it not re- engage drive when you touch the brakes and provide engine braking as in previous versions.- The 'free' 20" wheel upgrade.
If you’ve got an order in already, don’t pin your hopes on a free 20” wheel upgrade. My son has been informed today his order due end of July has build confirmed and is too late to change order for free upgrade and will definitely come with the standard 19” wheels.- Have the 4x4's been dropped?
Strange message to get as 2.0 tsi are back to 280 ps and the 2.0 diesel is 200 ps and have been for a while. - had my battery checked?
