Everything posted by Gissin
Mk2 FL CR170 coil spring
can't see any part numbers but my fronts have the letters HFH and a yellow and blue paint square about 3/4 of the way up and the rears have pink,white and red circles on them. agree with the above that they take time to settle.
what engine is It CEGA? if so I've got a OEM set of springs sat in the garage I could check for you
Wind Deflectors
notch goes on the back of the deflector ( so facing out ) fwiw I don't have the metal clips in and they've never moved
Bang from window- regulator, glass?
sounds about right - glad you got it sorted
removing the door card is fairly easy no seals that I remember however to get to the regulator you'll need to drill out the rivets in the inner door panel then once repaired replace the rivets. had this go on mine recently local vag specialist sorted it for (complete replacement ) for around 200 i think, the cheapest I could find full OEM replacement part was 160 if you take the card off there's 2 plastic black plugs inline with the wires so you can check if ones bust.
Tyre burst even though 4mm tread remained
ok so should have been picked up at a MOT at some point too then in that time ..so could be something that's happened fairly quickly. Yes I'd get it tracked asap as depending on the issues the new tyres you've just put on could be in the same state in a few months. w and y jus relate to the speed ratings W(168mph) and Y(186mph). ideally you should have the Y's on the front ( higher speed rated on the drive wheels) but it shouldn't cause any issues. you've not hit any big potholes or anything recently have you ?
how quickly have you done this 20K - hmm that's odd if skoda did a check on the tyres a few months ago and didn't pick up inside edge wear ( possibility that there has been a rapid deterioration in that time) did whoever changed the tyres check the suspension at the same time? what car is it, engine / year /spec/ wheels - I take it it's not been modified ? I would 100% get a 4 wheel alignment a combination of negative camber and excessive toe in will eat the inside edge pretty quickly. if that's ok then it's time to check suspension and compenents / trailing arm bushes etc.
quite possibly the alignment - have a tendency to wear on the inner edge on the rears, when was the tracking last checked? inflation checked?
VRS Exhaust setup
? yeah as I said a 200 cell cat (sports cat) you won't need to replace this every year .. unless you mean removing the cat and refitting for MOT Each year.
VRS Exhaust setup
ok so it's not illegal to remove the cat but it's a requirement for an mot. if you're going stage 2 I'd be looking at high flow turbo back with 200cell cat. later add in high flow intake,uprated DV version, upgraded intercooler and engine mounts. milltek (get a good rep on here) scorpion power flow Remus Apr non resonated will be louder and might be a bit droney on long journeys
Throttle position
so I looked at the live data again as it just states throttle % so Ive found out exactly what it's monitoring and it's throttle position (manifold) % will this make a difference to what the data means
VRS Exhaust setup
hi and welcome - it's worth stating what engine you have and year, should be able to get better answers then
Throttle position
Surely there's a issue if it's reading 80/90% at idle ..and the readings are all over the place like it'll go 32-80-25-62..etc. I'm going to screen record some live data and post it on here later - I'm also going to check the voltage with a multi meter. after that I'm going to have my local garage run a scan on it see if they can spot anything I guess after that maybe remove it and check to see if it's all clogged up then ,maybe think about replacing it.
Throttle position
so I can find a Oem throttle body replacement 185VG0510 for £180 - would this be a straight swap not requiring any VCDS witchery
Throttle position
thanks, do you know if these can be replaced just sensor only ? http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA) - I was reading this which stated Tdi's donot have throttle bodies ? http://wiki.ross-tech.com/wiki/index.php/Throttle_Body_Alignment_(TBA)
Throttle position
is there a separate senor or is it built into the pedal? assuming the throttle sensor is inside and linked to the pedal and not somewhere like the throttle body in the engine. .
Throttle position
in prep for my remap I thought I'd have a good check over the car - using carista (ELM327) nothing comes back so I assumed all good - I also used torque pro to have a look at some live data and something seemed off on absolute throttle position % with the ignition on it shows 92.5% (pressing the pedal did nothing) engine on goes down to 88.2% now pressing the pedal seems to make the % go down ...? I assumed it would read 0-100% starting at 0 the car, as far as I'm aware, drives fine (slightly sluggish 1000-1400 RPM) boost seems to hold steady as 22.3 PSI when accelerator fully depressed all through the rev range and drops off as soon as the pedal is released. thinking the TPS is goosed but I can't seem to find any info on replacing it or a replacement part. any help or info on this will be greatly appreciated as i'm sat scratching my head,
pressfit BB what options
my bottom bracket is very much on the way out and needs to be replaced, this is a little disappointing as it's only been around 900 miles- being pressfit, what are my options? can I just use a adaptor to convert to threaded ?
help finding a new bike
looking for some advice as I'm after a hardtail sub £1000 specs I know I want 1 x 10-12 gears 27.5 or 29er (leaning to 29) hydraulic discs 180/160 air forks ( ive been told with my weight 15-17st, air would suit me best) what I'm a little unsure about dropper post - I assume this can be added later? full suspension? - I've been told not really needed for what I do (Sherwood pines, through some wood lands, small jumps / drops and some bike path stuff with the Mrs) and I would be better of getting a better spec'd hard tail. tubeless wheels ? bikes I've looked at / considered buying voodoo - bazingo/bokor ( minustor/canzo -full sus) cannondale trail 2/3 / Cujo 2/3 trek roscoe 7
Gissin's White vRS project
Hi all, So after buying a few cars I wasn't bothered about working on, I'm back to playing with cars again I purchased a White vRS FL TDI and have enjoyed every minute of it so far, I've not done too much yet mainly just getting the car to a nice standard first, so in doing so I brought the following to do a full detail on it: Bilt hamber - korrosol and soft clay Poor boys - wheel sealant and light polish G3 colour restorer , super resin wax and clay mitt (for the wheels) Angelwax- heaven for leather cleaner Megs - gold class shampoo and lambs wool mit simmonz - tyre black and shine also picked up their hard wax with carnuba because it was on offer for £4 so why not I already had a few bits in my kit already but this lot did me proud
