Everything posted by Gissin
Gissin's White vRS project
I have a vrs mk2 (non mfsw) steering wheel with airbag, clock spring and stalks, orginal vrs springs and rarb. Full set of paid brake pads (almost new) going if anyone's interested
Goodbye for now (I may be back)
So after owning my 2012 octavia vrs for over 9 years, she's been sold today. A sad day, its been a fantastic car, ive enjoyed working on it and making changes ive learnt alot from the forum (and hopefully helped some people too) Now been replaced with a alfa romeo giulia which may or may not prove as reliable as my skod but it sure is a great car to drive. Might be back in a skoda one day. See you in the mist Regards Tom
- Gissin's White vRS project
Well she's gone sad day after 9 years of ownership now replaced with an Alfa Romeo giulia- Gissin's White vRS project
changes over the last few years MK3 mfsw added OEM bluetooth (BT audio and phone calls) upgraded drilled grooved front discs and performance pads She's still going strong but unfortunately time to sell :(- New style badges for Octavia mk2
you need to break the pins off - they're there for alignment but obviously not designed for use with the mk2 grill, so need to be careful when sticking the badge on- New style badges for Octavia mk2
Here's the part numbers you'll need: 1ST 853 601A AUL - Front 1ST 853 630 AUL - Rear 601 151 ULM - Wheels- Skoda Octavia Mk2 Facelift vRS MF Steering Wheel White Stitching for PQ-Cars ***SOLD***
DM'd- Paint Or Powder Coat Wheels?
you got any photos of the pc white wheels?- 2.0 tsi petrol how can I get a safe 300bhp ?
to be getting to 300bhp you'll need to be looking at stage 3 remap....so decat, Intake, intercooler, maybe a upgraded HPFP, full exhaust system.. r8 coil packs, upgraded plugs and maybe your clutch could handle it but I doubt it so factor that in . Stage 3 involves KO4 turbo upgrades ... injectors and other stuff ..Stage 2 will see around 270-280bhp which is pretty awesome anything past that personally I'd be looking at 4wd to be able to out the power down... torque steer is a bitch- Brake pad thoughts... !?!?
totally agree, I replaced mine all round including brake fluid, they're perfectly fine for normal driving but if you push them slightly they suffer from brake fade and I suspect they'd warp if you went further.. saying that I'm at 15k in they're still ok for everyday driving- Brake discs and pads
front: Centering Diameter mm65 Height mm50 Brake Disc Type Vented Minimum Thickness mm22 PR No.1LL-1LP-1ZB No.Holes5 Disc Ø mm312 rears: Bolt Hole Circle mm112 Brake Disc Type Solid Centering Diameter mm65 Height mm48 Minimum Thickness mm8 PR No.1KS-1KT No.Holes5 Disc Ø mm272 Pads: Height mm71 Length mm155 Thickness mm20 Wear Indicator: Integrated PR No.1LP-1ZB Disc Ø mm312 Fitting Position: Front # Brake System: BOSCH Height mm53 Length mm109 Thickness mm18 Wear Indicator: Not Fitted PR No.1KF-1KS-1KS,1KT-1KT Disc Ø mm256,272-272 Fitting Position: Rear- Brake discs and pads
there's a sticker in the boot under the floor that gives you codes alternatively measure them. there's an old post of mine with details on it, should be the same size as yours i can highly recommend Vagbremtechnic Hooked discs and the Ferodo Racing DS2500 pads are good too, make sure you change your brake fluid.- No dash lights, no nothing
- Mountain bike
i have a 27.7+ and mine fits without removing any wheels have the turn the front one slightly and obviously drop the back seats- The Gear shift indicator shows 6 uparrow
you sure it's not telling you to change to 5th, what speed and revs are you doing in 6th?- Gissin's White vRS project
been busy putting a new kitchen in the house but thought it was time to update... splitter and black roof looks awesome- Wheel centre caps
if you're replacing the caps you don't need to remove the wheels.- severe steering wheel wobble
have you had 4 wheel alignment checked ?- How to remove anti-roll bar stabiliser bushing?
I've never done a front one, but assuming you can take the brackets off, you could probably cut off and replace in situ. have you considered a full replacement SKODA OCTAVIA Mk2 (1Z) Front Anti Roll Bar 22MM 1K0411315R | eBay- Maxton Design VRS Grill
if it's the same as the rear ARB they're bonded to the bar, so you can either cut them off and replace or replace the unit as a whole- New addition...
how do you map out a DPF without doing anything to it ?- New addition...
i was under the impression if a DPF was part of standard fit equipment and it has been removed or tampered with, it will fail the MOT- Octavia FL 2.0 TDI CR VRS Intermittent Power Loss Issues
sounds like you've got a split hose or even the turbo is failing. does it take a while to get upto say 2.5Krpm and after that it's ok? any excess noise? - Gissin's White vRS project
