MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @numskull Ordered from local VW dealer, They were four identical within one package
  2. Each new tread contains links to previous, which version you are searching for?
  3. @langers2k https://www.briskoda.net/forums/topic/512842-amundsen-mib2-map-updates-2024/
  4. @numskull don't ask too much! 1. VAG engineers have had unknown reasons to develop them 2. they fit in our Superb 3. why not then comes immeasurable 4. dust protection 5. sound deadening 6. finished look huge closing comfort improvement came from Electric Suction Door
  5. improvement aren't as huge as i waited for, for unknown reason they ignored adding of ~3mm foam layer example -> https://www.drive2.com/l/471766905447777004/ anyway sound comfort now are on higher level than A6, E-Class have got from the factory, little bit behind 5 series
  6. -5 mm front, -15 mm rear, but DCC by default had -10mm link above and numbers were comparison to my previous MY16 220ps. now i have MY23 280ps, which have +12 mm in front and +22 mm rear and annoying waterbed effect in Comfort/Normal modes. OEM DCC will be definitely replaced, just not within this year
  7. any of the OE springs he offers are too soft for the Superb 😞 to add stiffness search for some from lowering kits, but to avoid lowering chose some from some weightier car. for FWD Superb as acceptable(-15mm) i found Eibach Pro springs from AWD Superb. which will be good for AWD Superb i haven't found yet who will try to share his experience? by max load ->
  8. Hi @numskull! these Audi's / Bentley's parts make Superb drive faster and add finished look
  9. to avoid lowering, chose custom springs from some weightier car 2.0 TSI 220ps FWD got perfect result with these -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5697693
  10. @IulianE one extra wipe with few seconds delay after windscreen washer
  11. it were done also on my previous MY16, but i haven't saved instructions there are from MY23 Mk3.FL, must be similar Tear Drop Wipe For Front Wipers 09 Central Electrics Subsystem: 48x LL 221122 Long coding 164DDD -> 1E4DFD -> Byte 0 Bit 3 "Adaptative Post/Tear Wiping Active" -> Byte 2 Bit 5 "Post/Tear Wiping Active" or Adaptation -> Front_wiper ---> Traenenwischen Front Status: not active -> active
  12. even worse 2023.02 -> 2023.06 l / 100km MPG.uk 12,7 22,3 17,8 15,9 15,9 17,8 9,9 28,6 9,4 30,0 16,2 17,4 8,7 32,6 12,3 22,9 9,6 29,3 15,9 17,8 avg 11,8 24,0
  13. @Graham Butcher i replaced whole part, which were ordered from Ali -> https://www.briskoda.net/forums/topic/426372-rear-passenger-air-vent-part-number/?do=findComment&comment=5332587
  14. 2016. 220ps 123k km 7 years 2023. 280ps 3k km 4 months
  15. the driving mode button near gear lever and menu section in the head unit
  16. @Graham Butcher i can't remember how exactly 😞 99% that were these
  17. what interesting - Škoda's EU1 is still packed into 'zip' as previous, but all others packed now into '7z'
  18. @John1701 2010 are previous 2023/2024 current 2024 -> 2110
  19. similar issue had my previous 2016, few months newer cars got recall with software update 175 Mb video -> https://www.briskoda.net/forums/topic/501383-automatic-lights-on/?do=findComment&comment=5627092 -> https://www.briskoda.net/forums/topic/368574-vcds-options-on-superb-iii/?do=findComment&comment=5642089 VIN weren't listed in recall list, few months too old and this light beam isn't enough down, claim were rejected by dealer (restart ignition improves situation, but not solve)
  20. @JR RS not tested for long, second picture is video i'm not trailblazer, several other VAGs with same supplement -> https://www.drive2.ru/l/548080159241011742/ -> https://www.drive2.ru/l/533914051428745659/ -> https://www.drive2.ru/l/625855763499200741/ -> https://www.drive2.ru/l/544268152427511986/ -> https://www.drive2.ru/l/597466648147920028/ -> https://www.drive2.ru/l/543462210404352055/ I forgot some minor details: previously replaced OEM 8J0 947 409 B single LED Trunk Bulb found it's new place behind panel above compartment under steering wheel added Lock Seals 4M0 837 087
  21. Electric Suction Door 2pcs https://www.alibaba.com/product-detail/Soft-close-automatic-auto-body-systems_60795154530.html video -> 2023-05-29 at 19.12.53.mp4
  22. welcome -> https://www.briskoda.net/forums/topic/449490-noise-insulation/
  23. @ArtursLVspoilers ->
