MartiniB
FREEDOMTech
Everything posted by MartiniB
  1. @JR RS not tested for long, second picture is video i'm not trailblazer, several other VAGs with same supplement -> https://www.drive2.ru/l/548080159241011742/ -> https://www.drive2.ru/l/533914051428745659/ -> https://www.drive2.ru/l/625855763499200741/ -> https://www.drive2.ru/l/544268152427511986/ -> https://www.drive2.ru/l/597466648147920028/ -> https://www.drive2.ru/l/543462210404352055/ I forgot some minor details: previously replaced OEM 8J0 947 409 B single LED Trunk Bulb found it's new place behind panel above compartment under steering wheel added Lock Seals 4M0 837 087
  2. Electric Suction Door 2pcs https://www.alibaba.com/product-detail/Soft-close-automatic-auto-body-systems_60795154530.html video -> 2023-05-29 at 19.12.53.mp4
  3. welcome -> https://www.briskoda.net/forums/topic/449490-noise-insulation/
  4. @ArtursLVspoilers ->
  5. worth! together with these strips -> https://www.briskoda.net/forums/topic/449490-noise-insulation/?do=findComment&comment=5221913 -> https://www.briskoda.net/forums/topic/449490-noise-insulation/?do=findComment&comment=5222150 what gave + ~20% improvement to full sound deadening installation size(11+3 x 18 mm) of following is about 25% too big for normal closing -> https://www.aliexpress.com/item/1005003678102965.html haven't tested yet, maybe with Electric Door Suction they will be ok 2023-05-29 at 19.12.53.mp4 waiting now smaller ones, 10 x 10 mm -> https://www.aliexpress.com/item/1005003361593514.html
  6. on my previous 2016. 220ps Start-Stop stopped working after ~30 months and came back in order after battery were replaced under warranty at 48 months 83 kKm after what i have installed Start-Stop state memory module, which deactivates S-S by default and i manually enable it only at longer stops
  7. speed on dashboard is calculated by wheels rotation instead apps on smartphone shows by GPS, what is closer for true on my previous 2016. 220ps offset were +4km for each 100kmh on dashboard with stock tire size 215/55r17 and just +2km with custom tire size 225/55r17 on my current 2023. 280ps i made small corrections by OBDEleven module: Control unit: 17 Dashboard System description: KOMBI Software number: 3V0920790H Software version: 6220 Hardware number: 3V0920790H Hardware version: 526 ODX name: EV_DashBoardVDDMQBA0 changes: Wheel circumference 1 17 Dashboard Long coding orig -> 05A5001AFF8C000A0188734B0001000800600000 new -> 05A50019FF8C000A0188734B0001000800600000 or --> Wheel circ.: orig -> Version 3 new -> Version 2 Wheel circumference 2 17 Dashboard Long coding orig -> 05A5001AFF8C00080188634B1001000800600000 new -> 05A5001AFF8C000A0188634B1001000800600001 or --> Wheel circumference 2: orig -> Version 1 new -> Version 2 result:
  8. exactly the same result, just activated manually @VenomVrs recent years DSG equipped cars have got coasting in 'D' mode by default there is coding to disable coasting, maybe you can find similar parameter and change it opposite way -> https://www.briskoda.net/forums/topic/513598-disabling-coasting-function-in-facelift-dsg-cars/?do=findComment&comment=5757722
  9. put 'D' to 'N' and coast
  10. only, if you are happy with current softness, mine and several other BS members conclusion is, stock springs are too soft. i can guess, that is marketing department choice, to make brighter difference between Comfort<>Normal<>Sport modes. Little headache of chose and lottery factor is guarantied to avoid lowering - acceptable combination for FWD 2.0 Hatch you can find in link i posted above, but i can't choose which Ebach Pro springs will be perfect for AWD 2.0 Hatch on the rear axle. also replacement costs can be saved by replace all together
  11. +++ 2025.06.02 +++ -> next 2025.02 # ECE 2024.06 28 Gb version:{"major":1167777,"minor":24032,"build":0} version:{"major":1167777,"minor":24032,"build":0} VW portal: https://navigation-maps.volkswagen.com/vw-maps/EUR_13PR129_FCT3WS-241E0_Offline_Update.tar Files inside: 2024.05.24 Downloadable: 2024.06.14 Published: 202-.--.-- Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_EU_202448_Offline_Update.zip Files inside: 2024.05.24 Downloadable: 2024.11.18 Published: 2024.12.0? Seat portal: https://navigationmaps.seat.com/MIB3/CW48-2024/EUR_13PR129_FCT3WS-241E0_Offline_Update.tar Files inside: 2024.05.24 Downloadable: 2025.01.02 Published: 202-.--.-- # Asia 4.1 Gb VW portal: https://navigation-maps.volkswagen.com/vw-maps/ASIA_13PR129_CT3W-241E1_Offline_Update.tar Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_ASIA_202448_Offline_Update.zip # Australia 1.8 Gb VW portal: https://navigation-maps.volkswagen.com/vw-maps/AUS_13PR129_CT3WS-241E1_Offline_Update.tar Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_AUS_202448_Offline_Update.zip # Chile 496 Mb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_CHILE_202448_Offline_Update.zip # India 7.6 Gb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_INDIA_202448_Offline_Update.zip # Israel 244 Mb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_ISR_202448_Offline_Update.zip # North Africa 1.5 Gb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_NA_202448_Offline_Update.zip # Turkey 20.2 Gb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_TUR_202448_Offline_Update.zip # Gulf Region 2.8 Gb VW portal: - - Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_AGCC2_202448_Offline_Update.zip # South Africa 1.5 Gb VW portal: - - Å koda portal: - - # South America 8.2 Gb VW portal: https://navigation-maps.volkswagen.com/vw-maps/MRM1_SAM_13PR129_CT3WS-241E1_Offline_Update.tar Å koda portal: https://infotainment-cdn.skoda-auto.com/base/maps/OI_P129_MRM_SAM_202448_Offline_Update.zip ======= coverage ======= # Gulf Region Bahrain, Jordan, Kazakhstan, Kuwait, Lebanon, Oman, Qatar, Russia, Saudi Arabia, United Arab Emirates # South Africa Botswana, Lesotho, Mozambique, Namibia, Reunion, South Africa, Swaziland, Zimbabwe # South America Argentina, Bahamas, Brazil, Colombia, Costa Rica, French Guiana, Guadeloupe, Martinique, Mexico, Panama, Paraguay, Peru, Puerto Rico, Uruguay, Venezuela
  12. +1 for Bilstein B6 DampTronic -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/?do=findComment&comment=5697693
  13. +1 some e-shops still offers old gen1 OBDEleven PRO, exactly same device which i used to for Å S Mk3 2016 and now for Mk3.FL 2023 have no idea, how then will work PRO license -> https://www.lemona.lv/vieda-automasinu-diagnostikas-sistema-obdeleven.html
  14. .. coding .. -> https://www.briskoda.net/forums/topic/436180-permanently-disable-stopstart/page/2/#comment-5747940
  15. another cover has been add under bonnet €9,38 Battery Cover
  16. made same coding today, there were suggested also second part, left it for later source -> https://forum.obdeleven.com/post/80599/thread
  17. Sad, i'm so interested on some feedback for previous 2.0 TSI 220ps FWD Hatch i found as perfect springs from AWD Wagon's kit but which rear springs for my current 2.0 TSI 280ps AWD Hatch . . .
  18. @A7AS copy-paste from another tread: due Bilstein parts shortage in 2021. i had to install Eibach Pro springs on the rear axle few months earlier than Bilstein B6 DampTronic shocks that gave me conclusion, the most, 65% of performance improvement, came from stiffer Eibach Pro springs -> https://www.briskoda.net/forums/topic/485647-bilstein-b6-dcc-shock-absorbers-available-at-last/page/4/#comment-5697843 for 2.0 T*I front axle Eibach Pro F11-85-043-02-FA springs(Pro kit for Audi Q2) will add stiffness without lowering for 4x4 rear axle i can suggest four Eibach Pro lottery tickets: 11-79-013-01-RA 11-85-016-10-HA 11-85-026-03-HA 11-85-011-01-HA
  19. @A7AS "Eibach Pro kit" = Lowering 😞 choose custom, from weightier cars to avoid it scroll up to tables, i posted above -> https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/?do=findComment&comment=5712661
  20. -> https://www.briskoda.net/forums/topic/393511-what-bulbs-are-fitted-to-the-s3-upgraded-bulb-recommendations/?do=findComment&comment=4994279
  21. Superb Mk3 will be better in couple of parameters even when compared to Octavia Mk4 or Kodiaq Mk*
  22. will first line in the head post "cross compatible"
