Everything posted by nige8021
High level brake light problem
If it's anything to go by the similar unit for an Octy estate is around £240 !! so a repair if possible might be a better option ?
Optimate for a car
I've got a NOCO Genius 10
2022 F1
The FIA are just s**te scarred of applying the rules they set out, and when the winning team principle says it shouldn't of finished like that, not the second place principal tends to strengthen the arguement that the FIA is in a mess and maybe Mr Masi freestyling wasn't such a bad thing ?
2022 F1
What a shambolic end to the race, seems the FIA haven't learnt from last years fiasco or are just s**te scarred of being seen to do the wrong thing again ? One good thing was Ch4 having Lee as the lead presenter, to show real sincerity about HM The Queens passing, as I hate to think what the Welsh guy would of done !
What glue to use
Something like this https://www.amazon.co.uk/Plastic-Welding-Machine-Staplers-Repairing/dp/B08X6VMYRS/ref=asc_df_B08X6VMYRS/?tag=googshopuk-21&linkCode=df0&hvadid=499292497816&hvpos=&hvnetw=g&hvrand=16219753051871651108&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1006933&hvtargid=pla-1225380420916&psc=1 for a proper repair ?
2022 F1
Porky can't agree terms with Red Bull https://www.bbc.co.uk/sport/formula1/62850221
New car key cut
That link is for pairing the new key to the central locking not the immobiliser chip, to do that you need to read the immobiliser PIN code from the speedo unit then with VCDS you can match that RFID chip to the immobiliser or Timpsons shoe menders might be able to just read the chip in the original key and copy it to the new one
G62 Coolant Temperature sensor placement 2.0TDI BMM Engine
https://skoda.7zap.com/en/cz/octavia/oct/2007-419/1/121-121035/#1 038 121 011 J
https://skoda.7zap.com/en/cz/octavia/oct/2007-419/1/109-109000/#4 Kit with tensioner/roller/belt 03G 198 119 A
#9 is the hose from the top of that radiator so easy to follow that back
Karoq After Market Tow Bar
It is also shown on the V5 logbook O.1 Braked limit & O.2 Unbraked limit
No High Beam
Just before you do what sort of headlights do you have ? as one version there is a high beam/flash relay
No High Beam
Ok that would indicate the stalk switch is at fault then
No High Beam
Does the high beam warning light in the speedo come on ?
2022 F1
Hamilton wasn't a happy bunny with the team tacticians, but it was Russell's call at the last minute for softs otherwise they would of both been sitting ducks.
Sourcing full set of cooling system spring band constant tension hose clamps in stainless steel
Not sure if this is the sort of thing you're looking for https://www.ebay.co.uk/itm/114212795933/ ??
Driver’s door lock expert needed
Try https://www.stevensvwspares.com/ normally have a good stock of genuine parts at decent prices and fast delivery
Part numbers needed
How does this look ? https://www.google.com/search?q=1K0+899+185&sourceid=chrome&ie=UTF-8
finding a useful diagnostic tool for budget price
Gendan https://www.gendan.co.uk/product_VAGUSB.html sell a cable for use with VCDS-Lite but it is only K line not Canbus and yours being a 2006 it will want a Canbus capable cable for full diagnosis ability I have a full Hex v2 unlimited based in Milton Keynes but at the moment I'm without transport as my Treg engine is in the process of being repaired
Removing marble
With the seats unplugged, don't switch the ignition ON or you set a fault code in the airbag system and that'll need the correct kit to turn off the airbag warning light
Photography Thread
Photography Thread
Red 6 (the pilot of the affected jet) tweeted a similar picture with no credit given to the photographer
Photography Thread
They were based at Hawarden for the Rhyl show and they returned there after the bird strike.
- Battery SOC Issue - Grateful for any advice
