Everything posted by Longship
Brand new vRS or brand new 1.5tsi?
If you can save £7k off list price, £3k in extra tax becomes a slightly moot point. :)
In your position, I'd get a vRS with less than 1k miles for around £35k. Just because you have the power doesn't mean you have to use it. My vRS 245 just did an overnight trip of 463 miles at an average 56.5mpg :)
AC issue
I know I have a leak in my AC system as it failed a few days ago and my OBD reader reported a static pressure of 11psi. Getting it in to Skoda will be a real pain but is anyone able to look at their system pressure on a cold non-running engine and let me know what a normal value should be? Just to be clear, it will be going in for a warranty repair and I'll get a service done at the same time. I have a long family trip planned for the end of July so it needs to be fixed by then.
Driving Score in MySkoda App
Typical, just did a very long overnight journey and wanted to see how that impacted the score. I've no doubt that Skoda are still collecting all that data, as will most (all?) modern connected vehicles, it's the clarity of the end purpose that needs to be addressed.
Traffic sign recognition error
Another thing to bear in mind is that the speed sign recognition is not infallible. Plenty of times it'll pick up the wrong sign and tell me I'm too fast or slow, so hardly evidential quality. Vehicle event data recorders though ... ;)
I'm not sure that the camera system is smart enough to recognise the advance warnings but I wouldn't worry about insurance or enforcement issues. The data goes to Skoda and is held for a year and they need your explicit consent to share with 3rd parties.
No driving modes
Are these manual cars without the mode selector?
- Repair cost dispute
MyŠkoda app v8 - activating or standby
On a previous (non-Skoda) car, access to servers and therefore vehicle, tended to be flaky at the start of the month. It was put down to server capacity being taken up users downloading journeys etc for expense mileage claims. Not sure how true that was ...
Braking Questions - pad wear.
Do Octavia's have torque vectoring by braking? This has been known to increase wear on rear pads.
Apply Park but not handbrake
My car doesn't get used very often, and only for very long journeys when it does so I clean the rear discs by pulling the handbrake button when moving and off the accelerator. Obviously only done on a quiet road when confident not going to affect other road users. Done that with my past 4 cars with electronic handbrakes, not comfortable with leaving the handbrake off even though I have a level drive.
Skoda Connect Renewal
Recently bought the traffic sign recognition add-on and it's fairly useful, but I understood it to be a one-off payment?
How to find exact spec....
For the definitive list of equipment fitted, you can contact Skoda customer services and request a build sheet. You'll probably have to provide proof of ownership, such as V5 scan.
Terrible grip on stock VRS
My vRS came with Goodyear Eagle F1's as stock and while they were fine for warmer weather, they weren't good for the cold. Did less than 1500 miles on the F1's before I swapped them out for Bridgestone Turanza 6's a couple of months ago, which I aim to keep on all year round. No complaints so far.
Octavia IV fast heating when cold
Some models do come with a PTC heater element as standard, although I think they could be mostly diesels. Can you look at the option codes your car has to find out? A previous Jaguar I owned had a 1kw PTC element in the vent system and that defrosted the screen and started to warm the interior within seconds of a cold start.
Update To Infotainment Version 1985 - Download Link and Guide
Thank you spcdust, I've downloaded the file and will update at some point.
Service and oil change info
Just as a comparison ... my vRS Tsi was new in March but I got it with 16 miles on it at the end of September and the app is showing; Mileage 778 Inspection in 655 days/at 19,199ml Service in 613 days/at 16,900ml
Octavia vRS FL first impressions
Gearbox temperature is an option in my '24 plate vRS. I may have had to select it as a displayable item, but it was readily available.
Dealer not covering blocked screenwash jets under warranty!!! Responses needed ASAP please :-(
The issue has never happened to me, and I've not been keeping too close an eye on what brand I use over a few decades of driving. There's another school of thought that says having too week of a mixture can cause bacterial growth, and I do like to keep the mixture fairly strong, even in summer.
There are different types of screen wash fluids that can cause a gel like substance to form when mixed. You don't have to use the VAG branded stuff, but you do need to use compatible fluids I'm afraid.
The "expensive vehicle tax" is based on the cars "list price" and from the UK Gov website; The list price is the published price of the vehicle before it’s registered for the first time. It’s the price before any discounts are applied. A bit more info ... my understanding is that VED rates are set by the published P11D value of the vehicle. So the Recommended OTR price of £39,775 has a P11D value of £39,040 (plus any options).
Recommended tyre pressures - are they too high?
BMW like to use runflats with stiffer sidewalls and/or also higher load ratings. I should have started my previous post of with "Typically,"
My understanding is that as tyre widths go bigger and profiles lower, higher pressures are required to maintain even wear. Running a PSI significantly below the pressures stated on the label might cause wear on the edges of the tyre, and potentially even cause a blowout on a sustained higher speed journey!
Octavia MK4 not approved for towing.
Try this; Skoda-Octavia-2024-UK.pdf Be aware though, the brochure has some strange tyre sizes listed!
1600kg for the vRS FWD's and 2000kg for the AWD version (braked capacities) are what is shown in the UK brochure for my '24 model.
