Everything posted by froggy8
- Weird revs at idle
Weird revs at idle
hi guys, i have had this problem since i got my car, i didnt know it was a leak till i read this thread. it happens when i press the clutch and when the rev needle goes back down to below 1k, it carries on going down to 500 then backup again just like the OP. i did ask my mechanic and he told me it would be a big job so then i left it, it turns out it goes back to normal when i pull the gas pedal up (by putting my foot behind the pedal and pull it towards me). i will have a look at where the leak is then try change the pipe, hopefully i can fix it.
Handbrake allowance
apologies to hijack this thread but was wondering if this applys to my car too? thinking about doing the same. so i just take the panel off behind the handbrake?
Time for an engine refurb?
i have thoroughly enjoyed reading thsi thread so happy that you have sorted it mate if i had to change an engine, i wouldnt know where to start so kudos to you
How do I switch out my swing radio for an RNS510? Which parts do I need for bluetooth, GPS etc. and where can I find them?
mine is the dance stereo and this is the harness i got for it: https://www.ebay.co.uk/itm/Skoda-Fabia-2007-2010-Car-Stereo-Quadlock-Wiring-Harness-Ignition-Generator-Lead/262319713590
hi i have managed to change my stereo after a few weeks, it is quite awkward. i got myself a single din stereo then hd to get a single din stereo converter adapter. i thought it was straight forward but it wasn't, had to get the harness too. problem was the stereo wont turn on if the ignition is off, if i had my original stereo then i can switch the stereo on without starting the car. hope this helps.
driver door does not show on the dash
yes i have a haynes book, forgot about that. thankyou. do you think that link what i posted above will do the job? thank you again
is this the correct one? https://www.ebay.co.uk/itm/Skoda-Fabia-MK2-Driver-side-Front-Door-Lock-Mechanism-3B2837016AB/193924950245?hash=item2d26d3e8e5:g:yTwAAOSwglJeGdIU
many thanks for reply. i have tried taking it off before but i couldnt take that wire off from the handle though.
anyone please help
spark plugs recommendation
20k? ive only done just over 2k since last april.
hi guys i bought these spark plugs last april, will i need to change it yearly? reason i ask is because someone told me that these kind of plugs can last few years.
exhaust blowing issue
i did bit of research after i posted this and realised i needed to know how to weld first, sorry, my bad.
thank you, i will ring skoda tomorrow. this might sound stupid but does having a holein the flexi pipe effect the fuel? such as using more?
abs cable snapped
thank you i will ring them when i get a minute.
Offside number plate light not working.
will there be a fuse for it?
abs cable snapped
hi guys, my abs broke just after the adapter, i cant seem to find it on google or ebay, they all come up with the adapter. i need the cable that goes to the abs adapter from the ecu. many thanks guys
i want to try sort it myself, its the part under the engine, will i need this part? am guessing its the flexi part. https://www.ebay.co.uk/itm/SKODA-FABIA-MK1-MK2-1-2-Exhaust-flexi-Repair-section-cat-flex-front-pipe-01-14/283197130586?fits=Car+Make%3ASkoda|Model%3AFabia|Cars+Type%3A1.2|Plat_Gen%3AMK+II&hash=item41efdd475a:g:aiwAAOSwF2FbuIXi
i have just read another thread that a guy got the part that was blowing fixed for 150 so i guess my price isnt too bad.
Skoda Fabia 1.2 HTP (2006) Exhaust
i got quoted by a back street garage for 165 fitted for the same part. i guess it is not far off from what you are paying, i thought maybe i was being lied to.
the mechanic told me the whole exhaust pipe is 240 pound, i have seen loads on ebay for much less, am i getting lied to?
