Everything posted by imart143
O3 - 2015 - 1.2 TSI - Replacing splash guards at rear brake disks, how much trouble to expect?
buy 2 new big bolts for hubs, also buy new bolts for guard. for guard i would buy some inox bolts.
Oil level...
i always measure cold, pull dipstick out, wipe, leave overnight and than put in and out. if i try to pull it out when engine is hot, it wont come out easy, it have rubber O-ring that seals, and when hot it cant move easily.
1.5 TSI MPG: Octane vs additives (>4,000 miles longitudinal road test)
I bought the additive https://www.mannol.de/products/additives/ester-additives/mannol-benzin-ester-additive and I add it as it says 0.1% to 95 gasoline, it's a very weak mixture, I wonder if it has any effect in such a small percentage. I was thinking of increasing it to at least 0.2%, shouldn't it be a problem?
Moved from a Dacia to a Kamiq & comparing 3 cyl engines
Dacia Sandero 1.0 tce also have 5 sp manual gearbox.
unavailable outside UK.
Could high oil level cause my engine runaway?
diesel fuel of multiple unfinished regenerations od DPF filter..
1.5 TSI misfiring when started from cold
probably. on both cars i didnt feel nothing when driving, normal driving, just until mil occured, when i scanned errors were multiple random misfire detected and missfire detected on cylinder 1, 2, 3, and 4. on renault wrong sparkplugs were in engine, replacing solved missfires and MIL. on tsi intake was full of carbon buildup, after cleaning, also solved..
i had renault 1.6 before and now karoq 1.5 , all gasoline cars and when missfires occures after that MIL light on dashboard, with that cant pass mot in my country..
missfires are serious defects detected by ecu and after certain number of them check engine light will occur. if not, those are not missfires, maybe jerking or something, but not classic missfires. with missfires you cant pass MOT. BTW, act i good system, when driving in city when you lift throttle pedal it engages and make lean mixture to clean GPF filter, it is not just about economy. i dont see any economy benefit because driving sporty.
- Hello! Skoda Kodiaq owner here from Dubai.
Engine symbol warning light showing yellow
you have to put some OBD2 scanner in port and scan for errors. if you dont have any, go to garage. it can be anything.
Skoda Felicia 1.6 gearbox oil check
it is unusual way to check gearbox oil. if gearbox is not leaking visible, oil level is correct, if it is not changed for years, change oil, you need 1.5 litre ow 75w80 oil and 17 allen key. if you dont have it, use M10 bolt long about 5 cm and put 3-4 M10 nuts on it and tighten them. this should be good as tool.
Scala 1.0TSi (2023) for short trips?
sure, every engine is made for work on torque rpms, not idle.. i always had gasoline cars, this is first DI engined car i have, 75% i drive in rush, but once a month i go to open roads and flooring it hard. since on highway theres noregular control i often go to maximal speed and holding for few minutes. if you do it regularly, no problems, and oil changes in 7000kms max, because half of engine work is in idle or low rpm. it contaminates oil more than anything. i am changing oil every 8 months, its about 6-7000kms, and should be no problem, also i did carbon cleanup from intake ports 1 year ago. this year i will check ports with endoscope camera for deposits. last time was very much, but it was from previous owner. after 80000 kms.
Topics title is skoda 2023, so i was thinking he is looking for newer car. VAG last mpi engine was 15 y ago, or dual ported.. other producers had it longer, specially Japanese, Korean cars..
but those are all older cars. any car with GPF and euro 6 eko norm have DI.
1.5 tsi dont have egr.. in city driving no issues, i drove it for 4 months only in town, average speed 20km/h but driving sporty, full throttle, and then brake from here and there if it is not wet, will keep GPF regenerate normally. it is not functioning like on diesel. combination full throttle driving and no throttle cleans it best, lean driving clogging it. only what is clogging always are intake ports of carbon deposits from oil fumes.
1.0 CHZB woes
change oil. 3 years in engine it is long period.
1.4TSI Octavia on bioethanol
dont do it, its for bifuel engined cars.
Service warning still on after oil change.
you have to reset it. i did it thru OBD11, but i can be done in infotaiment too..
Steel Pedal Covers for DSG
i have this https://www.aliexpress.com/item/1005010052805511.html?
What is this?
look for some numbers on that part..
Skoda Kodiaq Haldex Service
this is your haldex oil clean filter an thats ok. https://www.autodoc.de/febi-bilstein/8773507?search=FEBI+BILSTEIN+%C3%96l%2C+Haldex-Kupplung+%28101172%29 https://www.haldexrepairs.co.uk/shop/fluids/febi-bilstein-101172-850ml-haldex-oil-for-generation-2-3-4-5/?srsltid=AfmBOoqSYg9QKx0CW_J1gp5k3KStlEVnyH_PNHJs898_DJno6RNLeBoz
How severe carbon build-up happens to EA288 engines (2.0) ? When to start cleaning?
i had Yeti 2.0 tdi EA189 110 kW and on 150000 kms i removed intake shutdown flap and see 10mm deposit od intake mainfold, all was covered in black dirt, restricting airflow. it is because EGR didnt work properly, many short trips etc. need to be clean earlier, as you say at 100000km.
Type of Oil
in each countries they have different policy.. however, i will change it at 10 yrs.
Type of Oil
i did, i got answer Dear Sir/Madam, The timing belt replacement interval is 210000 km or 10 years. Best regards
