Alasdair1
  1. I reckon its the fan. Its pretty loud to be a water pump unless its bearings are failing. Was just wondering why it comes on. Doesnt do it all the time but as at the moment car is only doing 10-15min journeys.It might be failed or incomplete regen. Next time it happens I will have to be quick and pop bonnet to see. Will take it out for a decent run once the weather improves. Was going to do it today but its -5C and now we have snow so fire on and feet up plus a large drink as I have been out in it all day plus reeking of kerosene as boiler in green house was acting up. Its like cars. Works all year and as soon as it gets cold and miserable decides to break down. Many thanks for the replies Alasdair
  2. Not sure but will check. Car has full service history butt not sure if it has been recalled as I have only had it a few months Alasdair
  3. Many thanks, Does sound like a fan but I have never checked. It goes off after about 30secs. As said temp is normal and coolant level good. May be something to do with regen as at moment car doesn't get many long runs. Will check next timeit does it Thanks Alasdair
  4. Not sure if its doing regen or not. I am pretty sure it has a DPF unlike the 1.9tdi pd but havent seen any lights etc regarding starting dpf regen. Its a 12 plate 1.6tdi. Not sure if it actually displays when its regenerating the dpf or does it just do it in the baackground? Alasdair
  5. Hi there have a fairly recent purchase 1.6tdi MK2 and the rad fan keeps coming on for about 30 seconds as soon as engine is turned off. Doesnt do it all the time or when the engine is running as far as I know but happened again today. Temp outside is -1C. Have a 1.9tdi that never did this (in fact don't think the fan ever came on). Coolant level is good and temp never gets above 90. Is this something I should be worried about. Was thinking maybe a faulty temp sender but not sure. Just bothering me as to why? Alasdair
  6. If its an original Skoda/vw part it will have a part number stamped into the plastic or a sticker. My window motor is 1K0959792C. Yours may well be a different number but shoud look similar. . I generally google the part number and see what comes up. Try ebay for second hand ones? As far as the wiring loom for the door I reckon it will be a Skoda only part. I would replace/check wiring first. If the wwindows and mirrors arent working then its probably the wiring. Saying that it looks like someone has had a go at soldering the terminals on the motor. Alasdair
  7. May well be linked. If it was the main fuse I assume no lights at all so thinking earth fault at battery or bad terminals? Alasdair
  8. Garages used to do welding but these days its a quick spot on an exhaust or a small patch to get it through an MOT and thats about it. Have a friend who had a garage and he said the prep work etc plus welding costs so much in labour it wasn't worth it. Plus he always said that unless it was stripped right back and all the rusty metal cut out and done properly( which would in my cases cost more than the cars were worth) it would probably need rewelding again for the next MOT. Might be worth a quick check to see if anyone local does car restoration or if theres an old style garage near you. Body shops cost a fortune probably due to most repairs are being paid for by insurance. Alasdair
  9. I would check battery terminals are clean and not corroded plus tight. Next would do the same check with earth to chassis. If the mpg etc went to zero I would say the battery was disconnected somehow It may be a problem with the main fusable links at the battery box. My sons 1.2 had ABS fault etc and it was a hairline crack in one of them which I believe is a common problem. Not sure which one I replaced but couldnt see the crack until I removed it and it fell in half. I got a mixed pack out of halfords. Replaced and it its been fine since. Disconnect battery when changing or checking them Alasdair
  10. Many thanks, Going to pop into halfords and have a look. Need it soon as car is off the road. I have a few old ones about but they are getting past it. Still work but leak fluid and tend to drop slightly. Tried new seals but reckon there worn out aand not worth repairing. One is a 30 year old 2 ton Kamasa. Probably knackered them from lifting random things that were too heavy. Alasdair
  11. Thanks will take a look. Need it fairly soon. Didnt think to try screwfix Alasdair
  12. Hi there need to get a better trolley jack. Been using a small 1.5 ton halfords one but its ancient and need something to lift higher plus I could do with two as I am about to remove gearbox. Budget is around £100. Was looking at some online but problem is don't know what quality and build is like (They all look very similar but is it good Chinese or bad Chinese etc ). My local motorfactors only do professional and there £400 upwards. Halfords have a 2 ton one for around £100 but not sure if its any good. Had a look at SGS but seen mixed reports on build quality and reliabilty. The halfords ones come with 3 year guarantee. Will get used fairly often but not all the time. Any reccomendations welcome. Many thanks Alasdair
  13. Quick recap from this morning Jacked up both sides and in neutral, both wheels turn by hand no real resistance from box and only the wheel you turn moves. Jacked up both sides and in 1st gear turned one wheel by hand and the other goes in the opposite direction with slight resistance so reckon Diff working. Jacked up both sides and started car in neutral no wheel movement on either side but in first gear both wheels rotate forward in the same direction but I can stop them by hand. Reckon its the clutch thats failed suddenly. If its the original clutch its 19 years old so may be a corosion/age related problem. Who knows as said its a new one on me, so gearbox out unless anyone can think of anything else? At least the gearbox is fairly small. Hope it comes out without having to dismantle too much. Many thanks Alasdair Quick recap from this morning Jacked up both sides and in neutral, both wheels turn by hand no real resistance from box and only the wheel you turn moves. Jacked up both sides and in 1st gear turned one wheel by hand and the other goes in the opposite direction with slight resistance so reckon Diff working. Jacked up both sides and started car in neutral no wheel movement on either side but in first gear both wheels rotate forward in the same direction but I can stop them by hand. Reckon its the clutch thats failed suddenly. If its the original clutch its 19 years old so may be a corosion/age related problem. Who knows as said its a new one on me, so gearbox out unless anyone can think of anything else? At least the gearbox is fairly small. Hope it comes out without having to dismantle too much. Many thanks Alasdair
  14. Hi there , Did cross my mind but hub nut is tight and shaft spins in relation to wheels both sides when turning wheels by hand. When in gear neither shaft spins with car on ground with engine running. Car does seem to want to creep forward very slightly. Also raised car and held each shaft securely at gearbox flange ,turned wheels by hand with engine off and in neutral and they are both solid with no signs of movement. The car has done 70000 but is 06 and I reckon original clutch.
  15. When I was trying reverse without the clutch it was very gentle. the minute I heard the gears grating I stopped moving the gear stick. It was just to check the gear selector on top of gearbox was actually selecting/finding gears. It doesnt grate with the clutch pressed and seems to engage ok but no drive. After checking absolutely everything and replacing slave I think the clutch has either been contaminated with fluid but as i have nothing leaking under car more probably the centre of the plate has parted company or something like that. As I seem to have exhausted every option I think its time to try and remove box and have a look. (not looking forward to it as I hve no ramp) Theres no other way of checking. Going to have a word with an old mechanic mate tomorrow to see what he says but it does look like a gearbox removal. It was my teenage son who was driving but unlike most teenagers he is very good and doesnt abuse/thrash cars. He also stops and phones me if he hears or has any problems with the car. He said he changed down to pull into our road ,no noises and no previous slipping. Car just started reving without drive. If it is a clutch that has suddenly gone its as said very unusual and a new one on me but not impossible. Good thing is the cars in very good condition and everything underneath is corrosion free so should come apart fairly easily. Many thanks Alasdair
  16. When I was trying reverse without the clutch it was very gentle. the minute I heard the gears grating I stopped moving the gear stick. It was just to check the gear selector on top of gearbox was actually selecting/finding gears. It doesnt grate with the clutch pressed and seems to engage ok but no drive. After checking absolutely everything and replacing slave I think the clutch has either been contaminated with fluid but as i have nothing leaking under car more probably the centre of the plate has parted company or something like that. As I seem to have exhausted every option I think its time to try and remove box and have a look. (not looking forward to it as I hve no ramp) Theres no other way of checking. Going to have a word with an old mechanic mate tomorrow to see what he says but it does look like a gearbox removal. It was my teenage son who was driving but unlike most teenagers he is very good and doesnt abuse/thrash cars. He also stops and phones me if he hears or has any problems with the car. He said he changed down to pull into our road ,no noises and no previous slipping. Car just started reving without drive. If it is a clutch that has suddenly gone its as said very unusual and a new one on me but not impossible. Good thing is the cars in very good condition and everything underneath is corrosion free so should come apart fairly easily. Many thanks Alasdair
  17. Been working on it again. Reset gear linkage cables, Gear selector on gearbox seems to be clunking into place. Re bled new slave and raised one front wheel. In neutral its spins without any restriction or noise from gearbox. In first it has some resistance and sounds like gears are turning and engine is moving slightly on mounts but not trying to turn over. Same if I repeat with the other wheel If my clutch has completely failed and slipping badly is this a sign or is it a gearbox problem? Brain is so full of stuff can't think straight anymore. Many thanks for the replies Alasdair
  18. I can rotate wheel when in gear but what could be the problem? I assumed that the diff was compensating and it was the lack of clutch to engine connection causing the drive problem Alasdair
  19. Also remembered that if engine is running and no clutch pedal pressed it grates when trying to select reverse. Stops grating when clutch is pressed and seems to engage further but no drive. Its got me stumped. Alasdair
  20. I think so. Gear cables operate and selector moves and clunks into place/goes forward back and up and down. Difficult to tell if its in gear as there seems no drive from clutch at all. With one side jacked up and I rotate road wheel with gears I think are engaged it does feel very slightly different. When it was running the car would want to creep forward at medium revs slightly in first and also slightly creep back in reverse but you could stop it with one finger it was so slight. Also a slight humming/rumbling sound when in first and slight revs. Alasdair
  21. That makes sense. Never removed inner bolts Just outer hub nut etc. and inner bolts are still in place. Couldn't see it going back together either or been able to drive car for two weeks if I had pulled inner cv joint and it hadnt gone back in again. Reckon then its the clutch thats either worn out all of a sudden or contaminated with fluid. Changed slave as noticed internal gator was split as I removed it to check it hadn't seized in the out position. Seemed slightly damp plus clutch pedal was returning ok but may have been leaking over time. No signs of fluid under car but it could be sitting in bell housing and not draining. Had fluid level drop but had leaking rear brake cylinders as well as front flexi which were repaired for MOT so perhaps didn't notice I had another leak in the slave. Just hoping I didn't haave to remove box but can't think of anything else. Thanks Alasdair
  22. May seem like a simple question and I hope it makes sense. Been having drive problems. Changed wheel bearing and after driving for about 2 weeks drive went completely. Checked everything and narrowed it down to clutch or drive shaft. Been pointed out I may have pulled drive shaft from gearbox end during bearing change but as car was fine for 2 weeks after not sure how ? Question is how to check. Shaft seems solid and cv boots are intact, when I turn road wheel by hand shaft and outer cv joint rotates as well as inner cv including flange at Gbox end with no noticeable roughness or clicks. Shaft seems solid No noises when it happened either. Car just reved and came to a stop. Am i checking it correctly or am I missing something Alasdair
  23. Hi there had a sudden no drive problem with 1.2HTP and after a lot of hopeful checking to no avail reckon its either Diff problem or clutch contaminated/failed Took the slave out and internal gaitor is split with very slight signs of fluid. Fluid leak maybe a lot worse when clutch is pressed. No obvious signs of fluid under car but reckon clutch may be sitting in a puddle of fluid and not managing to drain out of bell housing hence no drive. Even with the slave removed still no drive/contact between engine and gearbox Tried everything else. Checked drive shafts and they seem good. Reckon need to take gearbox out. Had a quick look on line and tutorials say engine has to be hoisted up slightly with bar across wings when removing mounts. I have no lift or bar so question is can I support engine via sump. Its steel but don't want to crush it or damage it, Has anyone succesfully done this? (Mate put a trolley jack through his sump which was alloy) trying to lift his car. Used to regularly use the ssteel sump on my old volvo 940 but again it was a volvo. Also any tips etc would be appreciated ie. how high do I need to lift the car. Dont want to start then realise I have to lift it an extra inch or two to remove box. Its a 55 plate with 70,000 on clock. Normaly on a car of that age I wouldn't even bother but its in really good condition with no rust and so far everything has come off or apart with ease. Its like working on a new car compared to my other octavias and terminal rusty seat altea xl. I had a rear brake leak and front flexi which I have repaired so didn't notice any fluid loss. Many thanks in advance Alasdair
  24. Its a bit fiddly especially where the door lock mechanism fits through the plate . I watched a you tube vid. They removed cables etc from door but I managed to work around that. As said rivets are H duty I got this from toolstation for £20-00 and it did the job perfectly. Rivets I think are N91078801 The ones I used are I think https://www.ebay.co.uk/itm/174121630690?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5339017974&toolid=10049&customid=Cj0KCQiArby5BhCDARIsAIJvjISKJ7ZJ4GU8k2wH5Lg5ozSagk2Qo6iVb6zbzR36UTCjtlFc3dwWdLEaAlxYEALw_wcB&gad_source=1&gclid=Cj0KCQiArby5BhCDARIsAIJvjISKJ7ZJ4GU8k2wH5Lg5ozSagk2Qo6iVb6zbzR36UTCjtlFc3dwWdLEaAlxYEALw_wcB Alasdair
  25. Meant to add that if its just the plastic wheels etc you can get them individually but I just replaced the whole unit as mine had totalled itself
