Everything posted by Tell
Traffic data taking a long time to appear (Skoda Connect)
& they have go slow speeds. I use buy MVNO Sim cards visiting Japan the operation parameters were quite wide. Cheaper than the Japanese main providers which you couldn't buy since you didnt have a registered address, but there was a reason why they were cheaper. They always worked thou.
5 years ago till mib3 came along for the cheaper Vag brands. Seat and Skoda. The others got connect services more early. Yes you are probably best to cough up for the services when you got the car new then stop paying up when they stop working. The software updates come that way.
@joek666 was using a dongle thingey which gave the car traffic data. Skoda Mib2 standard which I think you pushed any old mobile card in ?.
Cunning. Well the mapping systems are only as good as the cartography and Google maps for one is pretty bad since it isn't a cartography company. The traffic speed data is useful but connect services is catching up. The adhoc Apple and Android Auto methods obviously provides a solution when Vag stops supporting the system. This will be a worry with connected cars although Audi were off the starters line earlier. Your probably seeing what happens when they stop supporting certain aspects of the car. It stops working or slows down.
Yes that will avoid any slow 4g. Where Vag buys data off providers and gets it cheap. But then if it's their servers and internal data comms it won't help.
Could be the same issue Vag has a habit of down grading it's offer as it judges the life cycle is over. Web pages disappear and slow data speeds through duff servers would be another. I recall the thread did give a pretty good explanation. I'm pleased with using old maps for mib2 standard and the mod. In the other car, mib2 high, the mod and the latest maps. Inrix isn't a bad service for giving road works and holds up. Different service to Google obviously.
Mib3 Map Updates 2024.06
Normally there is a parts ID on the file so shouldn't load into a unit that isn't compatible. You have to study assorted firmware files and uploads to work out what it is. Firmware isn't compatible but whether you'd classify that as firmware needs studying. The maps are interchangeable within a hardware type across brands. The logos get driven by another brand ID check but compatible if it's listed. Need a youngster with mib3 🤣.
- Mib3 Map Updates 2024.06
Well it's the whole of Europe that's on the map. The search engine is probably like the Here Maps online search engine so you have to narrow it down a bit. Free text search is probably the box you are filling in, if like mib2. That there is also a tabular view of the address where people have issues getting the postcode and town names in. The design is really for zip codes where the zone is much broader than our postcodes. It's a mute point whether it uses all 7 / 8 characters of the postcode or less. Bashing the street number will get you to a more exact place if it's been house numbered. Building names of residential homes aren't in the system, so where house numbers aren't available only the street name comes in. They have centroids of the street so you end up with the centroid (mid point). Postcodes have centroids as well so they get attached to the street. Some house numbering is done synthetically where they know the range of house numbers in a street and stretch these equal distance. Think these files are bought where that occurs or student projects. It fails where a recreation ground for example occurs in the middle of the street. Spacing is wrong. Probably occurs in 5 % of the house numbers. Basically two systems running one on street names and street numbers and one on postcodes. Commercial properties have their own postcodes. Residential ones share. You are always better to get a street number in as well as the street. People cherish their postcodes... use to do GIS from the start as it was taking off, survey work, analysis, modelling and planning. GIS we got into to assist planning and modelling. Hence my interest in mapping. Census analysis, deprivation and resource allocation... hence the postcode and GIS... two are related 😉. Point mapping is where you scatter the points randomly around the postcode to get intensity. The early mib3 programmers didn't know how to handle the suite of files they got from Here Maps, you could see they were building a GIS rather than a navigation system. That's been corrected now. They were having you turning off the road into a field to the centroid. The centroid has to be attached to the road so that doesn't happen 🤣. I don't hear about that now.
I'm not too sure what that does. @chills if they are Chillout would know. It could be just like a reboot and then took the update.... sort of stating the obvious. Bit like a Windows 11 inplace update as in 23h2 / 24h2 that resets parameters back to the default if they get corrupted. Then mib3 took the update. The question is for N Africa whether that reset had the European navigation FeC in it or in the case of the N Africa question whether the work that was done did actually update the navigation FeCs.
Well MartiniB top post covers them all and if it's like mib2 high and you have the FeC it should work but then mib3 could work differently. I have seen a person telling someone else on mib3 to change their firmware on a straight map upgrade. EU to EU as if their version of the firmware (on a Seat) wasn't kitted out for offline map update eg. A bug. Given that the firmware between Vag brands is re - purposed it's possible there could be a bug that prevented offline map updates that has been ironed out.
If it is like the mib2 high you probably need the navigation FeC altered to the rest of the world or specifically N Africa. I suspect it's an on the bench thing. Have you tried to just update the European maps to see whether it's taking the update. That red menu is back end menu obviously. There will be mib3 enthusiast sites and discussion forums just a question of plugging into them. Saying that as of last year little progress appears to have been made from this thread: https://www.briskoda.net/forums/topic/526371-how-to-unlock-mib-3-preh-with-patch/ I'm told thou that on the bench progress is suppose to have been made. Mib3 is better locked down unlike the mib2 high where you could do your own FeC activity. @East_Yorkshire_Retrofits I normally call up for their knowledge. I see they contributed to the thread above. Odis was mentioned, your dealer etc.
- Columbus Map Update 2025 (MIB2 HIGH)
Mib 1 maps update.
My helpful hand on the subject There is a univesal fix for getting that mibsolution.one, one working.
Mib 1 maps update.
I did post up how to get the mib1 standard maps working over on one of those threads with the 2024 (mib1) maps hosted on mib one solutions. I did dig someone out of a hole and on the SeatCupra site where they had deleted the contents of the mib1 card. A few Googles and it's possible to get the partnumber off that you need for the workaround. We know it works on Seat's and Skodas, think VWs as well. Basically "recent" maps are still in production but not freely distributed. If you find that post you can do it. Basically the normal, people don't back up the map before deleting the contents. In the days of these updates for VW and Skoda this was fine. Seat it wasn't, probably Audi as well.
Further to that I enquired whether they had the engine on during the door open period, just ignition was the answer. I think you don't need ignition just either the door kept open or open and close it at 15 minute intervals. The last one how I do for mib2 high. Needs someone to experiment, I don't have a Mib3 unit. Just gives it a cleansweep of processing rather than roll back and restart positions.
Yes that's it, then you have to troubleshoot. That's where the LED activity pen drive come in since they flicker although not everyone uses them and get it to work. Luxury touch. If it doesn't work then the issues fall into - Not presented correctly in the direction structure. One level down in the route etc, has to be at the top, see the PDF. - if using a MAC then CleanMyDrive will be required to remove MAC garbage - no work to be done if the installed release is above the file release (that comes up a few times now with connected services as people try to update but they are ahead of the file release). Installed release is on the infotainment information screen YY.MM and you cross check with MartiniBs designation. If using the Skoda, VW and Seat download web files they may be older than currently installed in the unit. Basically the unit does a signature integrity check on the file presented before setting about the update. If it fails it won't tell you. For mib3 and mib2 high it is impossible to edit, re save or change the contents of the file and to proceed with installation. Why any poking about in the files must be quited and the use of a MAC without CleanMyDrive or similar will lead to issues. The first only the technically minded would do that. On the second MAC users not technically minded fall into that trap but it is flagged up in the VAG pdfs. Old chestnut with MAC users and mib2 high, now carried across to mib3. Having passed the signature integrity check it next looks at, is there work to be done. Current release in the unit verses release presented, if it is an update then it will start the update using rollback restart positions the same as the mib2 high does. That is where it can take a time unless you keep power onto the unit with the ignition off once the update has started, door opened at 15 min intervals or door open... least that is the method I believe will fool it to keep the update going. I've been told the door open method works in a gated community where the update was left running. Took 40 minutes. Normal car use can take several days, depends on what normal is.
Post 1 over here I posted all the MIB3 navigation PDFs for the three brands. All the same. https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib3-satnav-offline.472408/ You notice the engine must be running to kick it off then the process can run for a period... like days. I think you can turn the engine off and leave the door open or open it at 15 minute intervals. You may then get it in 40 minutes 🤨. Basically the process uses restore points so if it doesn't finish it rolls backs to a restart point. Use of the car can lead to varying times for it to do it, type of USB etc. If you can do the clear run at it. Although I've suggested the 15 minute x 3 trick and the door open... someone did the door open trick and did it in 40 mins... not a couple of days. So yes my current belief is for mib3 once kicked off the real processing is when the engine is turned off in that 20 min power down, engine on when doing it, it's multiprocessing. Well that's my theory. Clear as mud. VAG just say leave the USB in... and it will only update is there is work to do. Current release on your infotainment system must be < the this release. Currently 24.6. I think people do poke at the menu or see the file picked up. Seat users like a USB with a flashing LED so they can see data activity. There have been issues with USB A to C adapters that are not compatible with data. Probably cheap Chinese imports. You get the MAC issue where you have to use CleanMyDrive since that will fail the signature check. You do also need to place these files carefully in the route directory.
OK sorted that VW link which VW people are getting pointed to is older than the Skoda files: The all important file was missing when I used 7zip to unzip the TAR files. The built in explorer gave us \MIB31_EU.ROOT\3D So we could use the @c34 magic on it... take away use the built in Windows Exporer but I reckon only @MartiniB and a few will be doing this checking.
I was going to give you the VW link https://navigation-maps.volkswagen.com/vw-maps/EUR_12PR119_FCT3WS-23131_Offline_Update.tar Using the @c34 method... I need a youngsters again🤣, I can't find that bit in the file to read YY.MM. That would be the cross check of the VW file verses the Skoda Still we got the Skoda one working now but a worked example to where that is in the VW file would be useful.
