Tell
Everything posted by Tell
  1. SWDL on this one at 1:32 that's a demonstration of the selective update. That I reckon will get you out of the issue. You do it with the map on the SD card he's doing it with a firmware update. It does either but we want to do map update from the backend which is what SWDL gives you. Remember to keep power on else it forgets every thing it's done in the session, doesn't pick up from where it left off unlike the normal map update.
  2. This is what a mib1 high columbus looks like Not saying you should follow those instructions since MartiniB has posted the files up. Normally if you Google the part number of the infotainment you can determine whether mib2 high or mib1 high. This unit has the carousel that got changed to tiles in mib2 high although you can have the carousel as optional. So if you are seeing the menu as tiles it's definitely a mib2 high.
  3. Is it not a mib2 high ?. I pass on mib1 highs.... If it is that you managed to get that map in it. SWDL menu I am trying to get you to use if it's a mib1, it never needed enabling on mib1 highs, it was pre-enabled. Mib2 high they made you enable before you can use it. Once enabled a long hold on the menu button should show you a menu with SWDL on it. It's that with the map card in the slop will get you out of difficulties. FEC List.pdf
  4. You have to hang onto the menu button till it opens the second menu as per above. It did take 24 hours or so for the developers menu to appear once enabled. Think it builds extra code or something. Once built you can always bring it up and you will see SWDL. That you use with either the door open for 45 minutes of map update or open and close it every 15 minutes. Give you a spare 5 minutes grace. Thats a manual update, you can go to old maps or new maps forcing an update. I suggest you force the 23-24 maps in. If you get them back try with the VW file for 24 or just try that. The menu says start or something which is the normal update or you press start manual download which is the selective update. You'll get the idea. You can dive up and down on the manual update. Either way the screen tell you what is possible to update.
  5. Pcbbc had said he wasn't going to do it right up on the thread. Too much to change so no change there. I guess Ozzie folk had looked it as well. It's legacy now unless Audi bring out some map reverting to HereMaps. Basically, the maps will be frozen in time now at V12 if you want Inrix for the UK and V18 without TMC in the UK. V12 is pretty adequate as you move away from 2024 both maps will age....
  6. Why I'd written off the question off as a mib2 standard one, mib2 standard hasn't been updated since June 2023 so it's reached the end of the road and anything after V12 is as Pcbbc says above. Basically you got to run with old maps on a mib2 standard either way unless like that mib1 map Vag release an update is found by Russian boards (that one always used Here Maps). You would only be in luck on that if they reverted to Here Maps cartography on mib2 standard not the TomTom one. I suspect Vags TomTom cartography contract is dead whilst they have a Here Maps one which is what mib1, mib2 high and mib3 use. Why updates stopped a year or so earlier than we would expect on the 5 year rule (map contract). Skoda as we know runs 6 months late so their November 2023 release was actually the June 2023 release (old). For mib2 standard if you want Inrix on latest maps you got to hope Vag has a business case to dig out their old Here Maps mib2 standard code for producing these / the agents they use for turning this around. I doubt it's going to happen unless there is a fleet of vehicles that need these maps. Probably committed Skoda users that think only Skoda maps should be used haven't twigged the end of the road has been reached for mib2 standard maps... They will in June 2024 when no maps are released on the Skoda website 😉... 2110 V18 is the last release ever as things stand. V12 is the last one that you can get Inrix to work on as per the thread. It's remote that you'll see any new mib2 standard maps let alone with Inrix unless Vag has a business case to produce them and they revert cartography and dig out their old programs. We might be surprised... You never know. It's a wait and see, in the meantime modded V12 to get Inrix on mib2 standard... Basically what they found in Australia where they were customising Vag maps to work with their local TMC provider. The jump back to old maps came from them. It was perfected by Bigade1 / Pcbbc for UK Inrix to make it an easy task home task to do.
  7. Is that mib3 you mean. It's over the air on connect services 4g, so no. Mib1 and 2 solutions as posted.
  8. Well the map updates go for 5 years after they change mib, so that puts it at 2030 for the current mib3. Firmware in the pre face lifted tends to get updates for about year after they finish. The question with post 2025 cars is how much of the firmware and files goes across into the next range. Could be shorter than we think.
  9. "Fee based traffic information" in Obdeleven. 14 is the group that holds Inrix. 15 is the one that holds Traffic Master in mib2 high non connected. I didn't say traffic master group @pcbbc !. The Id's are bundled into those groups. I'm expert on classification and grouping 😉. The traffic channels are grouped for marketting purposes for the infotainment providers associated with the car brand. Some go one way some go the other way. Traffic Master pulling out put a hole in the UK TMC service. The approach here to the fix was the same as the Australian Vag imports...
  10. Yes it was the TMC group that Vag used which had Traffic Master in it which pulled out of the UK but Inrix the other provider continues in a different group. Pcbbc sorted out mib2 high (mib1 solution dropped out of that) and mib2 standard excluding VW Discovery Media Bigade1 got that working and Pcbbc then improved it by taking out the need for recoding it: Mib2 standard here it can't be a Delphi: https://www.briskoda.net/forums/topic/512443-tmc-traffic-events-no-longer-being-receivedfirmware-update-required/?do=findComment&comment=5778623 Mib1 standard / high, Mib2 high: Just that code change dependent on what's in it. If its xxxxx then make it 32782. All mib1s go to 14 as mib2 highs without connect services. I did a write up on the SeatCupra board which covers the Vag models. Since I have edit privileges there I can perfect posts 😍. Mib2 standard: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-136#post-5037297 Mib2 high + Mib1: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-136#post-5035425 In short Vag won't be recalling these cars for this change they would have to pay Inrix. It's a DIY task or use someone to code it. A list of hobbyist Skodas is on the thread. Really for mib1 and mib2 high. Mib2 standard is like doing a map update but copying a few more segments that Pcbbc wrote. You can do that yourself if basic PC skills.
  11. & working today.... these satnav companies trying to make a buck out of what is free. 👌
  12. Yes some of these suppliers will spin any yarn. They probably didn't want the work. It's a roll your sleeves up and do it yourself thing or find someone trust worthy to do it.
  13. Ah possible. On the thread it was said mib1 here but I wasn't totally clear whether mib1 standard or mib1 high. Back on the Seat side a new Audi map for mib1 has dropped as the youngsters say so I got them to test out the 14 TMC group whilst they were updating to 2023 maps. Yes with VCDS / OBDELEVEN that standard coding group fix works.. . as muttered on the thread. Link here since I reckon some nifty map update can be made to breath new life into old mib1 maps as well as Inrix on these unit, mib1 map update here: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-138#post-5050968 Confirmation that recoding 15 to 14 works here for Inrix on mib1: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-139#post-5051436 I pass on the Skoda map update procedure for mib1 but you can put the newer contents on a 16gb mib2 card... we had established that on the thread. Seat Mapcare for mib1 procedure is covered... Skoda I pass on but you can either way recode the TMC group from 15 to 14. That's another Audi map that is interchangeable... we like that. re reading I'd try the simple code change 15 to 14 first with a reboot. The update does indeed work on a Discovery Media from this... badically its @MartiniB list extended on but not made available by VW / Skoda or Seat.
  14. 370 Done a comparison now of the Google Drive one and http://map.audi-mib.ru/ If you remove the two Russian files they put in above which don't have a bearing, the contents of the files are identical with the CRC check (basically a data fingerprint check of the contents for being identical): Always good to know 👍. Google drive if it's not overloaded is faster but failing that the Mega link with the VPN tricks once time is up if you don't subscribe.
  15. Yes and if the infotainment unit is really stuffed and won't work with that VW file then get SWDL enabled and force an update with that VW file. I say that since if it thinks it's got the update it won't update again to a file that works. That's my thinking. I have reversed map updates using SWDL when I've been experimenting, its a feature it's got other people out of difficulties in the past with software updates. Normal onscreen built in "update" will only go one way, "upwards"... useful tool to enable when having issues. You do need to run it with the door open or open and close it every 15 minutes till finished, stops power down else you have to start the process again. Why I posted up those screens. There is a manual / automatic toggle you can dance around to selectively update specific entities of updates. Don't forget CleanMyDrive on the SD card if using a recent Mac else the garbage in the files left will trip the SLA1 signature check and won't see an update. That's the VW recommendation. Does come up from time to time with Mac users. Pass on what Mojave does on a Mac... 😑.
  16. Once Google lets me download it I'll check it against the other site which is what I was trying to do with the Mibsolutions one but they were corrupted in the zip file. The Mibsolutions ones, had the creation date in them back in November whilst the http://map.audi-mib.ru/ have it as February. The ones I used. Was planning to delve deeper just to see whether it was exactly the same material, less the two Russian advert files. Basically, you can see what the site did installed it and re-zipped it... good to check. I see zloybob is said to have a hand in these files. Here we go https://www.drive2.ru/l/668834848395250015/ More links 🤣. Background info. Same person as the stripped down 350 Mib2 high early release. Feels about right as I said before freeze date of the map files six months before release but they have mastered quicker turnround which is why we see them now but not officially.
  17. Google drive or Mega ?. Did I miss something . Funny the RoW just covered America's, wonder if it's normal for the cut down Audi file ?.
  18. As for the source of the EU file I'd use the Russian one you gave me: http://map.audi-mib.ru/ Direct link: https://mega.nz/file/0rE1gABD#lcfr9fv0VigKTavqe6ty-T3NJUGPzWdkrmDKShrdYjs The Mibsolution one is more problematic, the file has a zip error in it. The link above is fine, and you can use three different IPs addresses to get it down with the screen refresh and a VPN 😍. BTW these Audi originated maps are filed with the FeC key that take you to that release in the file name... the decode is here: https://www.drive2.ru/l/631572674207817537/ I wondered why 02300036 had been added to the filename. It's the up to that code if you have Mapcare. With lifelong FeCs you are OK. If Audi did the dirty and removed Skoda, VW and Seat from these files you can add the Audi FeCs for sure. I know this since it was discovered with Seat. They are cross compatible. I've got the Skoda long life FeC on my car as well as the Seat one. It came up on one release where Seat had been dropped.
  19. No I don't.... but thanks. If you are playing CDs?. The graphics art I always do in FLAC file using the 500x500 cover art in each directory. Anyhow, the more reliable 376 will be the RoW NAR 2024-25 file link is https://mega.nz/file/SEhSCZTA#T8qGZbNC45wEFu0wf36clM3NVP84VDv_UjZ5dUWmur0 That goes straight into Mega then you can deploy your VPN tricks every time. I use Edge for that and TunnelBear. The Mibsolution link kept failing so went to the direct link they published. Haven't tested it thou but it does unpack... BUT saying that I reckon it's for North and South America only. I wouldn't bother with it in Australia or NZ. The attributes are for the Americas only
  20. We press cancel and it comes out... with a reboot Final stage... Then done. It allows you to revert map updates and revert software updates. Has it's uses.
  21. You get the option of manual update or do all. You can dance about the screen as to which you want to load in. In this example do all. Off it goes but you must keep the car door open or open and close it every 15 minutes to stop power down, you don't need the engine running. Looking at 40 minutes at this stage. Progressing: Means looking good:
  22. SWDL screen example. Once the developers menu of the infotainment has been enabled via VCDS or Obdeleven a long hold on the menu button brings up the menu with the FeCs on it, keep holding till you see this: Then you hit SWDL with the map update in the slot: Tap SD card. Tap the panel above. It then shows navigation entities that can be updated. Y means it can be done.
  23. PS 376 will be the RoW NAR 2024-25 on mibsolutions guest, guest for those down under to try out.... report back. You have to get the metafile in the route and the mib1 and mib2. Normal position. The 370 Russian link had them down a level or two, just drag and drop them as documented in Vag pdf of how to do it. https://mibsolution.one/#/1/15/MHIG - MHI2(Q)
  24. Here we go ECE 370 2024/2025 Mib2 high: I use the Russian link you gave me @BooBoo124 as above taking the second link in the page: http://map.audi-mib.ru/ Namely the Mega link for release 370 not Yandex that needed Russian mobile number. The Mega hint if you don't have a paid bandwidth is to use a VPN. Every time it says you have exceeded your allowance or wait 5hr, change IP address and hit refresh 😉 . The file has two links at the top to promote their web site. Ignore them. The materiel is signed with an SLA1 signature so can't be edited unless you are a member of five eyes on something so it's not modded and cant be from when it was sewn up by the manufacturers. We dont have to worry about that. The file has grown by 0.2gb from the last release. I did check some areas before and after and indeed this is an update to the geography. Got more roads in it. As mused I reckon with connect services they probably got production down to a fine art so this one is laying about from the freeze cut off in November. I've seen November named else where for this probably based on the mibsolution link. Dates are when they wrote this to the file, not Audi on this. This would normally ship in June 2024. The Russian page says next update December. Think they have their maths wrong. December if official but they will get it September 🤣. I'll be using this. Did the demo navigation run, fine. Inrix TMC works fine. No issues.
  25. And any one who can activate the developers menu to get SWDL for you over there. There have been other Australians over there with it working on the thread but guess the one that got stuck part the way through needs unsticking with SWDL. I suspect it was a faulty file created by Skoda / VW on the link where I said use the other one but has got stuck part in. There were issues on the European one on file creation but since the EU people are more in number than RoW... It didn't get fixed. You need the backend menu to do a re-install. (SWDL I'll be running here tomorrow on the June 2024 supposed EU release... since I know I can get back if there are issues). If you do get the map installed, select a destination and shows maps for 30 seconds then tells you its not valid, then that is your FeCs... been there, done that, since its a Skoda it won't be that. Just got some corrupted data in it that faulted it. It's corrupted in manufacture of the files not in the processing of it at your end since the files are signed. They will only get read if they presented correctly, clean my drives etc. Once they start being read if it throws up an error then it's the manufacturing of the download... that was the issue on the first EU ones, Skoda.
