Tell
Everything posted by Tell
  1. That was prior to mib3. Mib3 they removed the radio logo import adhoc option. The updates have to be via authorised (signed files) you can mess with in mib3/4.
  2. Mind you I think you will be unlucky from 350 on I reckon the Audi sourced files were released in mib2 high only http://map.audi-mib.ru/ This concurs with the 350 release coming out early and then the 370 only in the stripped down mib2 high only form. VW, Skoda and Seat followed suite with 370 only in mib2 high format. 350 was the last that covered mib1 and mib2 highs in a combined file for VW, Skoda and Seat. It's possible that Audi may run off a mib1 high version of 370 but you'd have to keep a lookout for it. The mib1 standard file was un expected arrival in 2023 after it was thought that mib1 standard map updates had finished. Something similar may occur in the future. Never say never.
  3. Good question the 370 release on the Skoda and VW sites was stripped to Columbus 2 only hence it's smaller: Question is whether the 370 release is knocking about on Columbus 1 only ones. Going to be on one of the Russian sites if so. They are Audi files which were traditionally shipped in three different forms, combined and separated to Columbus 1 and 2. You can't edit these yourself since they are signed.
  4. Yes (although early in the morning) it's the same trick as the Seat one I linked to which restarted this all off on the SeatCupra forum. Basically the units is hardwired via the software to the release as defined by the parameters that are given on the original card for PartNumber1="original field here" PartNumber="original field here" You edit in that original field for the two parameters and hack about the maps to fit 8gb original card or buy the newer mib2 card, 16gb to avoid the hacking but you still need to do the field edit. Back in 2016 or so people were hacking around these fields on Seat cars without mapcare that they never had, a small proportion got it to work but we never got down to the bottom of how they did it. Then the scent went dead. It must be newer firmware at the time and getting that edit correct. For Skoda if they had mapcare on them for life which I assume they did on the units, life must have died as far as using the newer files but the edit restores it. Those seriel numbers must be a predefined range of allowed up dates. Go out of that range and it can't be done but edit in the original parameters and you are fine. That edit would be new to Skoda users but not to a small band of diehard Seat users that never had mapcare. For UK people you can get the TMC working again as well with vcds / Obdeleven by just changing the tmc group from 15 to 14 (thats the mib2 high edit that works for mib1 standard and mib1 highs). We also established that if you haven't done it. That gets the car working with 2023 maps and TMC as delivered. This forum led with that one. I asked mib1 users whether that edit worked. Only for mib1 standard / high (Amer whats it and Columbus units), mib2 standard and it's editing the card and files and old maps. That's elsewhere on the board here.
  5. If you look at the Seat post I linked to you can see what they did. There are a number of posts where it's discussed. The cleanest approach is to just buy the 16gb MIB2 map card. The CID is recognized. Also when swapping cards you have to force a reboot into it. The long hold on on/off else it won't re read the data on the card. If you sit outside with your laptop and the unit doesn't power down. Needs 20 minutes, it won't re-read the card. So yes keep the existing card with the old maps on and copy the 106 image to a mib2 card. Any old cheap one will do off ebay. You just need the space of 16gb and the VAG CID on it.
  6. Could be 490 that is being talked about here.... you really need somebody who has done that map update on a Skoda unless it's only been done on Seats. @varooom just in case.
  7. If it's space you can buy a 16GB Mib2 VAG card and it will work if that's the problem. In Seat they have done both hacked the map down and some bought a replacement mib2 map card as I'd suggested since we knew they were compatible. However on Seat it seems you do need the Seat firmware update 0480. Also because of mapcare on Seats you do need to do a bit of editing to carry across your old map identity to frig it to work. It goes like this: >> I downloaded the P106_N60S3MIBS2_EU_NT (8V0060866S).7z from https://mibsolution.one/#/1. Extracted it to my HDD. I then removed a few files in the markets/eu/map/MapRegions folder. Ukraine and turkey stuff if I remember correctly, this made the files fit on the original card. Modified the DbInfo.txt by copying the original one from my map car and changing the last 2 lines to ApplicationSoftwareVersionNumber="0106" SystemName=" ECE 2023 " from the new map file. I then copied the contents of the original card to my HDD. << Resource of Seat and Mib1 and Mib2 https://www.seatcupra.net/forums/resources/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.60/ It could be for Skoda mib1 there is some similar Skoda 0480 firmware that makes it work. Retrofitters have described the Seat one as "European" which might be code for it's been modded. Seat European boards were using P106_N60S3MIBS2_EU_NT with the text edit and 480 Seat firmware. Those that didn't want to buy a new Mib2 card for mib1 use just did the contents hack + edit 480. Do't reckon it works without the 480. Haven't come across any that have it working without the firmware update. It's a bit like witchcraft since few people back in 2016 or so with mib1 standard managed to do Seat map card updates as DIY. They ended up out of pocket. All had gone quite till that 106 release came along and across Seat boards it was found it was possible. It could be that Skoda just needs that text edit and not a firmware change. It is an Audi map update so that firmware plus the edits could be the special sauce. The mib enthusiasts may know. This post brought the Seat Mib1 updates back to life in the UK although earlier in the year a retrofitter for offering to it for a cost https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-138#post-5050968 The board link to European Seat success is given in that. It's been replicated.
  8. The 350 will if it's still live. On the tablet so can't check. Any of the files with 350 on them whatever the brand for Europe, they are all interchangeable between brands. All the same file.
  9. Currently you need to go back to the 350 release if you want a mib1 high compatible release. Eg. The November 2023 release. Audi always released these files split into two forms whilst the rest of the Vag group released as a combined file. Mib solutions site goes up and down so I can't check whether they have layed their hands on a mib1 370 only version, what they had earlier posted was the 370 mib2 high version the same as the one Russian sites had in February. That early version atleast for the UK didn't change as far as the data was concerned from the VW mib2 high only one. If you had a Mib2 high you could have happily used that as I did. It's possible the 370 mib1 high only one is leaked out from Russian sites that find this stuff but failing that you will have to make do with the 350 only combined release. The Audi site behind a Audi VIN paywall may hold a mib1 high version for 370 or they may have just dropped production. That may be the case given VW are only releasing the file in 370 mib2 high version. Where you hit Google looking for mib1 high 370. Failing that MartiniBs back post providing the 350 link I suspect will still index into a version.
  10. How does that compare with MartiniBs pinned file for 2024. VW one. You'd have to load it up. https://www.briskoda.net/forums/topic/513799-mib3-map-updates-2024/ I guess if it updates it's newer. Not sure whether we are with the June 2024 release. You'd have to register with VW and check. I don't think MartiniB has posted those up yet if a newer one has arrived. I'm waiting for a clever spark to publish how you derive the YY.MM in mib3 files. It's buried in Hex so a simple scan of the files doesn't show the date code.
  11. Ah but if you think the Skoda files have secret sauce 😉
  12. They often fail on zipping them. Us mere mortals use 7zip they probably use some Linux Library and make a pigs ear of it. The same output is given to the brands which is designed to be used across the brands... just not zipped. That's when they make a pigs ear of it in the final stage of putting it on their servers.
  13. I'm told that the Vag mothership controls all upgrading of Vag audio systems so you can't obd code different systems in. That's East Yorkshire Retrofit that says that and can code at the mothership level. It's that VAG have pinned down user upgrading via VCDS /OBD coding. That was true of mib2. Microcoding that goes into the chipset rather than setting flags in Obd. I was pulled up on that one once. Us Seat moderators get corrected. It is true you see the files used. It's a nitch area to retrofit mib audio systems varying from what was fitted. Miss builds you either reject the car or get a discount deal by holding out. I got 3 years free service after they misbuilt without a wireless charger.
  14. I'd try to use VW versions where possible. Better resourced. Think now we are on hold till November all mib2 maps are now out.
  15. Further: The DBinfo file PartNumber1="V03959802TS" PartNumber2="V03959821CG" PartNumber3="V03959820ML" PartNumber4="V03959806CB" PartNumber7="V03959804FB" PartNumber5="V03959804QL" ApplicationSoftwareVersionNumber="0350" SystemName="ECE 2024 " Variant="ECE" ReleaseName="2024" DevVersion="P350_N60S5MIBH3_EU_NT_Q1.23" The one interesting thing about it: HIGH12_P350_EU_202345.zip\skoda_all_in_one\Mib2\NavDB\DBInfo\0\default That's a recognition that there are streams on the release and this is the big one covering mib1 and mib2 high whilst the pinned thread is just mib2 high only.
  16. That is the old 350. This thread. See what MartiniB reckons. Using my collection of Skoda VINs 🤣. Not 370 - see MartiniB's new pinned thread if you want the latest June 2024 release.
  17. Reversible ones like that are better since adaptors may be not fully wired for usb3. That has come up on Briskoda and Seat sites. There is an issue of what navigation FeC the car has installed. If it an import from the EU as a second hand it may be set up with a European FeC than a RoW FeC. That's how mib2 high worked which essentially is how mib3 works. This is where I say photograph the same car with navigation that works in the country against your import. Study the FeCs and Google. I dont think there are any DIY solutions to changing them yourself as mib2 high.
  18. You just use the latest map that is released which unzip correctly whether on one of MartiniBs found web link or website wrapped by one of the Vag brands. They are all the same files. It's like a library. New books come in but are put at the back waiting for a cover and card folder put in - old talk. In terms of release, the Vag website puts these out in June / November of each year. You can always wait for the brands release or just get it out from the backroom, the file server. MartininB lists are the direct fileserver links, you don't have to wait for the librarian, in this case the web site author to wrap the page around it. It's just map production from the cartography companies via an intermediate to get it in a form to upload into the car. Skoda seems more prone to zip errors where there programs fail. VW tend to be the gold standard, so first call of choice of map file. Better resourced. 7zip is the recommended unzip free program. Vag recommends it although Windows 10 / 11 now have unzipping programmes built into the file managers which will unzip the file without the user knowing its been unzipped. They tend to work well. Zip and 7zip are the two file type extensions you see on map files. Windows file managers have been extended to seamlessly see 7zip files of recent. As for timeliness, Skoda lost a 6 month period about three years ago so they always lagged behind VW. You were better off using VW files rather than Skoda. Production delays in VW files for release in November 2023 on mib2 standard have led to a time slip on VW files. The November 2023 VW release came out on the file servers in March 2024. Wrapped in a webpage now. That probably means they have scrapped what would have been the March release so the next release will be November 2024. Us people in the know took the March 2024 release off the filestore. We wait to see the November release later in the year. German Skoda websites also carry these links but are slower to find them and put them up. More time squabbling with each other 🤣. They are a useful read to cross check what they have. The Russian sites find the raw files not linked to file servers not in their links. They are Audi files, part of the Vag brand, but these get published as the files dumped in other areas not linked to Vag file servers except they have been copied from them. Mibsolution.one carry some of these files or links. It varies, a hobbyist operation.
  19. BTW. No issues with auto zoom in this release put it in demo mode and worked fine.
  20. You haven't found out how to read the mm.yy in those files yet. Somebody probably has but I haven't seen it yet. That way you could rank the different releases between brands.
  21. Yes these slimmed down mib2 high only versions were the preserve of Audi drivers only that got them on the paid mapcare subscription behind a pay wall previously. @pcbbc was familiar with them. The versions released on Skoda, VW and Seat were the combined mib 1/2 high release where they could be used in either unit. This release drops the mib1 high support but you must present all folders to the unit. The programmers have called the directionarys mib1 and mib2 but it needs both, just they got a rubbish directory naming convention. We had already seen a few months back the mib2 high only release of 370 in the Audi form curtesy of Russians boards and mibsolution.one. This file appears to be identical to that one except it has some additional checksums in it. The ones with the additional checksums are by country. I only checked the UK on these which demonstrated the early release of 370 was the same as this 370 for the UK once you ignored the additional checksums. VW must use a different way of manufacturing these files from the source materiel with more checksums or they changed their processes if it all comes from the same place. The main thing is not to get excited by the drop in file size. It's fine it's for mib2 highs only. Columbus, Seat Plus and Discover Pro and those Audi mib2 highs. Present all files as you have always done. You can use a Mac but you must use CleanMydrive to remove the Mac file garbage off the drive once copied before putting it in the unit else it will fail the integrity signature check.
  22. You want it on auto zoom. You have probably toggled it off or it's come up that way. Auto zoom is when a box is drawn around the button that shows in your case metrics or imperial in the UK. This is the Seat version of the mib2 layout. In this case you see 100yd with that ruler marking. Tap that box. It causes auto zoom to go on. Box round it, its in, no box it's off. Reckon that's it. Auto zoom and it should work fine. I've been using the Audi version of 370 for several months. My real test is Tuesday. But I reckon that's your issue. Normally. Set destination then tap to auto zoom. I always use 3D and the split screen on. Off in this photo. Hmm think you meant mib2 BTW. Not sure what would happen if you managed to load this file onto a mib1 high unit. You'd expect it to reject it. If that's the issue you'd have to use SWDL to force the old 350 into the unit. BTW you don't need to drive around to test auto zoom. You can put the unit into demo mode, under advanced setting or similar name. Select a destination and it will start a demonstration mock drive if it's a mib2 high atleast. It should do the zooms.
  23. And lastly @MartiniB I installed over the Audi release, you have to use SWDL manual download, start and select all and start to do that. Result success screen: Ofcourse if you were on 350 you'd install as you normally do. Since I already had 370 installed and it had said, yes you got it, for the hell of it and to respond to a question about whether 3D mapping was still in it, yes it is. Failed comparison someone had done between the combined normal mib1/2 high files as the mib2 high only one. So yes I reckon you can make a new thread.
  24. Think you might find the dab aerial wire in the rear glass. People in the past have broken the connection by vigorous cleaning. The other one you could check is whether you got it set to auto select region or something. This is where you are happy for it to switch between similar stations. If you have it toggled as no then you can end up on one that you loose and fades in and out. Commercial stations don't always have the best coverage as the BBC so if an LBC News hound say you may find it drops away as you go down a dip since there are no fill in stations. Happens in rural parts whilst the BBC stations are rock solid.
