Tell
Everything posted by Tell
  1. I pointed you to this release of the maps which would appear to be the correct release for the unit. If you check North Africa isn't on the maps. There may be a chance that some of North Africa is in the maps and the documentation is not correct. "Herewego" app shows what is in the Here Map cartography database but of course this may not be used by the developers that generate the final files for VAG. You wont know this until the maps are loaded up. You could ask a board that uses ROW to look at North Africa. That link above is used mostly for European users. So this link you are posting on is for the wrong map series. Suggest you ask on an Australian Audi board before you embark on changing anything. The mib helper web site is developed by enthusiasts as documentation, you really need an enthusiast Audi board where you can ask for assistance. The ROW navigation FeC is critical to get the unit working. Thus you can chase down the other Columbus link similar to the one above where I had the previous conversation. A set of button pushed will show your current FeCs you see whether the mib2 high RoW navigation FeC on yours is a life long navigation FeC. Import units may well be the European FeC. A check will reveal. As I said I did help a past Australian with an import unit get there unit on RoW. It is all on this board but shown under a different period release of the Columbus maps. Another Audi owner that popped up here. Either way the work is technical and you are dealing with high value units which you can mess up.
  2. If it's really a mib2 high you need the other link to the Columbus. ROW, then you need the FeC update and you have to use mib tools to update the FeC for the Row. Conversation on a previous release I had with an Australian. It's Audi navigation FeC that stop you from updating the maps same as Seat one's on the mib2 high. Assuming it's really a mib2 high. Read back posts of the release. The mib tool will sort this out but out of the box gives you European FeCs. You edit in the RoW FeC and update. Then load maps.
  3. Have you got North African maps already ?. You take a copy of what you have as a fall back and try. If it's a mib2 standard Audi it may use a type of mapcare. The Seat workaround may work. I've never heard of it being used on Audi. Skoda and VW don't need it since they were kind to customers. Audi aren't so. If you have a European unit and you want non European maps and it's a mib2 standard then the link may help. Either way you must back up any official SD cards so you can recover from any experiments. Some joint working between Seat and the VW Transporter board got European import VAG cars working outside Europe and US VW import to Europe working on European maps. Esoteric once you deploy the Seat workaround which you needed on VWs at this level. More uptodate units became more fussy with the original T6 transporter method. Think they were mib2.5. https://www.seatcupra.net/forums/resources/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-lost-mib1-card-solution.60/
  4. Yes I think that's the stumbling block Skoda will get you if you were to retrofit a unit since you'd need a valid VIN for it.... all fun.
  5. Reckon thats pretty old. I believe the series trains are similar between Skoda and Seat. Tiles came after... ? Or whatever the youngsters want 😍.
  6. Oops got that backwards... If 15 going to be 14 to get it to work. 5 character then it's the 5 characters 32782 . There was one post where a unit was different to pcbbc starting point.
  7. You'd fumble the menus looking for Wi-Fi is how you know the difference but as you say there will be a part number. I think the firmware will be the same once they released the unit. Seat has no special firmware for the Wi-Fi units with mib2. So it must be wrapped up in the software. My guess is they progressed on to a train where it covers both types of units, the original and the Wi-Fi enabled one's. May be Skoda is different. Its the 5 series or 4 series train for Seat when I believe Wi-Fi arrived to some of the units. They were shipping both. The Karoq of Joek666 like the Ateca will have had it. Later Leon3 got them. They were really designed to support connected services and those experiments they did on integration to apps. Might be useful or not if you have VCDS / Obdeleven: https://forums.ross-tech.com/index.php?threads/10862/ I suspect there isn't a chipset doing nothing that just needs turning on. Our Arona 2018 has a mib2 standard without wifi, same time period they were fitting the wifi units into the upper end cars. Mib2 high in my Ateca when you could specify what you wanted as an option.
  8. Yes that's pcbbc to thank for cracking that one... you need to do the one here. Get the guy to peak at the current tmc code and change Some units have a slightly different 5 digit starting off point but you finish with the one shown. If 14, it's going to be 15. Save and reboot.
  9. Vag introduced a mib2 standard Wi-Fi enable one. Probably that I reckon. The base unit and the fancy one that came later. Wasn't fitted to all Seats. So yes it will be the Wi-Fi flavour standard one with matching firmware. Created chaos with POI import programs which people had written since nobody knew the ID code the firmware used when running the scripts to bring in the POIs. That code was in the firmware updates. Those were the Wi-Fi standard mib2 one's.
  10. I have an EE pre loaded annual 120gb data SIM from Amazon £50 stuffed in my tablet. Slight overkill for the tablet. No sign up, just pop it in. £28 is their lower cost options for 6gb. EE flog the data off via these data SIMs but don't really publish it. Connected services never came to Seat mib2 standard. Mib2 high was experimental with connected services and they pulled the plug on the app. When Seat were testing their app writing skills. Alex and Google maps integration. 1gb app. You needed to use a hot spot and early mib2 high on Seat were missing the menu option to put the unit it in the right mode. They were shipped in hot spot mode but no data SIM slot in the unit. Again VCDS / coding to unlock that menu. Mib3 a fair few people come out of data contracts and use alternative for data but the connected services. That Spanish company they use for data. Slow data speeds.
  11. That bit is identical to obdeleven Press the button “5F Information Electr.” Press the button “Adaptation - 10” In the “search” box type “TMC” Then type in and save 😉
  12. 2016 that would be a mib2 high. The later would be sounds like mib1 high. Before my time. Mib2 maps you update with @MartiniB excellent links. 330 is the release. You need a 64gb standard SD card to be safe... gets marginal on 32gb. If using a Mac you need to use cleanmydrive after its on the SD else it will trip on the signature due to mac rubbish in the download. PCs are fine. That's the map. Then it's @pcbbcpost Horses for courses. If you want DIY you buy an https://obdeleven.com/en/home/62-pro-pack-0758277987813.html That's the black one works with Android or iOS. White one cheaper Android only. You can mix and match just the device and Pro license. Some people buy from Amazon on next day delivery then buy the Pro license online. Then once installed you do a scan. Then in to the 5f unit. Adaptions. Search TMC. Put the correct code in as per pcbbc, save long hold on green button of app. Reboot the unit. 10 second hold on, on / off. Job done. My example on the 14 code for mib2 highv
  13. Yes just look at their % approval score. Where my Skoda 32gb came from and I did make one using a so called Gold card for fun. Cheaper to buy a Vag card off ebay. Basically the CID on all Vag cards are interchangeable. How Vag makes money on sales of map cards.
  14. Didn't touch distributed control system till the Vag platform 😍.
  15. The 12 points Seat workaround above are with a valid VAG SD card ofcourse. They are not fussy whether it's VW, Skoda or Seat mib2 cards. You need that for the CID. So for a two card set up you need a second Vag card if the software isn't hacked to take any card using the toolbox mentioned. The Seat workaround you deploy if the map is later than the card (higher number). For those downgrading maps you wouldn't need to. Ie. If you had v11 card and a Seat you would need the workaround. V13 say you would not need it in that instance for V12 with the mods above.
  16. Two cards. Putting the fix to one side the standard unit isn't fixed to the card except on Seat where it's fixed to the release of the card except you can use the "workaround" to sort that out. The work around is this: Steps: Download the latest standard MIB2 maps on the infotainment go to settings, safely remove, sd1 card remove sd1 card from glove box slot long press on the on / off to reboot it a couple of times insert sd card in to computer copy and paste all contents to a directory on your computer Format the SD card keep it as fat32 and leave format settings as default in file explorer (don't forget to push the card lock mechanism to off) (ditto in a MAC or delete all from the SD card) Copy the new downloaded map version to the SD card (after unzipping it) Replace /maps/EEC/EEC_WLD/OVERALL.NDS on the SD CARD with the one from the original SD card eject the sd card (on a MAC run CleanMyDrive on the SD card - then eject) Inserted the card into the card 1 slot in glove box whilst infotainment is off power on and go to navigation Yet to be tested by me is whether you can do the @pcbbc / @bigade1 fix the overall.nds fix.... I'm away, I'm sure you can. I envisage that if you want to use the latest maps use one card, if you want TMC but old maps, the other card. We use the car with the mib2 standard in it as a rural run around. Single track roads... queues don't get on it. If heading on busy roads you might swap cards. For rural Wales think TMC doesn't add much. Hit the M4, the valleys and England TMC would come in handy. Hence the option of two card working. Not ideal. Best solution is with mib2 high. You need to code this yourself or get someone else too. Offers above. Any self respecting IT guy should be able to do it on the mib2 high. The car runs a distributed control system which VCDS / Obdeleven Pro acts to program each component part. 1970s computer thing. Now they call it DCS... that's the only thing that was changed in 50 years 😂. I remember our computer science lecturer getting excited about it and that other fangled thing of meshed computers 🤔 (Arcnet to become internet).... Not forgetting microcomputers. Punched cards, line printers, Teletype 45s and paper tape. Well if you can do that you can program your car.... without the punch cards 😉.
  17. Getting an alternative unit. People look at Android based products and I think Pioneer. The old mib1 chestnut solution. Not sure how good they are. The other solutions for DIY for mib2 are now out on the thread plus a working one for mib1.
  18. Seat mib2 standard guys have to stick with v12 this one and do your overall.nds business if they want TMC as posted by Pcbbc above under: MIB2STD 2020 Maps with TMC Update for Amundsen/Discover Media/Technisat here Seat guys DON'T forget the overall.nds file copy from your original map the unit is attached too. You need this since you haven't got the navigation life time FeC that VW and Skoda have. I haven't tested the process on a Seat since I'm away. I quess it works. The mib2 high whatever brand attached to it needs the TMC set via coding to 14 or the other code 32782 via VCDS or Oddeleven Pro as posted again by Pcbbc above. That's dependent on whether it has no online service 14 or online 32782. Peak a boo in the TMC coded set field 15->14 XXXXX-> 32782 We say XXXXX since some vary by brand within AVG. here 14 also works with mib1 reported here.
  19. Presume we can do the two card system then since the unit isn't modded. Use the old maps with TMC mod if you want TMC or latest maps without. Now just latest maps with TMC to go 😍. Well done all.
  20. We want all of this stuff if enthusiasts are going to crack taking mib3 maps and getting them into mib2 high maps for the day VAG pulls the plug on mib2 high maps. Need about 15 years on built in maps not 5 years. Where their support is woeful on products. A car will last 15 years, not 5 years as they plan, or less if you need TMC.
  21. Hopefully we'll get an answer that doesn't involve the toolbox and works with the latest version 🤔.
  22. Better not vanish in the next two weeks till I get home.
  23. Going to be the AS platform extended to V12 http://wiki.ross-tech.com/wiki/index.php/VW_Navigation_System_Maps#Platform_AS
  24. They normally twiddle them around in the naming so I reckon MartiniB will find them.
  25. Looking for v12 @MartiniBfor @bigade1special sauce above.
