Everything posted by Tell
- Columbus Map Update 2021 (MIB1/2 HIGH)
Columbus Map Update 2021-2022 (MIB1/2 HIGH)
Sure the navigation wasn't being jammed. Had that in Jordan close to the Syrian border. The satellite lock fell, open road, no hills, had to turn round and retrace so we didn't get lost. It then reconnected. Satellite navigation is illegal and jammed in Syria. Happened in Milton Keynes once, probably kids in that case. Mind you got thrown into the back of military 4x4 with machine gun on that trip. Didn't like where we were walking so got removed to the check point for passport inspection. Rolling around on the back of a 4x4 machine gun platform vehicle isn't comfortable. Passport and walking guide book inspected and we were driven back to our car. You wouldn't get there now in any case with the troubles.
Interesting project. I got a heated windscreen but it takes the signal off the roof aeriel. The Ateca's do that if a heated windscreen else the aerial is under the dash. Yes those older mib2 high units only have American GPS in them whilst the newer mib2 standards atleast have the full range including China but not the European system. My deduction from the number of satelites seen on these units and my tablet. I'm assuming it's not the rear aeriel interface to the unit. Put it down to the unit, not the interface. On your other issue there is calibration screen I've read about, haven't looked for it thou, since I get good lock on except after I tried to force 192 into it using an exploit of putting the input after a Poi input below the signatures. It's how they do mib tool via SD. Doesn't read other signatures if you take the metafilecheck out. Saying that it still stumbled on the read of common_eu. Think there is a limit to that technique in anycase that it may of hit, did open the navi uodate windows in swdl. Net effect the unit became a bit detached from the road, it corrected itself by retraining itself... a few kilometres of bends etc. Thankfully.
Non built in navigation bounces about with the GPS in towns putting you on neighbouring roads as built in navigation anchors the car to the road better as it calibrates the car to the map, mib2 high does that least once you have a big fiddling session of reloading maps. Will first put you off the map but will then calibrate the vehicle to the map as you drive, retains that calibration when you turn off. So you get continued registration of the vehicle to the road. Standalone systems don't have the same calibration routine, just GPS with a map overlay. You got that verses v timely traffic information. Ofcourse TSR warns you from speeding with road works and variable speed roads which Waze may not if it hadn't been entered. I use both as a navigator but only built in when driving.
- Columbus Map Update 2021-2022 (MIB1/2 HIGH)
Disappointed. That means whatever Vag / Seat were cooking up dates back six months to when the files were closed. Leaving their Mapcare customers high and dry. Retrofit solution(s) exist of reprogramming the unit. Side loading a technical app (Mib tool). Think they load up non Seat navigation FeCs in them and tinker with other things. Latter we know.... suppose we knew the other but never said what. Whether they all use one tool we know about or different, haven't got down to the bottom of it yet. There is modded firmware about which might be being used and sideloading Mib Tool on the other. Wonder if Seat will pay back the money they took for Mapcare from customers ?. Seat's stand on built in navigation continues to be weird. It leaves you to think there may not be parity with mib3 charging structure or services. They do a good job of shooting themselves in the foot.
- Amundsen Mib2 Map Updates 2022
Is that because earlier versions were operating some form of Mapcare which needs to be corrected or put another way never had Mapcare removed when VW and Skoda abandoned it. I know in Australia some VW units were shipped without Mapcare e.g. with fixed Mapcare on the build date so couldn t upgrade. People could go to dealers to get that fixed circa 2015. Mapcare operates by either having the navigation FeC set to the build date (quarter) so you dont effectively have it. With Mapcare but within period (future quarter of a specified year) or out of period, passed the valid quarter. Skoda FeC tables I've seen on mib2.5 didn't have a navigation FeC so concluded it was completely deleted from recent Skoda unit so that check isn't made. Audi and Seat mib2 runs with Mapcare, wasn't abandoned. Are there some Skoda mib2 highs (Columbus) that have Mapcare implemented on them which leads to user grief which slipped into a time period before Skoda abandoned Mapcare ?.
It's a dealer thing. They don't release them.... if you find one on the net they can brick your unit. If they are like Seat ones which they will be there are upgrade paths which you can follow but if you dont you have a problem. Haven't messed with mine. If it's a genuine fault then a dealer will do it. Users do it if there is some issue like Android Auto being problematic then if the user community finds a reliable one online which is the original and not modded you can if it's designed as a valid upgraded that's straight forward and doesn't require VCDS / ODIS. Suspect if it's a Mapcare thing around an old unit that got missed out its a dealer thing. Will post my question to the Skoda expert.
Not using a Mac are you ?. An integrity check is made on the files for transmission errors and any fiddling within the files. The Mac operating system adds additional rubbish to the files which is why you are suppose to use CleanMydrive and the recommended MAC OS unzipping program, ditto a PC 7zip for unzipping. Other PC unzipping programs can lead to problems. In the route of media you have the metainfo2.txt file, mib1 and mib2 directories. Attached is the VW guidance. See Mac OS guidance if using a Mac. If still no success you could always download the files again to the HD. Unzip to the HD with 7 zip if a PC. Then drag and drop to your SD card which is blank. People sometimes manage to get them not in the route. Need to be in the route. Since its telling you there is a problem with the metainfo2.txt file it means the files are corrupted or not as expected (The Mac question and correct unzipping). Btw there is a newer release that MartiniB has posted up. 192. 189 was the previous, 187 the one before. I see another post has come in, I'll post since I don't want to loose my edit :). Discover_Pro_June_2020_EN.pdf
The Seat solutions lays here, it's Chillout with his toolbox https://www.drive2.ru/l/589815971363982212/ Been monitoring boards to see how quick they pick up on it. I see MartiniB picked up on the map link being available on that link but not Chillout had the fix since it probably wasn't known that it wouldn't load up on Seats. More on the SeatCupra site. I haven't tested it yet. Requires one of three firmware releases to be on the infotainment unit (on a prior one). Navigation FeCs to be valid (think the normal Seat ones). I believe you then edit the Seat part number back in which got left out of this release (covered in the German board looking at the file). The toolbox tells the unit to ignore validation errors with toggles set as I understand it as per the link above. They will be the signatures not matching since the part number has been edited. I'm told the screen then looks just like normal. Magic as the youngsters say. We still don't know whether it's a big mistake or whether Seat has done the dirty on those people with Mapcare. Looking for MartiniB to flag up when Seat puts a link up (presume corrected) or no link = the dirty. The RoW link suffers from the same issue for Seat / Cupra owners. Had a look.... two accidents in one.
Amundsen Mib2 Map Updates 2021
Yep the all European one has popped the 16gb cards even if you alter the allocation unit size to 4096. Unpacked the Seat version of the all Europe one comes to 16,523,067. That day that Skoda warned about in atleast on the German Skoda website where you need a 32gb Skoda card for all of Europe has arrived. Took mine out of the envelope and put it in the partner's car. Really only if travelling opposite ends of the continent do you need this, but then it's nice to have all of Europe than both with sub files. Also nice to see my digital offerings to TomTom appearing on the maps .
Present for MartiniB lifted from the German Ateca forum 2021-22 maps all Europe Seat server: https://seatmapdownloads.akamaized.net/EUAS/EU_AS_STD_1730.zip VW Servers: https://navigation-maps.volkswagen.com/vw-maps/DiscoverMedia2_EU-AS_1730_V14.7z Musing about whether all Europe fits on the 16gb card now. Have not tried yet. Reduce your sector size if that doesn't work by the 32GB Skoda card or use a smaller region when they are published.
I know that's what is so annoying. The local Seat dealer is good... Karoq suspension is firmer. I'm holding for electric in 2030. My Ateca is fully loaded everything other than the tow bar, stuff you can't buy now. I see the standard maps have now come out from both Seat and VW. 1730.... pop over to see whether MartiniB has got them. People are moaning about they can't fit them on the SD card now for all of Europe... perhaps that day has arrived.
Afraid we can say the Seat retrofit community isn't having any success with this. May be they forgot about us. Will be interesting to see what's finally on the Seat servers or whether VW revises this. It could be it's an oversight on Mapcare which Seat still uses. Cupras in Holland 2019 were given life time navigation FeC which went on for 30 years or so. They won't be happy bunnies if it wasn't for life or even till 2025.
Edit. On the last para it's come to pass that Seat Wireless Android Auto is now put on the base mib3 units and its identified by the part number ending in a letter. That one above doesn't which I photographed at a dealer doesnt'. Causing a certain amount of consternation with Seat people with early 2020 models that some get Wireless Android Auto and other don't. There was a production line change. So called zn1 vanished, the base unit. Whilst atleast in Germany business cars can optionally buy with and without Wireless Android Auto, whilst the 3D buillding building of the old mib2 high are optionally priced as an addon to the zn2 build codd (what was the old mib2 high identifier). Not sure whether VW and Skoda have all these wrinkles in the mib3 product offer.
