Everything posted by Tell
- Radio stations Logos database updates
- Mib3 Map Updates 2025.02-06
That might work but the complete reset might have deleted something that hasn't been put back. You are thinking, its still thinking that its on 25.06 may not be. @MartiniB hadn't been able to do any map updates for a bit, I got told that on a DM but from the above it seemed to work. I know some people have updated their firmware. I believe early mib3 firmware didnt allow user map updates. By updating the firmware it fixed it. Its that SWDL menu that I reckon is in mib3 but you are locked out of it. Mib2 high its that menu that allows you to upload any file into the system over writing what is there. Maps, POIs, firmware. Its that which you want which was on the developers menu of mib1 and mib2. Had to be enabled in mib2 and I reckon thats a no go area in mib3 unless ODIS gets you into it via enabling it ?. Obdeleven gave you an option in mib2 but everything is locked down now... least my understanding unless you are Vag licensed.
But as we found once on one or the other you can't change and you haven't been able to update in anycase due to technical reasons. I trust nobody has a way of updating from those 25.06 versions ?. No menu the same as swdl that forces an update. Perhaps they had a shambles in the files used for the update so the original P153 was old data or missing entities and they have corrected it. But if true from the last poster you can't update to P154 then you are stuck on it till a higher release expressed in MM.YY. I'd say that is true unless someone has found a way to force an update in the engineering menu ?. Other than that you need trusty SWDL which I reckon normal mib3 users will be locked out of. So if not on 25.06 and a lower release use the newer file. If already updated using P153. Hard cheese (English expression for tuff) unless there is any advance on forcing an update. Or the text on the first page means its been solved ? >> < edit 2025.09.28 > red ECE failed load in to Mib3 Amundsen of Škoda Superb Mk3.FL 2023 green succesed, thanks to @wolfr4ge < edit OFF > << Hmm its working 💪 for @MartiniB now since they corrected something but not for @wolfr4ge I think... I dunno. The old one if it went in before you cant change it but if it failed and its been corrected then it will load ?. It will all become 🤣. I guess nobody who had 25.06 already installed has been able to re-install it but if you haven't then you may be able to. Possibly the old part number thing they hadn't engineered the update for all units leaving a part number out. Vag was always doing this for the user POI import.
Probably wont since it already has you on 25.6. It will be a simple comparison of whether you are on that release already. The 154 code wont come into it. On a mib2 high swdl menu you can overwrite but I'm pretty sure you can't get swdl in mib3. All locked down. They dont want you messing internally in the unit.
Using the technique that a kind sole gave me on here some months ago that file should give the same date of release as the one posted up, excepted it's incremented by 1... perhaps some fix ? The technique to read these for the technically minded is this: Technical Note - Derivation of the YY.DD as shown on the Infotainment Screen I have now been told how to read that YY.DD date off the files after putting out my request for some time for a bright spark into these Mib3 files. It's been delivered. If you don't want to load up the file you can look up what year the and periods the files relate to. It's important with MIB3 files you don't alter the contents because you can't they are signed and they will refuse to load. So no tampering with the files like mib2 standard maps. Anyhow, this is how you do it thanks to C34 on the Briskoda site... only two posts popped up to tell me. You need to install DB Browser for SQLite. This has an extension in it to read the NDS Associate files, the normal SQL Lite brower that is popular won't. Install the MSI of DB Browser for SQLite in the link above. We now use C34's text... In this example on the file Update OI_P119_EU_202425_Offline_Update.zip contains data from 23.12 (YY.MM)... in this instance 25.06. That was a cut and paste job. Thank C34 again. You can check this for example in the MIB31_EU.ROOT/3D/PRODUCT.NDS file. This is a SQLite database, you can find this information in the updateRegionTable table. Probably only @MartiniB and myself plus a few others would check. It resolves what the file period is.
Amundsen MIB1 maps update ?
Have a look on the link. Did send you a PM. It came up with another Skoda poster. They went quite. So I assume it worked for them. The other way is to buy it on SD from Ebay by googling 8V0060866S that's the official part number and card. Its an Audi release that has uses outside Audi discovered by others.
See, see also here https://www.seatcupra.net/forums/resources/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.60/
MIB3 map update
I got the Turbo Manager with Firefox installed but have got that 900Mbs connection so not a lot of buffering between here and wherever their servers are. That manager I got recommend by the youngsters at the time I had terrible rural broadband on an aerial system. The providers had the aeriels mounted on church roofs bounced around between houses... and down valleys by line of sight🤫. Taking government grant for a system held together by sticky plaster, all that changed when fibre to the property arrived. It was 2Mbs or patchy rural broadband. Had the latter first of all. Country living. Generally then these downloads were better when Europe had gone to bed. Doesn't make any difference now. Ofcourse the quicker you get it over the less chance of a wobble on their servers.
It might not like NVME drive. I've seen people trying to do it with SSDs. I'd stick to a standard pen usb stick with a LED. I got this link when I googled. Somebody was asking on there. Others may be available. 64gb is the size you require. Amazon may turn up others. https://hardwarerecs.stackexchange.com/questions/18397/are-there-any-modern-usb-3-0-3-1-usb-flash-drives-with-indicator-activity-ligh It should be formated to exFat. NTFS is slower. I haven't said anything about issues using Macs recently. If you do you must run CleanMyDrive once the maps are copied over to the stick. Don't mix different things on the stick. Only the map files. There are reports that some Skoda firmware in the past needs updating if the map update doesn't work. Something to consider if it's not on the most recent firmware update. You might need a dealer for that.
You are not in the Middle East, Africa etc. Vag cars were shipped there without the navigation FeCs enabled. You find a retrofitter if so to enable it. Other than that its going to be an unzipping error or file presentation. If it's a second hand car shipped into the Middle East or Africa needs the FeCs altered. That comes up a lot.
MIB3 map update
Indeed you frig it to download all the fragments on route with connected services by putting a destination in to that far off place... like Russia or somewhere. That starts the connected services updating all the fragments on route. For usb without connect services it was Skoda people on this board as I recall that pointed out with LED it still had activity going on after it displayed it had done it as far the update showing on the screen. Thus they said they leave it in till all fashing stops. You practical Skoda drivers with flashing LED USBs in the know. I reckon it just updates your location first then if you pull it out you dont get the rest. Why when you read the pdfs its ambiguous. Anyhow youd just leave it in for a couple of hours driving if you had a LED less one. You only update the maps offline twice a year. Given the low cost of USBs you might as well just buy one with a LED and be done with it. Some hubs with USB C also have those LEDs on them which you could try if you had a spare one. Second alternative if you had such a device. Skoda make do approach. Anyhow that's why the LED activity ones are preferred. Footnote. With a LED USB you'd do the frig and watch to see what the LED did. Was it downloading all the zones to Russia?. Task for someone with a LED USB. That answers the question of whether it mimics connect services with the USB in or whether eventually it downloads the whole lot.
MIB3 map update
Probably. Reckon this is the ambiguity. Leave it in for a few more days of driving about. The LED USB people have the edge on this one.
MIB3 map update
The point is, those that use a USB stick with a LED activity light see data activity on the stick after the map version has changed on the screen. Thus they dont pull the stick out till that's finished. You live in Australia with relatively small map. It probably isnt segmented. Europe is. The map file structure is designed for connect services and will update as required as you change the segmentation. Thus what I reckon people are seeing with LED USBs is the rest of the map outside their local zone still being read in. No LED on the USB leave it in a bit longer. Say a couple of hours for Europe. For Australia / NZ you probably dont need to be so careful. You can eyeball the files and count the zones. I did once. Compare.
MIB3 map update
MIB3 map update
But the main page is here for latest mib3 navigation file release: https://www.briskoda.net/forums/topic/513799-mib3-map-updates-202406/ Poor old @MartiniB does all the work but people try and reinvent the wheel. So this one is off topic 😉. You get this on the SeatCupra board. There is an area but think the files are specific to the model. Then you get duplication. The main index of the files is here: https://www.briskoda.net/forums/forum/7-audio-electronics-and-security/ The question I seem to recall is why the maps wont update if on connected services. The importance of the yyyy.dd and not the file name. The offline maps can't better the connected services maps if they have been distributed on time. 2025.05 on file did come out before the connected services got it on some units. If you give up connected services then it may take 6-12 months before the offline maps catch up. You look at @MartiniB files since he's the resident Guru on sniffing them out. Board members pass any onto him where his sniffing out algorithms miss them out. As said Vag brands can get tardi at distributing these files. Sometimes Skoda is a head, VW or Seat. Sometimes one of the brands misses out a release as Skoda did in the past and became six months behind VW on the mib2 standard for three years or so. Skoda at the minute is ahead in general on all the files. On that very first question the YYYY.MM may change but those with LED usbs say it continues to flash which means it hasn't completed. My deduction is dont pull the USB straight out if you dont have a LED one. The maps are segmented into areas for online update. Its likely that when the YYYY.MM changes its updated just your local zone, like South England etc. The structure of the file is designed for connect services where it pulls back what it requires. Leave the USB in longer and it actually completes in total. Why people like the USBs which have a LED on them.
MIB3 map update
You are only suppose to be a member if you know what you are doing to test out new builds. One of the complaints is that Microsoft has cut its testing staff and relies on the Insider programme as a cheap alternative. The issues 24h2 were identified by people on the Insider programme and ignored. Not making the best use of the programme. I didnt bother. I could not risk loosing the PC I used for business, so whilst I joined the programme I never installed any builds.
The last person who was having issues. Track backwards from this: https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-160#post-5082309 A little test :). Facing the same issues as you.
MIB3 map update
They are probably on unsupported hardware which could be 32bit or the processor not having that security chip. Later the solution I use on the old office computer is this https://www.seatcupra.net/forums/threads/windows-11-22h2-23h2-24h2-upgrade-on-unsupported-64bit-hardware-link.470723/ Use the server command, a wrinkle Microsoft left in for "server" machines. Looks like it will work with Windows 11 25h2, did with 24h2. Then they might have a fully specified Windows 11 machine with pesky drivers. Had to use this to find the offending one. https://www.seatcupra.net/forums/threads/windows-11-24h2-sorting-out-those-pesky-drivers-that-stop-it-doing-the-second-boot-on-the-upgrade.477634/ 24h2 had many upgrade issues from 23h2 on Windows 11. Some users may stick with Windows 10, paying that fee / offer for one year of updates. Others may go to the Internet of things release with a long life of updates. A token can be bought for the license. Only gives you three years. We are alright on Windows 11 24h2 on a compliant machine that should go into Windows 12 at some point. The unsupported ones probably wont get to Windows 12. Time will tell. Then its out it or the Internet of things release for 11 to buy time. With crafty editing the implementation you should be able to retain the existing data and programs. Examples on the YouTube. Think I'll buy new hardware myself when my old office computer from 2012 isnt up to it - 3 years is a short period. The newer 2 in 1 laptop is fine.
The secret source is in here but you got to read the thread. Daz3d is the guy with it. https://www.seatcupra.net/forums/threads/updating-the-inbuilt-mib2-satnav-mib2-tricks-and-mib1.388586/page-144#post-5056706 You will see people asking with the pointer. Also in some cases you have to try an old mib trick of going back releases. Which you'll see on the thread. I recommend buying a mib2 card as your development card. The CID is recognised by mib1. Don't do the hack of the regions to get 106 map on it buy the bigger card and keep the current mib1 card as is... people get in a mess deleting what they have working. It does work on Skoda units. One person had it working here. Best of luck. All the ingredients are there you just got to find it 🥰.
MIB3 map update
Yes that's your tool to add corrections that go into the moderation cycle. Element of AI in there. They can get ignored at times and the underlying maps aren't always the most recent but if you do GPS track mapping for hiking those tools you can lay a track and reflect back onto Map Creator based on newer aeriel images. The Here Maps staff have the latest aerial images but due to licencing Map Creator shows more the public domain ones. Cheaper for them.
MIB3 map update
I do send people of to look at Here Maps Mapcreator at times where the cars maps and road dont tally. You will see in their development database the road speeds given. If you see 40mph you know its been done. You have the max speed and the average speed box. I kind of hope the routing algorithm uses the average speed but moderated by traffic reports.
