bigjohn
Everything posted by bigjohn
  1. Re carbon buildup - unlikely but a compression test will show up any issues affecting running, My son has the same later 1.2tsi EA211 engine in his 2016 Octavia and does not suffer misfires at about 50k miles. I have a previous gen EA111 1.4tsi in a Superb that now has 112k miles on it with no sign of misfire. The one thing not on your list of replacements is the coils packs - I would have done that ahead of a remap.
  2. Make sure you have the correct oil filter in place as there is a valve to stop oil drain back due to the orientation of the filter. A small brief slight start-up rattle from cold is normal for the EA111 engine but two seconds sounds excessive. My 2014 Superb 1.4 16v EA111 has had a cold start brief rattle since I bought it at 14 months old / 14k miles. I mentioned it whilst under Skoda warranty and was told everything was well - fast forward 8 years & 111k miles and it's exactly the same. Engine still sounds sweet, burns negligible oil and still averages mid 40's to 50+mpg.
  3. This was quite a while ago now - I suspect just about all of the faulty versions have been sorted by now.
  4. I had a similar comparison a few years ago albeit re a Skoda Superb. I agree the 1.9pd was a great engine. I owned a mkI 1.9 pd Superb for 10 years from 18 months old that mechanically was brilliant - rust was an issue though sadly. I know it's a bigger car but when I drove the 1.6 diesel Superb mkII it felt flat although I'm sure it would have been fine cruising at 70mph. The 2.0 diesel version felt way way better however I noticed a good deal on a 2014 1.4tsi petrol at the time (2015 pre dieselgate) so I tried that and loved it. Not quite as low down torquey as the 1.9 pd (still reasonable though) but rather interesting as the revs rose. I was worried about the economy but on the local test drive it was showing 44mpg and after purchase my average was about 46mpg but 50mpg+ is possible on a gentleish run. However the big difference were the engine noise levels - the petrol was soooo quiet in comparison. Re Octavia mkIII my son has a 2016 1.2tsi and it's surprisingly lively - I'd say the 1.4tsi Octavia is worth a try! Clearly the 1.6td would be the most economical though.
  5. As far as I know 12v round sockets (cigarette lighter size) are permanently live and the USB sockets are powered down when the ignition is turned off.
  6. I have installed a mobile phone holder at low level near the gear stick. The unit was designed to attach to the screen but I unclipped the sucker assembly and secured in this area with strong double sided tape:-
  7. Hi, I think you need to post this on the Superb III section of the forum.
  8. I'd agree re my tsi engine potentially having more problems - all good so far and 111k miles covered - but we'll see! It gets very regular oil changes so fingers tightly crossed. I bought as in 2015 no one wanted a big petrol car so incredibly cheap - how times have changed! I was an owner of a 1.9pd Superb for 10 years so am familiar - it was a fab engine. I only mentioned because the words tap/knock were mentioned and it's a documented issue with the OP's engine code - the sound recording is also difficult to hear. Back to the original post:- My gut feel is it's the wrong frequency of tapping for a climate control servo issue - certainly I got used to that noise as I had a faulty/sticking recirculation servo that drove me nuts when I bought my Superb mk 1 nearly new back in 2005. Fixed under warranty - full dash and front seats out job though. The frequency of the noise is ringing a new bell with me - does this car have a dvd drive in the glove box re sat nav etc? Only a thought. Also noticed fan motor replaced - was this new?
  9. Forgot to mention - it's worth covering / protecting the alternator just in case you have an oil spill on removal.
  10. There is another scary issue to consider, the later bxe version of the 1.9 pd engine did have a reputation for throwing a con rod:-
  11. Viewing from the front of the car with the bonnet up the oil filter is top left on the engine above the alternator. https://www.ebay.co.uk/itm/195663029191
  12. I'd say a tapping noise on first starting for the day is either a slightly crudded up hydraulic tappet or more likely a touch of piston slap until warmed up. I had a Passat diesel with a dodgy tappet - I found using Wynn's engine flush helped. However my Octavia 1.416v petrol had a knock/tap on first starting that quietened down after a few minutes - piston slap. It did it from near new until we sold it 19 years later and never got any worse.
  13. My sister's 2011 Jazz is the 1.4 , nice car but a bit of a high rev screamer at motorway speeds. Super reliable but you have to keep an eye on rust traps - especially rear wheel arches, the U shape fills up with mud and would eventually rust through if not attended to. Your previous high mpg might be more to do with your previous high annual mileage. I always liked the 1.416v in my Octavia but it sulked when it was eventually retired from my long commute to pottering. The oil breather then eventually clogged with oil mayonnaise because of condensation / oil mixing. I learnt to clear the oil breather pipe bi-annually that passed through the air filter housing.
  14. That won't help your mpg. I had a 2001 Octavia 1.4 16v (same engine) that usually averaged low 40's mpg. Not as good as a tsi as it is direct injection compared to the less efficient port injection of the 1.4 16v. With the same driving my 1.4tsi Superb averages late 40's mpg although if you take it steady on a motorway early 50's possible. Is the Jazz 55 mpg tank to tank measured? - my sister gets nowhere near that in hers although the fuel computer is rather optimistic.
  15. Take it to a specialist that knows what they are doing - steer clear of your current stealer!
  16. What engine and gearbox codes do you currently have? The problem is the 2.0 non turbo is a totally different old breed 8 valve engine where all the ancillaries inc manifolds are totally different. It also has a reputation for oil burning although the 2.0 mk1 my Dad had was fine to be honest. Also I don't think the old 5 speed box is designed for many more gg's. I think you'd be better getting a complete suitable engine / gearbox although even then there are other differences eg mounts, engine management, Intercooler, cooling system (as I've discovered in the past). Beware engine/gearbox mounts especially where they are bolted to captive nuts in chassis etc - On a 20 year old car these can be seized / snap off etc which can be a big job to sort.
  17. Isn't your Kamiq a 1.5 DSG auto? This thread is about a manual 1.0 Kamiq. I've been watching this thread with interest as I was considering a 1.0tsi manual. I'm also concerned about the infotainment / SOS woes.
  18. A windscreen fitter showed me the best way to remove things such as this - wrap some strong thin twine or fishing line etc around the top edge between device and windscreen then pull backwards and forwards repeatedly to cut through the adhesive. Hope that makes sense..
  19. I'm surprised its not mentioned on other non manufacturer specific forums yet - HonestJohn etc
  20. Shouldn't your Skoda dealer get back to Skoda UK! Especially as they can demonstrate the issue on multiple cars?
  21. Well diagnosed, I was looking for my much older Tomtom to do the same test - but it will no longer turn on.
  22. I'd still check just to make sue. It seems on modern cars it's other systems that start failing before car struggles to start. Power steering a common early symptom. At least measure the voltage before first starting to confirm all ok.
  23. Seconded re battery on its way out
  24. I know in the UK it's transmitted with the Classic FM broadcast - has somethings changed, failed or expired(eg certificate of some sort)? I can't test anymore as I just use Tomtom technology via phone sim theses days (device and phone app) - my original RDS-TMC device has died.
