Everything posted by bigjohn
2014 Auto Estate Flat Battery
The original battery has just been replaced in my 2014 1.4 Superb. After being left for a couple of cold days it was complaining of low battery after I unlocked the car. Mine is a stop/start and a great local independent garage sorted for about £100. One clue - the stop/start operated less and less and not at all in the weeks beforehand.
Windshield washer problem
Hi, You have posted in the Superb MKII forum - not the Octavia III. How cold is it where you are in Sweden? Could be wind chill of the car moving freezing up pipes that thaw out when stopped after a while with the heat from the engine bay - Just a thought.
octavia eng change
Even though it's similar, a Passat 1.9pd at this age has a totally different North/South orientation compared to the transverse of the Octavia. The Passat engine would better suit a mk1 Superb! A VW Golf or Seat Leon 1.9pd engine would be much better suited.
- Front Parking Sensors problems alonside few other diagnostic errors
Something not right..... 2.0 TSI (190)
i suppose we are saying the same thing - it's the "active" part that is different between diesel and petrol. A diesel "active" regen involves injecting extra fuel on the exhaust stroke whereas the petrol system is different. Diesels can also achieve passive regens when conditions allow (temperature in dpf, oxygen etc)
As far as I know GPF's are all passive regens due to higher combustion temperatures. Injecting more petrol down the exhaust system could have explosive results! However I stand to be corrected - I thought GPF's were much smaller and cheaper because of this. In addition I'm not sure a NA port injection VW UP even has a GPF although a later gti tsi will have as it has direct injection.
- Stop/Start not working
When I bought my 2014 facelift Superb it had been in the dealer system for 8 months of the cars 14 mount life (no one wanted a big petrol back in 2015!) - so probably hadn't had a good run for some time - The stop/start took many days to even work at all. The algorithm for the stop/start to work is a complex one involving battery condition, electrical load and many sensors (movement, car angle, temperature, pedal positions, doors, seat belts etc.. The stop start has recently stopped working on mine and basically the original battery is now on it's way out and is booked in for replacement tomorrow as it happens, If yours is on it's original it may be worth swapping now anyway. Make sure it's an EFB or AGM and it will need to be coded. VCDS may be able to tell you what's stopping stop start - I don't have it but I'm sure others will advise. Infact a previous owner may have disliked S/S and disabled it through VCDS by changing the required voltage setting too high. Does everything else work ok - eg cruise control? Things like clutch pedal sensor could cause both cruise and s/s to fail. PS on mine when S/S is working the car doesn't have to overly warm for it to function. [EDIT]Previous thread that is worth reading:-
Help, how do I know if I have a faulty alternator
I'd still suggest changing the battery - the 10v ish reading is a potential clue. It's the time of year that they fail(cold). Is it the original battery ? if so it's about due anyway - it's also cheapish to change.
This is classic symptoms of a failing battery - and they usually fail in cold weather
Vehicle not reaching optimum temperature
Is it a DSG?
It's getting cold again...
How old is the battery? - when getting on a bit these can cause strange errors - usually showing up when very cold. The stop start issue can be a symptom of a sub optimal battery
Central Locking not un locking
I've found my door handles are a bit prone to freezing up when very cold - also the door rubber can stick somewhat with frost stopping the door from opening. However I have to say I cheat - when I know I've got a very cold early start I put on a windscreen cover and position a small fan heater in the front footwell. Wired back to an outside socket that can be switched on / of from inside the house. Turned on before breakfast car usually nicely defrosted before I set off. I always tie a duster on the steering wheel to remind me I'm plugged in though!
SE technology range expanded Nov 2020
I looked at the technology model investigating the Karoq , it wasn't available with the PCP deposit contribution. I was considering buying with the contribution on PCP and quickly paying off. Not sure re Scala though.
What kind of smartphone holders do you have in your Superb 2?
I use the Brodit system to mount my Tomtom 5200 in my Superb II. the system comes in two parts.:- The first is the part designed to fit to a specific car The second is the part designed to fit the device; in my case a Tomtom 5200 but phone holders are available https://www.brodit.co.uk/brodit/vehicles/Skoda/Superb/2014/654219.htm https://www.brodit.co.uk/brodit/vehicles/Skoda/Superb/2014/654218.htm https://www.amazon.co.uk/gp/product/B013NNGX8I?pf_rd_r=XRGSG09C8GQCKMFAEVDE&pf_rd_p=6e878984-68d5-4fd2-b7b3-7bc79d9c8b60&pd_rd_r=48caf26e-6390-4937-9e23-f6babfb97be9&pd_rd_w=sn1Ha&pd_rd_wg=SYZtq&ref_=pd_gw_unk
Which bulb type and how?
Unlikely on a 1,4 tsi poverty spec
i also have a 1.4tsi facelift - it's a turn anticlockwise job past a bit of a notch. H7 bulb. Easy to access compared to some cars.
changing headlight bulbs
"PLEASE NOTE: Though the Philips Ultinon Pro9000 series does offer enormous lighting improvements and is made to the most rigorous of Philips' manufacturing standards, it is important to note that this LED headlight range is not road legal. The range's lack of ECE certification means that its usage should be prohibited to off-road, private applications."
DSG Failed at 30k
If you take the deal then as you are paying some money then the gearbox should get a two year warranty. This wouldn't be the case if you got it done Free of Charge. Myself I'd say £700 as a final bill is not a bad outcome.
Fuel Gauge reading only half the true amount of fuel in the tank
- Fuel Gauge reading only half the true amount of fuel in the tank
- Road Noise
My poverty spec Superb has 205 55 R16 Michelin Crossclimates and it's very refined indeed- Headlight conversion for european driving - Skoda Superb II
Thought I'd share the headlight conversion for European driving of my facelift 2014 Skoda Superb II S as I seen a couple of them with Eurolites attached. I don't have the benefit of "Travel" or "Tourist" with the halogen headlights on my Superb and last year I struggled finding how to convert them last year for driving in Europe - spending a lot of time with the master technician at my local Skoda dealership - apparently they are very different from the pre facelift models I can now do it in a couple of minutes a side using an inspection camera and a small screwdriver. You need to remove the headlight bulb plastic cap, insert the inspection camera viewing the "wing side" rear of the reflector - follow up with a small but long screwdriver to move the lever (it clicks into position) Hope this helps someone, I'd even bought a pack to Eurolites ready! I've take photos of this years (today!) conversion:-
