Everything posted by Carlston
Article from Parkers' about diesels in the upcoming London pollution zone (ULEZ)
What's crazy is when TFL puts a ULEZ camera up at a set of traffic lights that causes all the non-compliant cars to take a detour past the local primary school in order to avoid the camera. What the Mayor should be doing, is first putting a ULEZ camera outside the primary school to prevent a rat run, and only then putting one up at the local traffic lights. Children deserve clean air outside their school, not a rat run for dirty diesels.
Changing from 21inch to 19 inch wheels
It's not only a standard Skoda approved tyre and rim option for the Enyaq, but it doesn't increase the car's performance. So not only is it not a significant modification, it's not even a modification at all. If you're worried, check the CoC (Certificate of Conformity) to make sure that the 235/60R18 fitted to an 8Jx18 ET45 rim or 235/55R19 fitted to an 8Jx19 ET45 rim is listed. If it's listed it's not a modification. Also see inside the fuel filler flap, to see what tyre sizes are listed. On the Continent, it's very common to fit smaller diameter rims for winter tyres but from sizes that are listed on the CoC. The Enyaq owner's manual only lists 18" and 19" wheels for use with snow chains. So owners with 20" or 21" wheels won't be able to use snow chains.
Tires 175/70R14 driving characteristics-experiences
See this thread, where I suggest 195/60R15 on standard 6Jx15 ET38 5/100 57.1 rims for the Fabia MK3 and Rapid. However, you might want to try 185/65R14 on your current 5Jx14 ET35 5/100 57.1 rims. I've tried both 185/65 and 195/60, and although the 195/60 has more grip than the 185/65, the 185/65 rides better and still has plenty of grip. Because of the better ride, I prefer 185/65 to 195/60. Compared to 175/70R14, 185/65R14 is not just 10mm wider but has a 5% lower aspect ratio, giving quite a big improvement in performance. I'm not surprised you are a little disappointed with the performance of the rather narrow and high profile 175/70R14. Another option for the standard 5Jx14 ET35 5/100 57.1 rims, is 185/70R14. Part of the problem with your current 175/70R14 tyres is that they might just be past their best, and perhaps not particularly good in the first place. The big advantage of 185/70R14 over the high performance 195/60R15 is the ride quality and to some extent a small improvement in fuel consumption. Wider tyres do increase the drag, hence the increase in fuel consumption. 185/70R14 is even a standard tyre size on the latest Fabia MK4, although most markets seem to be choosing the 185/65R15 tyre size as the entry level for factory ordered Fabia MK4 cars. Vredestein Quatrac 5 185/70R14 88T https://www.camskill.co.uk/m137b0s7981p144829/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_185_70_R14_88T_TL_Fuel_Eff_%3A_D_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_69dB
Alcar 9383 8Jx18 ET45 5/112 57.1 steel rim 235/60R18 (weighs 13.26kg) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9383 https://www.mytyres.co.uk/rims/details?vehicleId=1313955427855111280&rimCode=ALCAR9383 Alcar 9393 8Jx19 ET45 5/112 57.1 steel rim 235/55R19 https://www.oponeo.pl/felga-stalowa/alcar-kfz-9393 https://www.mytyres.co.uk/rims/details?vehicleId=1313955427855111280&rimCode=ALCAR9393 19" to 21" alloy rims for Enyaq (19" alloy rim weighs between 14.1kg and 16.5kg, depending on model) https://eshop.skoda-auto.cz/cs_CZ/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AEnyaq%2B%282020%2B%29&page=1 Michelin CrossClimate 2 235/60R18 107H XL (Euro label A B 71dB) (about £134.00) https://www.camskill.co.uk/m141b0s12739p208592/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_235_60_R18_107H_XL_TL_Fuel_Eff_%3A_A_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Michelin CrossClimate 2 235/55R19 105H XL (Euro label A B 71dB) (about £155.40) https://www.camskill.co.uk/m142b0s12770p208527/Michelin_Tyres_All_Season_Car_Michelin_Cross_Climate_2_235_55_R19_105H_XL_TL_Fuel_Eff_%3A_A_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB
Will 225/45 R17 fit Skoda Rapid?
As you can see below, 225/45R17 is an Octavia MK3 tyre size. Fabia MK3 and Rapid tyre sizes 175/70R14 185/60R15 215/45R16 215/40R17 Octavia MK3 tyre sizes 195/65R15 205/55R16 225/45R17 As you can see below, the outside diameter of 225/45R17 is 5.1% bigger than 215/40R17. So is too big for the Fabia MK3 and Rapid. Also, 225/45R17 is likely to rub on the Fabia MK3 and Rapid. Outside diameter of tyre 215/40R17 603.8mm 225/45R17 634.3mm (+5.1%) If you're looking for slightly oversize tyres, then 195/60R15 fitted to the standard 6Jx15 ET38 5/100 57.1 rims would be a good choice. One advantage of the 195/60R15 tyre size is that it's an economical tyre size. One advantage of 15" rims is that they are lightweight. Vredestein Quatrac 6 195/60R15 88H (Euro label C B 70dB) (all-season tyre, 3PMSF symbol) (about £62.90) https://www.camskill.co.uk/m138b0s7993p202144/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_195_60_R15_88H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB 6Jx15 ET38 5/100 57.1 alloy rim MATO (3559CZK is about £126.67) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-mato-15-rapid-fabia-iii/p/6V0071495++8Z8 Alcar 7760 6Jx15 ET38 5/100 57.1 steel rim (about £40.00) https://www.mytyres.co.uk/rims/details?vehicleId=666952208536835172&rimCode=ALCAR7760
New Fabia noise query
Looking at the Skoda UK configurator, the standard size wheels for the different Fabia MK4 models are as follows. 15" wheels SE Comfort 16" wheels Color Edition SE L 17" wheels Monte Carlo In Poland and perhaps many other EU countries, the Monte Carlo comes with more sensible 16" wheels even if you select the most powerful 150HP engine.
Kamiq Spare Wheel Set
The following space saver rim with OEM part number 1J0601027M could be used with a 125/70R18 tyre on the Kamiq/Scala, etc. This OEM part number goes back a long way...at least 1997 when it was used with cars such as the VW Golf MK4. Some of the used ones sold on ebay have very old tyres that are over 20 years old. However, if a full size wheel fits in the spare wheel well with the carpet flush, there seems little point using a skinny space saver. 3.5Jx18 ET38 5/100 57.1 steel space saver rim 1J0601027M
Both the alloy and steel rims use the same wheel bolts.
VW forums ?
The Tiguan MK2 came out in 2016. If yours is a 2020 Tiguan, I doubt it is the Tiguan MK1. The Tiguan MK1 came out in 2007. VW Tiguan https://en.wikipedia.org/wiki/Volkswagen_Tiguan
The standard Kamiq tyre sizes have an outside diameter between 11.9% and 13.1% larger than the far too small 125/70R16, as shown in the chart below. Up to 1.5% difference is generally regarded as small and insignificant. Up to 5% difference is a big difference, but may be acceptable as a temporary get you home measure. More than 5% difference is too big. Outside diameter of tyre 125/70R16 581.4mm 205/60R16 652.4mm (+12.2%) 205/55R17 657.3mm (+13.1%) 215/45R18 650.7mm (+11.9%) However, you could change the 125/70R16 to a 135/90R16 as shown in the chart below. Outside diameter of tyre 135/90R16 649.4mm 205/60R16 652.4mm (+0.5%) 205/55R17 657.3mm (+1.2%) 215/45R18 650.7mm (+0.2%) Continental 135/90R16 102M space saver tyre https://www.mytyres.co.uk/rshop/tyre/Continental/sContact/T135-90-R16-102M/D-123394 Have you checked whether there's room to fit a full size spare in the spare wheel well, such as 205/60R16 fitted to a 6Jx16 ET35 5/100 57.1 steel rim? Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=1164478471326422116&rimCode=ALCAR6664 I suggest you order the below foam and jack kit from a VAG parts department using the OEM part number 658093860A. However, check with them to make sure that this is correct for your car. At about £40, it is surprisingly good value and includes everything except for the actual spare wheel. Once you have the kit, you can see how one of your current full size wheel fit...and take it from there. Foam and jack kit for Kamiq 658093860A (everything except for the actual spare wheel) (1,029CZK is about £36.63) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/658093860A To give you an idea of how much room the standard wheel sizes will take up, I have compiled the following chart. Note that the actual inflated width of a tyre always depends on the rim width to which it is fitted. As you can see in the chart below, the actual inflated widths of the standard tyre sizes on the Kamiq are all within 5mm of each other. Actual inflated width of tyre 205/60R16 fitted to 6J rim 209mm 205/55R17 fitted to 6.5J rim 214mm 215/45R18 fitted to 7J rim 213mm
Time to change Disc brake Vrs mk2
Does your Fabia MK2 VRS have build code 1ZD for the front brakes? If the answer is yes, then you just need the carrier. You can use either OEM part number 6C0615125 or 6R0615125B for the carrier. You might find that only one of these OEM part numbers is available to order from a VAG parts department. If you don't know your car's build codes, you can get them from an ebay seller for about 3 Euros. There might be around 180 build codes, and each build code is a 3-digit code made up of numbers and letters, ie. alphanumeric. "skoda vin decoder" https://www.ebay.co.uk/itm/224631127243 You can use the "vw codes decoder" to find out what each build code means. Build codes are useful for finding out what equipment was fitted to the car in the factory. "vw codes decoder" http://igorweb.org/equidec.aspx Skoda Fabia MK2 parts diagram (288x25mm front brakes with build code 1ZD) https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/6/615/615030 VW Polo MK5 parts diagram (310x25mm front brakes with build code 1ZR) https://www.lllparts.co.uk/catalogs/vw/RDW/PO/747/6/615/615040 Once the change is complete, you will have the same front and rear brakes as the VW Polo MK5 1.8GTI 192HP, ie. 310x25mm front brakes with build code 1ZR (which is an ATE brake system) and 230x9mm rear brakes with build code 1KV (which is a TRW brake system).
Will 16" Velorum 5 Spoke alloys fit Octavia III estate?
On "skoda eshop cz" the Velorum with OEM part number 5E0071496L 8Z8 is listed at 4,399CZK (about £156.61). https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282012-2017%29%3ArimDiameter%3A16%22&text=# If that doesn't sound particularly expensive, it's because Skoda alloy rims with the OEM part number format xxx071xxx are from the Skoda accessory catalogue. By contrast, Skoda alloy rims with the xxx061xxx format are from the Skoda parts catalogue, so tend to cost a lot more...often more than twice the price...for what is often essentially the same rim. I expect this is simply Skoda's attempt to compete on price with aftermarket alloy rims. In the Skoda parts catalogue, the Velorum is listed with the OEM part number 5E0601025C 8Z8, ie. using the xxx601xxx format. 5E0071496L 8Z8 and 5E0601025C 8Z8 appear to be the same rim. 8Z8 is the associated 3-digit colour code. 8Z8 means silver. If you do purchase Skoda alloy rims from their accessory catalogue, it's best to choice a style and colour that was commonly supplied on factory cars. That way, should you need a single replacement if a rim gets damaged (and Skoda have stopped selling that particular model in their accessory catalogue), there should be plenty of secondhand ones available on places like ebay. As you can imagine, most secondhand Skoda rims use the xxx601xxx format and not the xxx701xxx format, because most secondhand Skoda rims for sale came from factory supplied Skoda cars and not the Skoda accessory catalogue. 2 5E0601025C Aluminium rim 6.5Jx16 ET46 4 PR-C3N VELORUM 5E0601025C 8Z8 Diamond silver https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601060
6.5Jx16 ET46 5/112 57.1 is the standard 16" rim size on the Octavia MK3, and is normally used with a 205/55R16 tyre size. You can see the Velorum listed here. https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29%3ArimDiameter%3A16%22&text=#
It will fit the Audi A1 MK1, Seat Ibiza MK4, Skoda Fabia MK2, VW Polo MK5. The 310x25mm 5/100 front brake disc is a newer design than the 312x25mm 5/100 front brake disc. The older Brembo 312x25mm has a minimum thickness of 23mm, whereas the newer Brembo 310x25mm has a minimum thickness of 22mm. This means that the newer design might last 50% longer. Brembo 09.7880.11 front brake disc 312x25mm 5/100 (from Octavia MK1) (Minimum thickness 23mm) https://www.autodoc.co.uk/brembo/1657272?search=BREMBO Brake Disc (09.7880.11) Brembo 09.7880.21 front brake disc 310x25mm 5/100 (from VW Polo MK5, Seat Ibiza MK4, Audi A1 MK1) (Minimum thickness 22mm) https://www.autodoc.co.uk/brembo/8713501 However, I prefer ATE over Brembo. As far as I know, ATE is a German company (owned by Continental tyres) and Brembo is a Chinese company. The diameter of the front wheel hub flange is 126.5mm, and the H dimension is 133.8mm on the ATE 310x25mm front brake disc. It's going to fit easily. SKF VKBA 3569 Wheel Bearing Kit with integrated ABS sensor, 72 mm Article number: VKBA 3569 Supplementary Article / Supplementary Info Info 2:with integrated ABS sensor Diameter [mm]:72 Rim Hole Number:5 Flange Ø:126.5mm SKF:Wheel Bearing Kit https://www.autodoc.co.uk/skf/1362679 The only front brake disc that won't fit on the above front hub is the tiny 239x18mm front brake disc, as the H dimension is only 125mm, as shown in the diagram below. https://www.autodoc.co.uk/ate/957173 The 6C0615125 front brake carrier, 1K0615123M left front brake caliper, and 1K0615124M right front brake caliper are used on the VW Polo MK5 and Seat Ibiza MK4 with 310x25mm front brake discs. The Fabia MK2 uses the same 1K0615123M and 1K0615124M front brake calipers with 288x25mm front brakes discs, so just a change of carrier is needed to convert to 310x25mm front brake discs on the Fabia MK2. 310x25mm front brake carrier 6C0615125 https://www.oemvwshop.com/6c0615125-calliper-carrier-p396739/
Don't you mean 310x25mm front brake discs? Does your Fabia MK2 VRS have build code 1KD for the front brakes? If so, then you have an ATE front brake system. ATE don't make 312x25mm 5/100 front brake discs that will fit the Fabia MK2. They are 310x25mm as shown below. ATE 288x25mm 5/100 front brake discs https://www.autodoc.co.uk/ate/957587#productImageGroup ATE 310x25mm 5/100 front brake discs https://www.autodoc.co.uk/ate/957594#productImageGroup
Suspension Upgrade
The Bilstein B6 non-DCC shock absorbers for the Superb MK3 are particularly high quality because they are a mono-tube design. By comparison, the Bilstein B6 DCC shock absorbers for the Superb MK3 are the inferior twin-tube design. No wonder, there's been a huge improvement. Sadly, many Superb MK3 owners have DCC shock absorbers so won't be able to experience the excellent and superior mono-tube design.
Main dealer part prices?
That ebay listing is for 280x22mm front brake discs. If you've got a Yeti 2.0TDI 150HP, you've probably got 288x25mm front brake discs.
Spare wheel kit
As you can see in the chart below, there might only be 5mm difference in the inflated tyre width between a 205/55R16 and 225/45R17. The "205" and "225" marked on the sidewall is just the nomimal width of the tyre. The actual width of the inflated tyre always depends on the rim width to which it is fitted. Notice that if 205/55R16 and 225/45R17 are both fitted to a 7J rim, the 205 tyre is actually wider than the 225 tyre. Actual width of inflated tyre 205/55R16 fitted to 6.5J rim 214mm 205/55R16 fitted to 7J rim 220mm 225/45R17 fitted to 7J rim 219mm 225/45R17 fitted to 7.5J rim 225mm
VW forums ?
The VW Tiguan MK2 and Skoda Kodiaq both use the MQB A2 chassis. The VW T-Roc and Skoda Karoq both use the MQB A1 chassis. The VW T-Cross and Skoda Kamiq both use the MQB A0 chassis.
Tyres again
I normally use all-season tyres, as they have a lot more grip than summer tyres below about 7 degrees Centigrade. However, if you want summer touring tyres then Michelin Primacy 4+ work quite well above about 7 degrees Centigrade. Michelin Primacy 4+ 225/45R17 91V https://www.camskill.co.uk/m54b0s16p209569/Michelin_Tyres_Car_Michelin_Primacy_4%2B_225_45_R17_91V_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_69dB https://www.blackcircles.com/catalogue/michelin/primacy-4-plus/225/45/R17/V/91/m?tyre=42941985
Rear Beam Axle failed - need guidance please
Complete secondhand subframes are available on ebay, which might be suitable if the subframe has broken through corrosion. The labour cost of fitting will be more than the parts. If you go this route, it makes sense to chose as new a car as possible. The one in this photo came from a 2010 Octavia MK2. New subframes are also available, but then you don't get any of the associated parts if any of these need changing...such as wishbones.
The Octavia MK2 has independent rear suspension, not a beam axle. Can you take a photo of the part that is broken? Perhaps the upper wishbone (13), lower wishbone (7), or the axle guide (2). Broken rear springs are very common. When you say the wheel suddenly went inwards, do you mean that it looked like the rear spring was suddenly fully compressed? If so, this is most likely a broken spring. If you don't have a factory fitted towbar, then gknautomotive thinks you have rear springs with OEM part number 1K0511115BF. These springs have 1 white dot, and 3 yellow dots. https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/5/505/505005
On google maps, the factory shows up as Federal Mogul Friction Products Ltd, Chapel-en-le-Frith. So it appears that the name Federal Mogul is still in use, but under the Apollo umbrella. Federal Mogul Friction Products Ltd, Chapel-en-le-Frith https://www.google.com/maps/place/Federal+Mogul+Friction+Products+Ltd/@53.3296813,-1.9171536,17z/data=!4m14!1m7!3m6!1s0x487a339f98c18597:0x4086989223a247d2!2sFederal+Mogul+Friction+Products+Ltd!8m2!3d53.3296813!4d-1.9145787!16s%2Fg%2F1v3kmlq2!3m5!1s0x487a339f98c18597:0x4086989223a247d2!8m2!3d53.3296813!4d-1.9145787!16s%2Fg%2F1v3kmlq2?entry=ttu You can see on the Companies House website, that Ferodo Limited changed its name to Federal-Mogul Friction Products Limited in 1998. There's another company shown on the Companies House website that was called G. B. Tools & Components Exports Limited when it changed its name to Ferodo Limited in 2008. It's shown as a non-trading company, so presumably this is being used to prevent anyone else calling themselves Ferodo.
vRS TDI Front Brake Disc Measurements (Nominal & Minimum Thickness)
The early Octavia MK3 2.0TDI VRS were fitted with 340x30mm front brake discs, the later ones were fitted with smaller 312x25mm front brake discs. Minimum thickness is 27mm for the 340x30mm discs, and 22mm for the 312x25mm discs, ie. 3mm of allowable wear for both discs.
The brand "Ferodo" has been bought and sold a number of times since 1998, when it ceased to be a British company. I suspect Turner & Newall sold out to Federal-Mogul in 1998 because of massive asbestos claims and a £400 million pension deficit. In 2001, this caused the American buyer Federal-Mogul to put their company into Chapter 11 bankruptcy protection in America. So it seems that "Ferodo" (or the company that owned the brand, ie. Turner & Newall) had the business ethics and moral compass of the notorious Robert Maxwell. This is another shameful part of UK history, where UK politicians allowed businesses to cause serious and permanent damage to the health of their workers and allowed UK businesses to steal the pensions of their workers. Timeline of "Ferodo" ownership 1926 Acquired by Turner & Newall (British) 1998 Acquired by Federal-Mogul (American) 2018 Acquired by Tenneco (American) 2022 Acquired by Apollo Global Management (American)
