Carlston
Everything posted by Carlston
  1. Carlston replied to sparky2's topic in Reviews
    The Tiguan MK2 came out in 2016. If yours is a 2020 Tiguan, I doubt it is the Tiguan MK1. The Tiguan MK1 came out in 2007. VW Tiguan https://en.wikipedia.org/wiki/Volkswagen_Tiguan
  2. The standard Kamiq tyre sizes have an outside diameter between 11.9% and 13.1% larger than the far too small 125/70R16, as shown in the chart below. Up to 1.5% difference is generally regarded as small and insignificant. Up to 5% difference is a big difference, but may be acceptable as a temporary get you home measure. More than 5% difference is too big. Outside diameter of tyre 125/70R16 581.4mm 205/60R16 652.4mm (+12.2%) 205/55R17 657.3mm (+13.1%) 215/45R18 650.7mm (+11.9%) However, you could change the 125/70R16 to a 135/90R16 as shown in the chart below. Outside diameter of tyre 135/90R16 649.4mm 205/60R16 652.4mm (+0.5%) 205/55R17 657.3mm (+1.2%) 215/45R18 650.7mm (+0.2%) Continental 135/90R16 102M space saver tyre https://www.mytyres.co.uk/rshop/tyre/Continental/sContact/T135-90-R16-102M/D-123394 Have you checked whether there's room to fit a full size spare in the spare wheel well, such as 205/60R16 fitted to a 6Jx16 ET35 5/100 57.1 steel rim? Alcar 6664 6Jx16 ET35 5/100 57.1 steel rim https://www.mytyres.co.uk/rims/details?vehicleId=1164478471326422116&rimCode=ALCAR6664 I suggest you order the below foam and jack kit from a VAG parts department using the OEM part number 658093860A. However, check with them to make sure that this is correct for your car. At about £40, it is surprisingly good value and includes everything except for the actual spare wheel. Once you have the kit, you can see how one of your current full size wheel fit...and take it from there. Foam and jack kit for Kamiq 658093860A (everything except for the actual spare wheel) (1,029CZK is about £36.63) https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/658093860A To give you an idea of how much room the standard wheel sizes will take up, I have compiled the following chart. Note that the actual inflated width of a tyre always depends on the rim width to which it is fitted. As you can see in the chart below, the actual inflated widths of the standard tyre sizes on the Kamiq are all within 5mm of each other. Actual inflated width of tyre 205/60R16 fitted to 6J rim 209mm 205/55R17 fitted to 6.5J rim 214mm 215/45R18 fitted to 7J rim 213mm
  3. Does your Fabia MK2 VRS have build code 1ZD for the front brakes? If the answer is yes, then you just need the carrier. You can use either OEM part number 6C0615125 or 6R0615125B for the carrier. You might find that only one of these OEM part numbers is available to order from a VAG parts department. If you don't know your car's build codes, you can get them from an ebay seller for about 3 Euros. There might be around 180 build codes, and each build code is a 3-digit code made up of numbers and letters, ie. alphanumeric. "skoda vin decoder" https://www.ebay.co.uk/itm/224631127243 You can use the "vw codes decoder" to find out what each build code means. Build codes are useful for finding out what equipment was fitted to the car in the factory. "vw codes decoder" http://igorweb.org/equidec.aspx Skoda Fabia MK2 parts diagram (288x25mm front brakes with build code 1ZD) https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/697/6/615/615030 VW Polo MK5 parts diagram (310x25mm front brakes with build code 1ZR) https://www.lllparts.co.uk/catalogs/vw/RDW/PO/747/6/615/615040 Once the change is complete, you will have the same front and rear brakes as the VW Polo MK5 1.8GTI 192HP, ie. 310x25mm front brakes with build code 1ZR (which is an ATE brake system) and 230x9mm rear brakes with build code 1KV (which is a TRW brake system).
  4. On "skoda eshop cz" the Velorum with OEM part number 5E0071496L 8Z8 is listed at 4,399CZK (about £156.61). https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282012-2017%29%3ArimDiameter%3A16%22&text=# If that doesn't sound particularly expensive, it's because Skoda alloy rims with the OEM part number format xxx071xxx are from the Skoda accessory catalogue. By contrast, Skoda alloy rims with the xxx061xxx format are from the Skoda parts catalogue, so tend to cost a lot more...often more than twice the price...for what is often essentially the same rim. I expect this is simply Skoda's attempt to compete on price with aftermarket alloy rims. In the Skoda parts catalogue, the Velorum is listed with the OEM part number 5E0601025C 8Z8, ie. using the xxx601xxx format. 5E0071496L 8Z8 and 5E0601025C 8Z8 appear to be the same rim. 8Z8 is the associated 3-digit colour code. 8Z8 means silver. If you do purchase Skoda alloy rims from their accessory catalogue, it's best to choice a style and colour that was commonly supplied on factory cars. That way, should you need a single replacement if a rim gets damaged (and Skoda have stopped selling that particular model in their accessory catalogue), there should be plenty of secondhand ones available on places like ebay. As you can imagine, most secondhand Skoda rims use the xxx601xxx format and not the xxx701xxx format, because most secondhand Skoda rims for sale came from factory supplied Skoda cars and not the Skoda accessory catalogue. 2 5E0601025C Aluminium rim 6.5Jx16 ET46 4 PR-C3N VELORUM 5E0601025C 8Z8 Diamond silver https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/601/601060
  5. 6.5Jx16 ET46 5/112 57.1 is the standard 16" rim size on the Octavia MK3, and is normally used with a 205/55R16 tyre size. You can see the Velorum listed here. https://eshop.skoda-auto.cz/alu-kola/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AOctavia%2BIII%2B%282017%2B%29%3ArimDiameter%3A16%22&text=#
  6. It will fit the Audi A1 MK1, Seat Ibiza MK4, Skoda Fabia MK2, VW Polo MK5. The 310x25mm 5/100 front brake disc is a newer design than the 312x25mm 5/100 front brake disc. The older Brembo 312x25mm has a minimum thickness of 23mm, whereas the newer Brembo 310x25mm has a minimum thickness of 22mm. This means that the newer design might last 50% longer. Brembo 09.7880.11 front brake disc 312x25mm 5/100 (from Octavia MK1) (Minimum thickness 23mm) https://www.autodoc.co.uk/brembo/1657272?search=BREMBO Brake Disc (09.7880.11) Brembo 09.7880.21 front brake disc 310x25mm 5/100 (from VW Polo MK5, Seat Ibiza MK4, Audi A1 MK1) (Minimum thickness 22mm) https://www.autodoc.co.uk/brembo/8713501 However, I prefer ATE over Brembo. As far as I know, ATE is a German company (owned by Continental tyres) and Brembo is a Chinese company. The diameter of the front wheel hub flange is 126.5mm, and the H dimension is 133.8mm on the ATE 310x25mm front brake disc. It's going to fit easily. SKF VKBA 3569 Wheel Bearing Kit with integrated ABS sensor, 72 mm Article number: VKBA 3569 Supplementary Article / Supplementary Info Info 2:with integrated ABS sensor Diameter [mm]:72 Rim Hole Number:5 Flange Ø:126.5mm SKF:Wheel Bearing Kit https://www.autodoc.co.uk/skf/1362679 The only front brake disc that won't fit on the above front hub is the tiny 239x18mm front brake disc, as the H dimension is only 125mm, as shown in the diagram below. https://www.autodoc.co.uk/ate/957173 The 6C0615125 front brake carrier, 1K0615123M left front brake caliper, and 1K0615124M right front brake caliper are used on the VW Polo MK5 and Seat Ibiza MK4 with 310x25mm front brake discs. The Fabia MK2 uses the same 1K0615123M and 1K0615124M front brake calipers with 288x25mm front brakes discs, so just a change of carrier is needed to convert to 310x25mm front brake discs on the Fabia MK2. 310x25mm front brake carrier 6C0615125 https://www.oemvwshop.com/6c0615125-calliper-carrier-p396739/
  7. Don't you mean 310x25mm front brake discs? Does your Fabia MK2 VRS have build code 1KD for the front brakes? If so, then you have an ATE front brake system. ATE don't make 312x25mm 5/100 front brake discs that will fit the Fabia MK2. They are 310x25mm as shown below. ATE 288x25mm 5/100 front brake discs https://www.autodoc.co.uk/ate/957587#productImageGroup ATE 310x25mm 5/100 front brake discs https://www.autodoc.co.uk/ate/957594#productImageGroup
  8. The Bilstein B6 non-DCC shock absorbers for the Superb MK3 are particularly high quality because they are a mono-tube design. By comparison, the Bilstein B6 DCC shock absorbers for the Superb MK3 are the inferior twin-tube design. No wonder, there's been a huge improvement. Sadly, many Superb MK3 owners have DCC shock absorbers so won't be able to experience the excellent and superior mono-tube design.
  9. Carlston replied to a post in a topic in Skoda Yeti
    That ebay listing is for 280x22mm front brake discs. If you've got a Yeti 2.0TDI 150HP, you've probably got 288x25mm front brake discs.
  10. Carlston replied to markie1810's topic in Reviews
    As you can see in the chart below, there might only be 5mm difference in the inflated tyre width between a 205/55R16 and 225/45R17. The "205" and "225" marked on the sidewall is just the nomimal width of the tyre. The actual width of the inflated tyre always depends on the rim width to which it is fitted. Notice that if 205/55R16 and 225/45R17 are both fitted to a 7J rim, the 205 tyre is actually wider than the 225 tyre. Actual width of inflated tyre 205/55R16 fitted to 6.5J rim 214mm 205/55R16 fitted to 7J rim 220mm 225/45R17 fitted to 7J rim 219mm 225/45R17 fitted to 7.5J rim 225mm
  11. Carlston replied to sparky2's topic in Reviews
    The VW Tiguan MK2 and Skoda Kodiaq both use the MQB A2 chassis. The VW T-Roc and Skoda Karoq both use the MQB A1 chassis. The VW T-Cross and Skoda Kamiq both use the MQB A0 chassis.
  12. I normally use all-season tyres, as they have a lot more grip than summer tyres below about 7 degrees Centigrade. However, if you want summer touring tyres then Michelin Primacy 4+ work quite well above about 7 degrees Centigrade. Michelin Primacy 4+ 225/45R17 91V https://www.camskill.co.uk/m54b0s16p209569/Michelin_Tyres_Car_Michelin_Primacy_4%2B_225_45_R17_91V_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_69dB https://www.blackcircles.com/catalogue/michelin/primacy-4-plus/225/45/R17/V/91/m?tyre=42941985
  13. Complete secondhand subframes are available on ebay, which might be suitable if the subframe has broken through corrosion. The labour cost of fitting will be more than the parts. If you go this route, it makes sense to chose as new a car as possible. The one in this photo came from a 2010 Octavia MK2. New subframes are also available, but then you don't get any of the associated parts if any of these need changing...such as wishbones.
  14. The Octavia MK2 has independent rear suspension, not a beam axle. Can you take a photo of the part that is broken? Perhaps the upper wishbone (13), lower wishbone (7), or the axle guide (2). Broken rear springs are very common. When you say the wheel suddenly went inwards, do you mean that it looked like the rear spring was suddenly fully compressed? If so, this is most likely a broken spring. If you don't have a factory fitted towbar, then gknautomotive thinks you have rear springs with OEM part number 1K0511115BF. These springs have 1 white dot, and 3 yellow dots. https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/5/505/505005
  15. Carlston replied to a post in a topic in Skoda Yeti
    On google maps, the factory shows up as Federal Mogul Friction Products Ltd, Chapel-en-le-Frith. So it appears that the name Federal Mogul is still in use, but under the Apollo umbrella. Federal Mogul Friction Products Ltd, Chapel-en-le-Frith https://www.google.com/maps/place/Federal+Mogul+Friction+Products+Ltd/@53.3296813,-1.9171536,17z/data=!4m14!1m7!3m6!1s0x487a339f98c18597:0x4086989223a247d2!2sFederal+Mogul+Friction+Products+Ltd!8m2!3d53.3296813!4d-1.9145787!16s%2Fg%2F1v3kmlq2!3m5!1s0x487a339f98c18597:0x4086989223a247d2!8m2!3d53.3296813!4d-1.9145787!16s%2Fg%2F1v3kmlq2?entry=ttu You can see on the Companies House website, that Ferodo Limited changed its name to Federal-Mogul Friction Products Limited in 1998. There's another company shown on the Companies House website that was called G. B. Tools & Components Exports Limited when it changed its name to Ferodo Limited in 2008. It's shown as a non-trading company, so presumably this is being used to prevent anyone else calling themselves Ferodo.
  16. The early Octavia MK3 2.0TDI VRS were fitted with 340x30mm front brake discs, the later ones were fitted with smaller 312x25mm front brake discs. Minimum thickness is 27mm for the 340x30mm discs, and 22mm for the 312x25mm discs, ie. 3mm of allowable wear for both discs.
  17. Carlston replied to a post in a topic in Skoda Yeti
    The brand "Ferodo" has been bought and sold a number of times since 1998, when it ceased to be a British company. I suspect Turner & Newall sold out to Federal-Mogul in 1998 because of massive asbestos claims and a £400 million pension deficit. In 2001, this caused the American buyer Federal-Mogul to put their company into Chapter 11 bankruptcy protection in America. So it seems that "Ferodo" (or the company that owned the brand, ie. Turner & Newall) had the business ethics and moral compass of the notorious Robert Maxwell. This is another shameful part of UK history, where UK politicians allowed businesses to cause serious and permanent damage to the health of their workers and allowed UK businesses to steal the pensions of their workers. Timeline of "Ferodo" ownership 1926 Acquired by Turner & Newall (British) 1998 Acquired by Federal-Mogul (American) 2018 Acquired by Tenneco (American) 2022 Acquired by Apollo Global Management (American)
  18. According to Jurid on autodoc, the Octavia MK3 1.4 petrol 140HP has 288x25mm front brakes with build code 1ZE and 253x10mm rear brakes with build code 1KD. Build codes 1ZE and 1KD are both TRW brake systems, so perhaps use TRW brake pads. To search for front brakes pads 1ZE you can use OEM part number 8V0698151, and to search for rear brake pads 1KD you can use OEM part number 5Q0698451A or 5Q0698451M. TRW GDB1330 rear brake pads 253x10mm 1KD 5Q0698451A 5Q0698451M https://www.autodoc.co.uk/trw/2191943 https://www.amazon.de/-/en/GDB1330-TRW-Brake-Pad/dp/B00DPIB6DO/ref=sr_1_1
  19. On the Kodiaq, there are three different front brake sizes. 16" rims will clear the front brake calipers on all front brake disc sizes, except the biggest 340x30mm front brake discs which need at least 17" rims. Kodiaq front brake sizes 312x25mm (16" rims will clear the front brake calipers) 314x30mm (16" rims will clear the front brake calipers) 340x30mm (17" rims will clear the front brake calipers) Note that 16" wheels aren't approved by Skoda for fitment to the Kodiaq. However, with almost 6" of sidewall the 215/70R16 tyre size could prove useful for going off-road/muddy tracks, etc. Vredestein Quatrac 6 215/70R16 100H https://www.camskill.co.uk/m139b0s12700p201645/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_215_70_R16_100H_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_71dB Yokohama Geolandar AT G015 215/70R16 100H https://www.camskill.co.uk/m62b0s13231p148267/Yokohama_Tyres_Car_Yokohama_Geolandar_AT_G015_215_70_R16_100H_RPB_TL_Fuel_Eff_%3A_E_Wet_Grip%3A_C_NoiseClass%3A_B_Noise%3A_70dB Alcar 9922 6.5Jx16 ET33 5/112 57.1 steel rim (from 2007-2016 VW Tiguan) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9922#23375120
  20. It won't be 312x25mm, because the 1.6TDI doesn't have enough power. Even the Octavia MK3 2.0TDI 150HP only uses 288x25mm front brake discs. It is either 276x24mm or 288x25mm depending on the car's build code for the front brakes. Build code 1ZF means 276x24mm, and build code 1ZE means 288x25mm. You might have a white build code label under the carpet near the spare wheel well. This has some of the build codes on.
  21. The latest Continental AllSeasonContact 2 is now available from mytyres in the slightly oversize 245/40R19. However, as it has only just come out the price may drop over the next month or two as other online sellers such as camskill also start to receive stock. I can't see it listed in the standard 19" size yet, ie. 235/40R19. Even if it's only a small improvement over the previous highly rated AllSeasonContact, it going to be very good. Compared to the standard 235/40R19 size, the slightly oversize 245/40R19 has an outside diameter 1.2% larger...which is such a small change that you might not even notice the difference. Put another way, when the 245/40R19 has just 4mm of tread wear it will have exactly the same outside diameter as a new 235/40R19. Outside diameter of tyres 235/40R19 670.6mm 245/40R19 678.6mm (+1.2%) Continental AllSeasonContact 2 245/40R19 96Y XL (Euro label B B 71dB) (the tyre size shown in the below photo is a slightly smaller 225/45R17) https://www.mytyres.co.uk/rshop/tyre/Continental/AllSeasonContact-2/245-40-R19-98Y-XL-EVc/D-128031
  22. Some owners have already made the change, and are very pleased with the much improved comfort, better fuel consumption, less tyre noise, less unsprung weight, etc. The OP has pointed out that he isn't a racing driver and more of a cruiser. Unfortunately, many owners just don't realise how extreme some car manufacturers (including Skoda) are being in their choice of large diameter rims and rubber band tyres. One Superb MK3 owner changed down to 17" wheels and was so pleased with the improvement in ride comfort that he then changed to 16". Surprise, surprise, the ride on the 16" wheels was even better than the 17" wheels. In the 1960's there was huge development in car tyres. For example, the Jaguar E-Type went from cross-ply tyres when it first came out in 1961 to low profile 205/70R15 radial tyres in 1968. The entry level 215/60R16 tyres on the Superb MK3 would have been an absolute delight on this 144mph car, but they weren't available back then. Notice in the chart below that 205/70R15 and 215/60R16 have about the same outside diameter. Outside diameter of tyres 205/70R15 668mm 215/60R16 664.4mm Jaguar E-Type https://en.wikipedia.org/wiki/Jaguar_E-Type#/media/File:Jaguar_E-Type_series_1_coupé_1964.jpg Superb MK3 280HP 4x4 fitted with slightly oversize 245/45R18 tyres
  23. As you can see in the chart below, 235/45R19 has an outside diameter 4.5% more than the standard 215/60R16 tyre size. If you want 235/45, it would be better to go for 235/45R18 rather than 235/45R19. I've added 245/45R18 and 245/40R19 to the chart, as some Superb MK3 owners have changed to those sizes. A 2.0% or 2.1% increase is far more modest than a 4.5% increase, so has the big advantage of running gearing that is a lot closer to how Skoda intended. Outside diameter of tyres 215/60R16 664.4mm 245/45R18 677.7mm (+2.0%) 245/40R19 678.6mm (+2.1%) 235/45R19 694.1mm (+4.5%)
  24. 215/60R16 is a more comfortable and quieter tyre size than 235/40R19. 6.5Jx16 ET41 is the standard 16" rim size on the Superb MK3, but the similar 6Jx16 ET43 (from Karoq) would allow it to fit in the spare wheel well without raising the carpet using the standard 215/60R16 tyre size. 6Jx16 ET43 5/112 57.1 alloy rim NANUQ (from Karoq) https://eshop.skoda-auto.cz/cs_CZ/alu-kolo-nanuq-16-karoq/p/57A071496A+8Z8
  25. Here are three standard Fabia MK4 rim sizes. Alcar 3055 5Jx14 ET38 5/100 57.1 steel rim (185/70R14) https://www.oponeo.pl/felga-stalowa/alcar-kfz-3055#23447420 https://www.mytyres.co.uk/rims/details?vehicleId=1351328927595312228&rimCode=ALCAR3055 Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim (185/65R15) https://www.oponeo.pl/felga-stalowa/alcar-kfz-4055#23361620 https://www.mytyres.co.uk/rims/details?vehicleId=1351328927595312228&rimCode=ALCAR4055 Alcar 6955 6Jx16 ET45 5/100 57.1 steel rim (195/55R16) https://www.oponeo.pl/felga-stalowa/alcar-kfz-6955#23447419 https://www.mytyres.co.uk/rims/details?vehicleId=687573549115790436&rimCode=ALCAR6955
