Carlston
Everything posted by Carlston
  1. 5Q0513029KD rear shock absorbers are listed against build codes 0N4+1JC+1X0+K8D (and manufactured after 05.10.2015) VW Codes Decoder 0N4 independent rear suspension 1JC lowered ride height 1X0 front wheel drive K8D estate Octavia MK3 parts catalog https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/5/511/511001
  2. One of the standard wheel sizes on the Octavia MK2 1.9TDI 105PS is 195/65R15 6Jx15 ET47 5/112 57.1 Steel rims can be ordered on their own or with fitted and balanced tyres, from mytyres.co.uk Alcar 9165 6Jx15 ET47 5/112 57.1 steel rim (7.73kg) (Octavia MK2) https://www.mytyres.co.uk/rims/details?vehicleId=183006013861926000&rimCode=ALCAR9165 Alcar 9165 6Jx15 ET47 5/112 57.1 steel rim with fitted and balanced Uniroyal RainExpert 5 195/65R15 91H (Euro label C A 71dB) https://www.mytyres.co.uk/cw/bundle?vehicle_ids=182669563303826544&wheelId=SKWi-9165--D-124258&rimCode=ALCAR9165&tyreId=D-124258&wheelIdWithTpms=&season=so&rimType=steel Octavia MK2 parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/6
  3. The 57A093860B and 57A093860C kits on "skoda eshop cz" both list a 125/70R18 3.5Jx18 ET25.5 spare wheel with OEM part number 5E3601011B, as shown below. 57A093860B (for Karoq FWD) Sada pro výměnu rezervního kola 18Určeno pro: Karoq.Technical specificationProduct code 57A093860B Color Black Material Polystyrene Set contents Polystyrene box, plastic nut, mounting bolt with rosette, luggage compartment floor support, jack, jack handle, wheel wrench, assembly instructions. Weight 3 kg Limitations Only for 4x2 front-wheel drive vehicles with basic luggage compartment floor and standard rear seats as standard equipment. Fastening On the luggage compartment floor. Spare wheel (product code) 5E3601011B (3.5J x 18" ET 25.5) 57A093860C (for Karoq 4x4) Sada pro výměnu rezervního kola 18Určeno pro: KaroqTechnical specificationProduct code 57A093860C Color Black Material Polystyrene Set contents Polystyrene box left, polystyrene box right, polystyrene spacer, plastic nuts, fixing screw with rosette, luggage compartment floor support, luggage compartment carpet, jack, jack handle, wheel wrench, assembly instructions. Weight 8.2 kg Limitations Only for 4x4 vehicles with basic luggage compartment floor and standard rear seats as standard equipment. Fastening On the luggage compartment floor. Spare wheel (product code) 5E3601011B (3.5J x 18" ET 25.5)
  4. On the Octavia MK3, the 253mm rear brake discs come in two widths (51.6mm and 61.4mm). Confusingly, both rear brake discs use the same build code, ie. 1KD. The 253mm rear brake discs with a 61.4mm width appear in the Octavia MK3 parts catalogue from the 2018 model year...so when the car was facelifted. What size brake discs are fitted usually depends on what engine is fitted, in particular the engine power. Occasionally, the size of brake discs can also depend on whether the car is FWD or 4x4, and whether it's a petrol or diesel. From various autodoc listings (Jurid, Ferodo, Pagid, Champion), it appears that the Octavia MK3 uses 253x10mm rear brake discs for all models with up to 150PS. 253x10mm rear brake disc (D=51.6mm) (up to 2017 model year) https://www.autodoc.co.uk/ate/956867 253x10mm rear brake disc (D=61.4mm) (2018 model year onwards) https://www.autodoc.co.uk/ate/18101448 ATE Rear Brake Discs (Octavia MK3) 253x10mm ATE 24011002771 (pre-facelift model) 253x10mm ATE 24011004201 (facelift model) 272x10mm ATE 24011003561 310x22mm ATE 24012202191
  5. The price on the Australian version of Amazon for this SKF front wheel bearing seems similar to the price in the UK, even taking into account shipping. SKF VKBA 7011 (sold to replace 8V0498625A) https://www.amazon.com.au/SKF-VKBA-7011-Wheel-bearing/dp/B019IPPN7C/ref=sr_1_1
  6. The 2014 Octavia MK3 2.0TSI 220PS VRS has 340x30mm front brake discs, ie. build code 1LG. Therefore, the front wheel bearings have OEM part number 8V0498625A...as shown in the Octavia MK3 parts catalogue. Front wheel bearing (Octavia MK3 with 312x25mm or 340x30mm front brake discs) 9 8V0498625A Front wheel bearing with assembly parts 85mm Octavia MK3 parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/4/407/407005
  7. One option is to change the 205/55R16 to 205/60R16 or 205/65R16...assuming the current spare wheel is 205/55R16 6.5Jx16 ET46. 205/60R16 and 205/65R16 have an outside diameter much closer to the standard Superb MK3 tyre sizes, as shown in the chart below. Another option is to use a 215/60R16 fitted to a 6Jx16 ET43 rim (from the Karoq FWD). Unlike the standard 16" wheel, ie. 215/60R16 6.5Jx16 ET41, a 215/60R16 6Jx16 ET43 wheel fits in the spare wheel well without lifting the carpet. Superb MK3 tyre sizes 205/55R16 631.9mm (not a standard Superb MK3 tyre size) 205/60R16 652.4mm (not a standard Superb MK3 tyre size) 205/65R16 672.9mm (not a standard Superb MK3 tyre size) 215/60R16 664.4mm 215/55R17 668.3mm 235/45R18 668.7mm 235/40R19 670.6mm MWD 16236 6Jx16 ET43 5/112 57.1 steel rim (from Karoq) https://www.mytyres.co.uk/rims/details?vehicleId=1128135213981897840&rimCode=MWD16236
  8. Skoda sell two "foam and jack" kits for the Karoq. One is for the Karoq FWD, and the other is for the Karoq 4x4. The "foam and jack" kit includes everything, except for the actual spare wheel...which can be ordered separately. These "foam and jack" kits can be ordered from any VAG parts department, by quoting the relevant OEM part number, ie. 57A093860B for the Karoq FWD or 57A093860C for the Karoq 4x4. The standard space saver wheel for both of these kits is 125/70R18 3.5Jx18 ET25.5 5/112 57.1 which are often sold secondhand on ebay from about £40...sometimes unused. However, 125/70R18 has an outside diameter about 5% smaller than standard Karoq wheels...so perhaps consider 135/80R18 instead of 125/70R18 fitted to the same 3.5Jx18 ET25.5 5/112 57.1 steel space saver rim. When fitted to a 3.5J rim, the 135/80R18 tyre is about 7mm wider than the 125/70R18 tyre...so check that there's 7mm of available space in the wheel well (when a 125/70R18 3.5Jx18 wheel is in the spare wheel well) before ordering a 135/80R18 tyre. The actual width of a tyre is measured when the tyre is inflated from sidewall to sidewall, at the widest point. It might also be worth seeing if a standard full-size wheel fits in the spare wheel well...such as 215/60R16 6Jx16 ET43 5/112 57.1 (for the Karoq FWD) or 225/60R16 6Jx16 ET43 5/112 57.1 (for the Karoq 4x4). 135/80R18 space saver tyre https://www.camskill.co.uk/m129b0s7672p0/Temporary_Spare_Tyres_-_Space_Saver_Tyres_-_18_inch_R18_inch_-_135_80_18_135_80R18_R18_inch_-_135_18_135R18 Karoq FWD "foam and jack" kit 57A093860B (Czech price about £90) Only for 4x2 front-wheel drive vehicles with basic luggage compartment floor and standard rear seats as standard equipment Karoq 4x4 "foam and jack" kit 57A093860C (Czech price about £128) Only for 4x4 vehicles with basic luggage compartment floor and standard rear seats as standard equipment
  9. 1K2614019B Right Hand Drive F >> 1Z-62173 092* F >> 1Z-68069 679* https://www.autodoc.co.uk/ate/13668740 1K2614019H Right Hand Drive F 1Z-62173 093>>* F 1Z-68069 680>>* https://www.autodoc.co.uk/ate/13765809#brake-master-cylinder Octavia MK2 parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/6/611/611010
  10. 2017 Yeti 1.4TSI 4x4 150PS Rear brake discs 272x10mm 1KS 1K0615601AA 5Q0615601D Rear brake pads 272x10mm 1KS 5K0698451 5K0698451A 5K0698451C 5K0698451D
  11. 312x25mm front brakes (build code 1ZA) (TRW brake system) (Octavia MK3) Left front brake caliper 8V0615123A https://www.autodoc.co.uk/trw/7488968 Right front brake caliper 8V0615124A https://www.autodoc.co.uk/trw/7488969 Left front brake caliper carrier 8V0615125A https://www.autodoc.co.uk/trw/7488924 Right front brake caliper carrier 8V0615126A https://www.autodoc.co.uk/trw/7488925 Octavia MK3 parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/615/615025
  12. Outside diameter of standard 225 tyre sizes (Octavia MK3, not Scout) 225/35R19 640.1mm 225/40R18 637.2mm 225/45R17 634.3mm Outside diameter of 235/40R18 compared to the standard 225 tyre sizes 235/40R18 645.2mm (0.8% bigger outside diameter compared to 225/35R19) 235/40R18 645.2mm (1.3% bigger outside diameter compared to 225/40R18) 235/40R18 645.2mm (1.7% bigger outside diameter compared to 225/45R17) Outside diameter of 235/35R19 compared to the standard 225 tyre sizes 235/35R19 647.1mm (1.1% bigger outside diameter compared to 225/35R19) 235/35R19 647.1mm (1.6% bigger outside diameter compared to 225/40R18) 235/35R19 647.1mm (2.0% bigger outside diameter compared to 225/45R17) Outside diameter of 225/40R19 compared to the standard 225 tyre sizes 225/40R19 662.6mm (3.5% bigger outside diameter compared to 225/35R19) 225/40R19 662.6mm (4.0% bigger outside diameter compared to 225/40R18) 225/40R19 662.6mm (4.5% bigger outside diameter compared to 225/45R17) Outside diameter of 235/40R19 compared to the standard 225 tyre sizes 235/40R19 670.6mm (4.8% bigger outside diameter compared to 225/35R19) 235/40R19 670.6mm (5.2% bigger outside diameter compared to 225/40R18) 235/40R19 670.6mm (5.7% bigger outside diameter compared to 225/45R17) ETRTO approved rim widths for passenger car tyresa 225/45 7.0-7.5-8.5 225/40 7.5-8.0-9.0 225/35 7.5-8.0-9.0 235/45 7.5-8.0-9.0 235/40 8.0-8.5-9.5 235/35 8.0-8.5-9.5
  13. You can open an account on "skoda parts com" and park your Skoda in the garage with its VIN number. This apparently lets you get the OEM part numbers of various parts free of charge. "skoda parts com" https://www.skoda-parts.com/online-store.html
  14. The part number of the turbo actuator for the Skoda Rapid 1.0TSI might be 04E198725G. This OEM part number is also listed for the 1.0TSI engine used in some other Skodas including the Fabia MK3, Kamiq, Karoq, Octavia MK3, and Scala...so it's not just used for the 1.0TSI engine in the Rapid. The listings on autodoc show that this part is out so stock, but it's listed in stock on "skoda parts com"...as linked to below. Skoda Rapid parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/RAP/740/1/145/145020 04E198725G https://www.autodoc.co.uk/car-parts/oem/04e198725g?search=OEN+04E198725G 04E198725G https://www.skoda-parts.com/spare-part/04e198725g-turbo-pressure-vacuum-regulator-europen-union-oe-producer-54360.html
  15. Carlston replied to mct23's topic in Skoda Karoq
    The only Skoda approved 17" tyre size for the Karoq FWD (Front Wheel Drive) NOT 4x4 is 215/55R17. 205/55R17 isn't a Skoda approved tyre size for the Karoq. Also note that 205/55R17 has a smaller outside diameter than 215/55R17. Skoda cars that use the 205/55R17 tyre size include the Kamiq and Octavia MK4. Outside diameter of tyres 205/55R17 657.3mm (1.6% smaller outside diameter compared to 215/55R17) 215/55R17 668.3mm
  16. If you have steel rims and fit snow chains, the owner's manual says remove the wheel trims before fitting snow chains. So as removing wheel trims from steel rims isn't a modification, I would have thought that removing wheel trims from alloy rims would also not be a modification.
  17. The below three ALTAIR alloy rims are listed in the "Skoda alloy rim accessory catalogue". 7.5Jx19 ET48 5/112 57.1 alloy rims ALTAIR 5E3071499AA FL8 5E3071499AB HA7 5E3071499AC 8Z8 Colour code decoder FL8 Black HA7 Anthracite 8Z8 Silver The OEM part number format xxx601xxx means the alloy rims are factory alloy rims or from the standard Skoda parts catalogue. The OEM part number format xxx071xxx means the alloy rims are from the "Skoda alloy rim accessory catalogue". Alloy rims from the "Skoda alloy rim accessory catalogue" might be about 60% less expensive than alloy rims from the standard Skoda parts catalogue because Skoda use the "Skoda alloy rim accessory catalogue" to compete on price with aftermarket alloy rims. The only difference is the OEM part number and sometimes the colour can also be different (if the three-digit colour code is different). The three-digit colour code should be cast into the back of the alloy rim.
  18. As you can see in the two charts below, if the Octavia MK2 was manufactured before 06.03.2006 build codes 1JA+0YD meant the car came with 1K0511115BF rear springs, but if the Octavia MK2 was manufactured from 06.03.2006 the same build codes meant the car came with 1K0511115BD rear springs. So what Skoda did from 06.03.2006, was start fitting the cars with rear springs that were two down in the hierarchy, ie. softer rear springs. If the owner of a later car (manufactured from 06.03.2006) fits stiffer rear springs two up in the hierarchy, they are simply going back to what Skoda used to fit until 05.03.2006. Octavia MK2 rear springs (car manufactured until 05.03.2006) (1JA=standard ride height) 1K0511115BC 1JA+0YA 1K0511115BD 1JA+0YB 1K0511115BE 1JA+0YC 1K0511115BF 1JA+0YD 1K0511115BG 1JA+0YE 1K0511115BH 1JA+0YF 1K0511115DE 1JA+0YG 1K0511115DF 1JA+0YH 1K0511115BL 1JA+0YJ 1K0511115BM 1JA+0YK 1K0511115BN 1JA+0YL 1K0511115BP 1JA+0YM Octavia MK2 rear springs (car manufactured from 06.03.2006) (1JA=standard ride height) 1K0511115FT 1JA+0YA 1K0511115GA 1JA+0YB 1K0511115BC 1JA+0YC 1K0511115BD 1JA+0YD 1K0511115BE 1JA+0YE 1K0511115BF 1JA+0YF 1K0511115BG 1JA+0YG 1K0511115BH 1JA+0YH 1K0511115DE 1JA+0YJ 1K0511115DF 1JA+0YK 1K0511115BL 1JA+0YL 1K0511115BM 1JA+0YM As you can see in the chart below, the aftermarket spring market has a lot of rebranding going on, ie. the same spring is often sold under more than one brand name. Some springs that should match 1K0511115BF (this isn't a complete list) Ashika ZCA7099A (same as KYB RA7099) Bilstein 36-134076 (might be rebranded) JapanParts ZC7099A (same as KYB RA7099) Japko ZCJ7099A (same as KYB RA7099) Kilen 63117 (same as Lesjofors 4285718) KYB RA7099 (same as NAPA NCS1219) Lesjofors 4285718 (same as Kilen 63117) NAPA NCS1219 (same as KYB RA7099) Sachs 996 653 (same as SKF VKDL 31011) SKF VKDL 31011 (same as Sachs 996 653)
  19. NAPA NCS1219 appears to be a rebranded KYB RA7099, so identical to that spring. It should be almost identical to the Sachs rear spring that is sold to replace 1K0511115BF. The KYB RA7099 is sold to replace 1K0511115BE and 1K0511115BF, but is probably a 1K0511115BF rear spring because KYB couldn't sell a 1K0511115BE rear spring to replace a 1K0511115BF rear spring due to a 1K0511115BE rear spring not being able to support the same axle weight as a 1K0511115BF rear spring. One white paint mark and one yellow paint mark is a 1K0511115BD rear spring. NAPA NCS1219 rear springs (probably matches 1K0511115BF) (£31.48 for two) Length 353mm Wire diameter 11.75mm Number of coil turns 8 (as shown in the below KYB RA7099) https://www.ebay.co.uk/itm/195003151427 When looking for stiffer rear springs for the Octavia MK2 with standard ride height, I first get a list of all of the standard ride height rear springs that are shown in the Octavia MK2 parts catalogue, as shown below. As you can see below, there are twelve rear springs in this hierarchy going from the softest rear spring (1K0511115FT) to the stiffest rear spring (1K0511115BM). The first two springs in this hierarchy aren't listed for the estate or 4x4 versions, only the hatchback version. 1K0511115BD is 4/12 in this hierarchy, and 1K0511115BF is 6/12 in this hierarchy. Next, I get the specifications for the original spring (that is too soft) and the next two in the hierarchy. Getting a good idea of the specification can often be difficult because different brands will often have different ideas of what the specification of each spring is, and many brands don't give the specification. Octavia MK2 rear springs (car manufactured until 05.03.2006) (1JA=standard ride height) 1K0511115BC 1JA+0YA 1K0511115BD 1JA+0YB 1K0511115BE 1JA+0YC 1K0511115BF 1JA+0YD 1K0511115BG 1JA+0YE 1K0511115BH 1JA+0YF 1K0511115DE 1JA+0YG 1K0511115DF 1JA+0YH 1K0511115BL 1JA+0YJ 1K0511115BM 1JA+0YK 1K0511115BN 1JA+0YL 1K0511115BP 1JA+0YM https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/5 Octavia MK2 rear springs (car manufactured from 06.03.2006) (1JA=standard ride height) 1K0511115FT 1JA+0YA 1K0511115GA 1JA+0YB 1K0511115BC 1JA+0YC 1K0511115BD 1JA+0YD 1K0511115BE 1JA+0YE 1K0511115BF 1JA+0YF 1K0511115BG 1JA+0YG 1K0511115BH 1JA+0YH 1K0511115DE 1JA+0YJ 1K0511115DF 1JA+0YK 1K0511115BL 1JA+0YL 1K0511115BM 1JA+0YM https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/663/5
  20. All Superb MK3 models use the same 312x25mm front brake discs with TRW front brake calipers, except for the 272PS/280PS 4x4 models that use the bigger 340x30mm front brake discs. You can use any of the below three OEM part numbers because they all lead to the same aftermarket front brake pads. Brembo brake pads often don't do well in tests. ATE, TRW, Ferodo, Jurid, etc. are generally better. EBC DPX2150 are another good front brake pad which are available on ebay for about £60. However, TRW GDB1956 are available for about £33 including shipping to the UK on the German version of Amazon. OEM part numbers for front brake pads (312x25mm front brake discs) (Superb MK3) 5Q0698151AA 5Q0698151AH 8V0698151B TRW GDB1956 front brake pads for 312x25mm front brake discs (Superb MK3) https://www.amazon.de/TRW-GDB1956-GDB1956-LUC-FPS-Brake-Pads/dp/B0113713JA/ref=sr_1_1_sspa OEM part numbers 1K0615301AA and 5Q0615301F both lead to the same aftermarket front brake discs. OEM part numbers for front brake discs (312x25mm front brake discs) (Superb MK3) 1K0615301AA 5Q0615301F
  21. 225/45R18 is a standard Octavia MK4 tyre size, so a 225/45R17 tyre will have an outside diameter that is 1" too small for the Octavia MK4. 225/50R17 is suitable for 7Jx17 ET46 rims on the Octavia MK4, although it is not a Skoda approved tyre size. The 225/50R17 is used on the Yeti and Octavia MK2/3 Scout...all on 7Jx17 ET45 rims. So 1mm different from ET46. The standard 18" and 19" rims on the Octavia MK4 both have a specification of 7.5J ET48 for their 225 tyre sizes, ie. 225/45R18 and 225/40R19. ET46 is only 2mm different from ET48, which means that the centre of each tyre is pulled 2mm further out in each wheelarch...which gains you 4mm of extra track width. Considering that some owners fit 15mm spacers, which changes the offset by 15mm...ie. the ET48 offset would be effectively changed to ET33. So by comparison, a 2mm difference in offset is very small. If I was looking for new 17" alloy rims for the Octavia MK4, one of the specifications I would consider for a 225/50R17 tyre size is 7Jx17 ET45 because that's a common specification and fitted to the Octavia MK2/3 Scout, Karoq, and Yeti...and ET45 is still only 3mm different from ET48. My own view on changing offsets is 3mm less offset than standard is a small difference, 5mm less offset than standard is a modest difference, 7mm less offset than standard is generally the maximum I would consider, but up to 10mm less offset than standard in certain circumstances (such as if that was the only suitable rim for a certain tyre size that I wanted). In any case, the lowest offset I would consider for 5/100 hubs is ET28 and the lowest offset I would consider for 5/112 hubs is ET33...because those are the lowest offsets that VAG have used for those hubs.
  22. If the OEM part number 1K0511115BD is what the car left the factory with, then I suggest going up two in the hierarchy to 1K0511115BF. If you are going for aftermarket rear springs, then be careful with the selection because different brands will often have different ideas about what the specification of any OEM part number should be. Many aftermarket springs are sold to replace more than one OEM part number, so may be stiffer than the required spring. However, the below three Sachs springs are each listed to replace just one spring each...so should be an exact match. Have a look at the specification given by Sachs for 1K0511115BD, 1K0511115BE, and 1K0511115BF rear springs. 1K0511115BE is one up in the hierarchy compared to 1K0511115BD, and 1K0511115BF is two up in the hierarchy compared to 1K0511115BD. The increase in wire diameter from 11.25mm to 11.50mm gives an increase in spring stiffness of about 5%, whereas the increase in wire diameter from 11.25mm to 11.75mm gives an increase in spring stiffness of about 10%. gknautomotive lists the 1K0511115BF rear springs for the Octavia MK2 estate without towbar (front wheel drive including 1.2TSI, NOT 4x4), and gknautomotive lists the 1K0511115BG rear springs for the Octavia MK2 estate with towbar (front wheel drive including 1.2TSI, NOT 4x4). Sachs rear springs 1K0511115BD Length 352mm Wire diameter 11.25mm https://www.autodoc.co.uk/sachs/1232470#coil-spring Sachs rear springs 1K0511115BE Length 348mm Wire diameter 11.5mm https://www.autodoc.co.uk/sachs/7059747#coil-spring Sach rear springs 1K0511115BF Length 354mm Wire diameter 11.75mm https://www.autodoc.co.uk/sachs/1232501#coil-spring gknautomotive online spring catalogue https://web.tecalliance.net/gkn/en/home?sessionArticleCountry=GB&sessionTargetCountry=GB
  23. The standard 18" wheel size on the Octavia MK3 is 225/40R18 7.5Jx18 ET51 5/112 57.1 As you can see in the chart below the actual width of a 245/40R18 9J wheel is 30mm more than the standard 225/40R18 7.5J wheel, ie. 15mm more each side. So combined with the change in offset from ET51 to ET35...that's 31mm of extra space required on the outside compared to the standard 225/40R18 7.5Jx18 ET51 wheel. I doubt there is anything like that amount of space before rubbing occurs. Even the more modest 245/40R18 8Jx18 ET35 wheel size would need an extra 25mm on the outside compared to the standard 225/40R18 7.5Jx18 ET51 for rubbing not to occur. On some Skodas (not necessarily Octavia MK3) owners have managed to fit 15mm front spacers and 20mm rear spacers (using standard wheels) without rubbing. If there is that much space available, even 245/40R18 8J wheels wouldn't fit because they would need an extra 25mm of space on the outside compared to the standard 225/40R18 7.5Jx18 ET51 wheels. If you're keen on 245's, perhaps try 245/35R18 8Jx18 ET45 5/112 57.1 because that size would require a far more modest extra 15mm of space on the outside compared to the standard 18" wheels. The Alcar 9383 8Jx18 ET45 5/112 57.1 steel rim is available in that size, which could be used as a test bed and then a spare wheel if the trial and error is successful. The smaller outside diameter of 245/35R18 compared to 245/40R18 would make the front tyres less likely to rub on full lock. Also, the outside diameter of 245/35R18 is only 0.5% smaller than the standard 205/55R16 tyre size, whereas the outside diameter of 245/40R18 is a rather large 3.4% bigger than the standard 205/55R16 tyre size. Actual width of inflated tyre (measured from sidewall to sidewall, at the widest point) 225/40R18 fitted to 7.5J rim 224mm 235/40R18 fitted to 8J rim 235mm 245/35R18 fitted to 8J rim 242mm 245/40R18 fitted to 8J rim 242mm 245/40R18 fitted to 9J rim 254mm Alcar 9383 8Jx18 ET45 5/112 57.1 steel rim (from Skoda Enyaq, VW iD.4, VW iD. Buzz) (13.26kg) https://www.oponeo.pl/felga-stalowa/alcar-kfz-9383#23664146 Outside diameter of tyre 205/60R15 627mm (Octavia MK1 tyre size, possible alternative to 195/65R15) 195/70R14 628.6mm (Octavia MK1 tyre size, possible alternative to 175/80R14) 245/35R18 628.7mm (not standard on Octavia MK3) 225/50R16 631.4mm (not standard on Octavia MK3) 205/55R16 631.9mm 225/45R17 634.3mm 195/65R15 634.5mm 175/80R14 635.6mm (Octavia MK1 tyre size) 205/50R17 636.8mm 225/40R18 637.2mm 225/35R19 640.1mm 215/55R16 642.9mm (not standard on Octavia MK3) 235/45R17 643.3mm (not standard on Octavia MK3) 235/40R18 645.2mm (not standard on Octavia MK3) 215/50R17 646.8mm (not standard on Octavia MK3) 235/35R19 647.1mm (not standard on Octavia MK3) 205/65R15 647.5mm (not standard on Octavia MK3) 205/60R16 652.4mm (Octavia MK3 Scout winter tyre size) 245/40R18 653.2mm (not standard on Octavia MK3) 225/50R17 656.8mm (Octavia MK3 Scout tyre size) 205/55R17 657.3mm (Octavia MK3 Scout winter tyre size)
  24. The standard 16" wheel (215/60R16 6.5Jx16 ET41) only lifts the carpet up about 6mm, so a 215/60R16 6Jx16 ET43 should be sufficient to get a level carpet. One owner fitted a 205/65R16 6.5Jx16 ET41 without problems. 215/60R16 6Jx16 ET43 is the same width, so should also fit without problems. The 2mm greater offset should also help, because if the toolkit is resting on the back of the rim that will free up an additional 2mm of space. As you can see in the chart below, a 205/65R16 fitted to a 6.5J rim is the same width as a 215/60R16 fitted to a 6J rim. Actual inflated width of tyre (measured from sidewall to sidewall, at the widest point) 205/65R16 fitted to 6J rim 209mm 205/65R16 fitted to 6.5J rim 215mm 215/60R16 fitted to 6J rim 215mm 215/60R16 fitted to 6.5J rim 221mm
  25. I suspect the tyre on that ebay listing is a budget tyre, which are in general best avoided. Reasonable quality tyres aren't always expensive, with Camskill listing Kumho ES31 and Kumho HS52 in size 215/60R16 94V for about £68. My preference for a spare for the Superb MK3 FWD (not 4x4) would be something like Vredestein Ultrac+ in size 215/60R16 94V. It's listed on Camskill for about £20 more than the above mentioned Kumho tyres. Being winter, steel rims are currently more than summer prices...with the Alcar 6665 6Jx16 ET43 5/112 57.1 steel rim being listed on mytyres for about £76 including shipping to the UK. Come spring/summer I expect this price will drop a lot. The reason for the high price of steel rims in the winter, is because of the high demand for winter tyres. The weight of a 6Jx16 ET43 5/112 57.1 steel rim (from Karoq) is about 7.60kg, whereas the weight of a 6.5Jx16 ET41 5/112 57.1 alloy rim (from Superb MK3) is about 9.9kg. So that's 2.3kg more, which is about 30% more. When it comes to weight, the 18" alloy rims are often over 12kg and the 19" alloy rims are often over 14kg. So the 7.60kg steel rim is quite light weight by comparison. Vredestein Ultrac+ 215/60R16 94V (Euro label B A 69dB) https://www.camskill.co.uk/m62b0s111p227471/Vredestein_Tyres_Car_Vredestein_Ultrac%2B_215_60_R16_95V_TL_Fuel_Eff_%3A_B_Wet_Grip%3A_A_NoiseClass%3A_B_Noise%3A_69dB Alcar 6665 6Jx16 ET43 5/112 57.1 steel rim (from Karoq) (Weight=7.60kg) https://www.mytyres.co.uk/rims/details?vehicleId=1284041564754023536&rimCode=ALCAR6665 6.5Jx16 ET41 5/112 57.1 alloy rim NYOTA (from Superb MK3) (Weight=9.9kg) Alu kolo Nyota 16 Superb IIIRozměr ráfku: 6,5J x 16“ ET 41
