Carlston
Everything posted by Carlston
  1. Is there a white tyre pressure label inside the fuel filler flap? You need about 0.2Bar (3psi) more than you would use for 195/65R15, 205/55R16, 225/45R17 size tyres. If you need to use more than 3Bar (44psi) make sure the tyres are XL eXtra Load.
  2. Skoda will often fit stiffer rear springs if the car has a factory fitted towbar, often two weight ranges stiffer.
  3. See my previous post about changing the Superb MK3 front springs to VW Passat B8 front springs. A solution without compromise (or almost).
  4. On the Superb MK3, 3Q0511115N rear springs and 215/55R17 tyres will be more comfortable than 3Q0511115M rear springs and 235/45R18 tyres, ie. the tyre size will make more difference to ride comfort than this small change in rear spring stiffness. An alternative to changing the rear springs is to change the front springs...perhaps by using 10mm shorter front springs with the same stiffness. This will help to balance the sagging rear springs while towing. The VW Passat B8 sometimes uses 10mm shorter front springs compared to the Superb MK3. However, it's easier to change the rear springs than the front springs. Kilen list 5Q0411105GN for the front springs on the standard ride height Superb MK3 2.0TDI 4x4 estate, and 5Q0411105CH for the front springs on the standard ride height VW Passat B8 2.0TDI 4x4 estate. From the specifications on autodoc 5Q0411105CH front springs are just over 10mm shorter than 5Q0411105GN front springs and the same stiffness. This will lower the front of the Superb MK3 2.0TDI 4x4 estate by just over 10mm and keep the ride comfort the same, and help to balance out the sagging rear end when towing a caravan. Superb MK3 2.0TDI 4x4 estate front springs 5Q0411105GN https://www.autodoc.co.uk/car-parts/oem/5q0411105gn?search=OEN+5Q0411105GN&supplier[0]=32&supplier[1]=85&supplier[2]=112&supplier[3]=246 VW Passat B8 2.0TDI 4x4 estate front springs 5Q0411105CH https://www.autodoc.co.uk/car-parts/oem/5q0411105ch?search=OEN+5Q0411105CH&supplier[0]=32&supplier[1]=85&supplier[2]=112&supplier[3]=246&supplier[4]=246&supplier[5]=32&supplier[6]=85&supplier[7]=112 Whatever springs you fit, there are always compromises. This includes the springs that new Skodas are fitted with. Although with the change from Superb MK3 front springs to VW Passat B8 front springs, maybe there isn't in this case.
  5. You could fit a slightly stiffer rear spring. If you've currently got 3Q0511115M rear springs, then 3Q0511115N will stop the rear end sagging so much while towing. Unlike alternative options, changing the rear springs from 3Q0511115M to 3Q0511115N won't increase the unladen ride height. Kilen 65127 or KYB RA5338 would be a good choice to match 3Q0511115N because they are reliable and economical. 3Q0511115N rear springs Kilen 65127 https://www.autodoc.co.uk/kilen/12865401 https://www.ebay.co.uk/itm/393379354984?epid=251920479&hash=item5b973c9968:g:2WIAAOSwxzJiMbDt&amdata=enc%3AAQAHAAAAoHOib0f1G4EzoNdQKZh52%2BdaYytaVdRQ9kjWTDvnZcou5iTxNRJNPAqom1DZExlvgty5JJCeb4Tujabg2eeqNMkhOCuylUbtDYHaUtNDaQ8%2Bof7RAi4E9WOqYKE5hfAWTNK6RiGflFC7k0iL6m1GzLOcE8nH45btO6g4kVKxDmcwe3SQOV0WVCVrL%2BnlonekGNDo%2BqiAjZObA0qqiUy%2Bwpk%3D|tkp%3ABk9SR6KHuePcYA KYB RA5338 https://www.autodoc.co.uk/car-parts/oem/3q0511115n?search=OEN+3Q0511115N https://www.ebay.co.uk/itm/334488105247?hash=item4de10b711f:g:qdEAAOSwLr5iu7wL&amdata=enc%3AAQAHAAAAoOUFIMaiK6NZFmGMwr1dy%2B4TGrEO1JnRxxepP1AS0o5vrzZkgnpC9NL%2B48R5vV3ZjKq1%2FeWx%2FPmrAWiOH%2FXdzOX1%2Fe4fzOiWcOdhiB8B2q3h16R7ye%2BVwFwCMkZPgdOk6P%2BRjv6f1rndl5zxjIkXPQ%2Fdi8VBEAw%2FIkWB1bjjbYxlDvr5kk5Lh2Q77THxJfTWHSbaFNJyXI3uhxLGAUpxjM0%3D|tkp%3ABk9SR6KHuePcYA As you can see in the chart below, build code 1JA+0YE means that you would have rear springs with OEM part number 3Q0511115M. Build code 1JA means the car has standard ride height. Rear coil springs for Superb MK3 2.0TDI 4x4 estate 1 3Q0511115AH Coil spring 2 PR-1JA+0YA 1 3Q0511115AJ Coil spring 2 PR-1JA+0YB 1 3Q0511115AK Coil spring 2 PR-1JA+0YC 1 3Q0511115AL Coil spring 2 PR-1JA+0YD 1 3Q0511115M Coil spring 2 PR-1JA+0YE 1 3Q0511115N Coil spring 2 PR-1JA+0YF 1 3Q0511115P Coil spring 2 PR-1JA+0YG 1 3Q0511115Q Coil spring 2 PR-1JA+0YH 1 3Q0511115R Coil spring 2 PR-1JA+0YJ 1 3Q0511115BC Coil spring 2 PR-1JA+0YK https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511005
  6. There's an ebay seller who can send you all your build codes for about 3 Euros. Search "skoda factory options decoder" to find the listing.
  7. It's not about what size spacers, but what offset to use. Spacers change the offset of a rim. So if you have rims with an offset of ET51 and use 10mm spacers, that would change the effective offset of those rims to ET41. If you have rims with an offset of ET54 and used 15mm spacers, that would change the effective offset of those rims to ET39. Using spacers with an offset of less than 10mm is a bad idea, because you can't get spacers that are hubcentric if they are less than 10mm. Hubcentric spacers centre the rim on the hub, thereby helping to prevent vibration. Avoid spacers that are not hubcentric, ie. don't centre the rim on the hub, as this can lead to wheel vibration. The offset of standard rims on the Octavia MK2 range from ET47 to ET54. For the front rims, it's important to keep near to the design offsets or you can get problems with the steering such as bump steer. Using an offset within the standard range will mean that when you turn the steering wheel the front tyres pivot on the centre of the tread. By using offsets outside the design limits, the front tyres will be dragged sidewalls when you turn the steering wheel rather the pivoting on their centre. Power steering might not let you feel this happening, but if you didn't have power steering the steering feel when you turned the steering wheel at low speed might not feel good. I suggest you keep to offsets between ET42 and ET54, perhaps by using rims that have the offset that you want rather than using spacers. Here are some 8Jx18 ET44 alloy rims from the VW EOS, perhaps used in combination with 225/40R18 tyres. 225/40R18 fitted to 8J rims won't give much protection from kerbing damage, and the low profile tyres fitted to the relatively wide 8J rims won't give you much comfort. 8Jx18 ET44 5/112 57.1 alloy rims (from the VW EOS) 3C0601025AN 3AA601025L 3AA601025H 3C0601025AP 3C0601025AC 3C0601025BA 1 3C0601025AN Aluminium rim 'CHICAGO' 8 JX18H2 ET44 5/112 4 PR-CH8 - 3C0601025AN16Z Grey metallic 1 3AA601025L Aluminium rim 'VICENZA' 8 JX18H2 ET44 5/112 4 PR-C0J 3AA601025L AX1 black-glossy 1 3AA601025H Aluminium rim 'KANSAS' 8 JX18H2 ET44 5/112 4 PR-C1Q 3AA601025H 88Z Diamond silver 1 3C0601025AP Aluminium rim 'BUDAPEST' 8 JX18H2 ET44 4 PR-F30 3C0601025APAX1 black-glossy 1 3C0601025AC Aluminium rim 'VERACRUZ' 8 JX18H2 ET44 4 PR-CC9 3C0601025AC88Z Bright chrome 1 3C0601025BA Aluminium rim 'SARMAKAND' 8 JX18H2 ET44 4 PR-CH9 3C0601025BAQQ9 Titanium (grey) https://www.lllparts.co.uk/catalogs/vw/RDW/EOS/712/6/601/601065
  8. On that ebay listing, the seller claims those rear shock absorbers have OEM part number 3Q0513045AD and 3Q0512009AF. It can't be both, it's either one or the other. The seller has also stuck new white sticky labels on them showing 3Q0512009AF. This isn't the correct OEM part number for the Superb MK3, and even if it was you would need to see that the OEM part number was stamped into the metal of the shock absorbers to prove that the shock absorbers really had that OEM part number. The seller also claims that mileage is both 19,845km and 24,600km and the age is both 2018 and 2019. which seem very low for a 3 or 4 year old car. Who knows what the mileage really is, and how old the car they came off really is. At least in the UK, you could ask for registration number of the car they came off and check the MOT history for the mileage, although that wouldn't prove that they really did come off that car. Why did the owner of the car change them. He clearly wouldn't have gone to the massive expense of replacing them if he was happy with them. The seller claims that they are for a Superb MK3 and a VW Passat B8. These cars use different OEM part numbers for the rear shock absorbers, and are not the same. The seller sticking new white sticky labels on both rear shock absorbers is a red flag. Perhaps he is deliberately hiding the real OEM part number underneath.
  9. You might find it interesting to look again at the TRW BHN952 listing on autodoc. But this time change the car from Octavia MK2 2.0TDI 170HP RS to VW Golf MK5 2.0 petrol GTI 200HP. The below information comes up. Notice that this time the build code is shown as 1KY. The same build code is also shown when the car is changed to Seat Leon II 2.0 petrol CUPRA R 265HP. More importantly for these VW and Seat models, the OEM part numbers are also correct, which isn't the case for the Skoda. TRW BHN952 Brake Caliper Rear Axle Right Article number: BHN952 Fitting Position:Rear Axle Right for PR number:1KY Brake Caliper Type:Fist-type Caliper, Brake Caliper with integrated parking brake Material:Aluminium Manufacturer Restriction:TRW paired article number:BHN951 Brake Caliper Colour:Red Piston Diameter [mm]:38 TRW:Brake Caliper Item number:BHN952 Our price:95,14 £ Manufacturer part number:BHN952 Manufacturer:TRW EAN number:3322937794454 Condition New https://www.autodoc.co.uk/trw/2184172?search=TRW Brake Caliper (BHN952)
  10. TRW is probably where autodoc got the mistake from. autodoc simply repeated TRW's mistake on their website. autodoc don't make up all these details themselves, they import them from the various aftermarket parts' brands. It's a bit like the old computer saying...garbage in, garbage out. Using the number plate or even the VIN on one of these online aftermarket parts' websites is a recipe for disaster. The number of mistakes that these websites make is legendary. I always search using the correct OEM part number. That's the most reliable way to find the correct aftermarket parts. Even then, you need to be wary of aftermarket parts that are sold to replace more than one OEM part number as this could mean that the aftermarket part isn't an exact match to the OEM part number. Caveat emptor, as they say in Latin.
  11. The 340mm front brakes on the Octavia MK3 RS is a TRW brake system. 8V0698151C front brake pads with wear indicator for 340x30mm front brake discs https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/753/6/615/615040 TRW GDB2114 front brake pads for 340mm front brake discs on the Octavia MK3 8V0698151C https://www.autodoc.co.uk/trw/11288579
  12. Here is autodoc's incorrect claim that TRW BHN952 (38mm piston) is for build code 1KP. You can see from the OEM part numbers at the bottom of this autodoc listing that it is sold to replace 1K0615424F and 1K0615424P (38mm piston). The Octavia MK2 with build code 1KP uses OEM part numbers 1Z0615424, 1Z0615424A, and 1K0615424M (41mm piston). TRW BHN952 Brake Caliper Rear Axle Right Article number: BHN952 Fitting Position:Rear Axle Right for PR number:1KP Brake Caliper Type:Fist-type Caliper, Brake Caliper with integrated parking brake Material:Aluminium Manufacturer Restriction:TRW paired article number:BHN951 Brake Caliper Colour:Red Piston Diameter [mm]:38 TRW:Brake Caliper Item number:BHN952 Our price:95,28 £ Manufacturer part number:BHN952 Manufacturer:TRW EAN number:3322937794454 Condition New OEM reference number(s) comparable with the original spare part number OEN 1K0 615 424 F — SEAT OEN 1K0 615 424 P — SEAT OEN 1K0 615 424 F — SKODA OEN 1K0 615 424 P — SKODA OEN 1K0 615 424 F — VW OEN 1K0 615 424 P — VW https://www.autodoc.co.uk/trw/2184172?search=TRW Brake Caliper (BHN952)
  13. If you search for any of the below three OEM part numbers on autodoc, you will see that they all use 41mm pistons. OEM part numbers for right rear brake caliper on Octavia MK2 RS 1Z0615424 (mint green colour) (41mm piston) https://www.autodoc.co.uk/car-parts/oem/1z0615424?search=OEN 1Z0615424 1Z0615424A (red colour) (41mm piston) https://www.autodoc.co.uk/car-parts/oem/1z0615424a?search=OEN 1Z0615424A 1K0615424M (standard colour) (41mm piston) https://www.autodoc.co.uk/car-parts/oem/1k0615424m?search=OEN+1K0615424M&page=3 Octavia MK2 RS rear brake calipers 1KP 1 1Z0615424 Brake caliper housing mint green right painted 1 1 1Z0615424A Brake caliper housing red right painted 1 1 1K0615424M Brake caliper housing right 1 Skoda parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/6/615/615062 The TRW BHN952 (38mm piston) and TRW BHS325 (41mm piston) rear calipers are very similar except for the piston diameter and colour. They are so similar that they even use the same brake pads, the same brake caliper carrier, and the same discs. The 38mm piston version is used on cars such as the VW Golf MK5 GTI. The 41mm piston version is used on cars such as the Octavia MK2, Superb MK2, and Yeti. The 38mm piston version does not have build code 1KP, although autodoc has made a mistake on one of its listings and incorrectly claims that it does have build code 1KP. TRW BHN952 rear brake caliper (38mm piston) (sold to replace 1K0615424F 1K0615424P) https://www.autodoc.co.uk/trw/2184172?search=TRW Brake Caliper (BHN952) TRW BHS325 rear brake caliper (41mm piston) (sold to replace 1K0615424M) https://www.autodoc.co.uk/trw/2184819
  14. The rear brake calipers with build code 1KP have 41mm pistons. TRW BHN952 has a 38mm piston, and is sold to replace OEM part numbers 1K0615424F and 1K0615424P. Build code 1KP doesn't use either of those OEM part numbers.
  15. TRW left rear brake caliper 1K0615423M 1KP https://www.autodoc.co.uk/trw/2184817 TRW right rear brake caliper 1K0615424M 1KP https://www.autodoc.co.uk/trw/2184819 Skoda parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/419/6/615/615062 1K0615423M 1Z0615423 1Z0615423A are the same except for the colour. 1K0615424M 1Z0615424 1Z0615424A are the same except for the colour. These OEM part numbers are correct for an Octavia MK2 that has build code 1KP for the rear brakes. The Skoda parts catalogue lists the 1KP build code for the RS, and 1KP is for the biggest 282x12mm rear brake discs. So there seems little doubt that build code 1KP is what the RS has.
  16. Bilstein B4 DampTronic 23-238978 front shock absorbers sold to replace the following OEM part numbers on the Superb MK3: 3Q0413031AK 3Q0413031BE 3Q0413032 3Q0413032A These appear to be all of the OEM part numbers on the Superb MK3 with electronically controlled front shock absorbers https://www.autodoc.co.uk/bilstein/7949490 Bilstein B4 DampTronic 20-267520 rear shock absorbers sold to replace the following OEM part numbers on the Superb MK3: 3Q0513045AA 3Q0513045AC 3Q0513045AD Note that the 3Q0513045AJ and 3Q0513045AT OEM part numbers aren't listed against these Bilstein B4 DampTronic 20-267520 rear shock absorbers, so if your Superb MK3 has build code UC9 or 1JL these might not be suitable. See the extract from the Skoda parts catalogue below. https://www.autodoc.co.uk/bilstein/12775653 Superb MK3 electronically controlled rear shock absorbers (extract from Skoda parts catalogue) 7 3Q0513045AA Gas shock absorber, electronically controlled 2 PR-1JP+1X1 7 3Q0513045AD Gas shock absorber, electronically controlled 2 PR-1JP+1X1 7 3Q0513045AC Gas shock absorber, electronically controlled 2 PR-1JP+1X0 7 3Q0513045AJ Gas shock absorber, electronically controlled 2 PR-UC9 7 3Q0513045AT Gas shock absorber, electronically controlled 2 PR-1JL https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511010 VW Codes Decoder 1X1 = Four wheel drive 1X0 = Front wheel drive http://igorweb.org/equidec.aspx
  17. Michelin CrossClimate 2 has the 3PMSF symbol, so is officially a winter rated tyre. Winter rated tyres can have a lower speed rating than the maximum speed of the car. However, that's academic with the Michelin CrossClimate 2 as 225/50R17 98V XL (Euro label B B 71dB) is the lowest speed rating for this tyre. Michelin CrossClimate 2 as 225/50R17 98V XL (Euro label B B 71dB) https://www.blackcircles.com/catalogue/michelin/crossclimate-2/225/50/R17/V/98/m?tyre=42160812 By using a 98Y XL in that size, you are over-specifying the tyre. This means that the tyre will be stiffer and heavier than it needs to be, resulting in a reduction in ride comfort, ie. the ride will be harder. If you look at the winter tyres in size 225/50R17 that are listed on camskill, you will see that none have a speed index greater than V (240km/h, 150mph). This isn't surprising, as if you drive at 168mph or 186mph on winter tyres on a hot summer's day they are likely to overheat and fail. 225/50R17 winter tyres listed on camskill https://www.camskill.co.uk/m97b0s1472p0/Winter_-_Snow_-_Cold_Weather_-_Car_MPV_Tyres_-_17_inch_R17_inch_-_225_50_17_225_50R17
  18. They certainly are much cheaper and according to a Kamiq owner (on the below thread) who has tried all three standard sizes, ie. 205/60R16, 205/55R17, 215/45R18, much more comfortable. Vredestein Quatrac 205/60R16 96H XL https://www.camskill.co.uk/m139b0s8005p201101/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac_6_-_205_60_R16_96H_XL_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_B_NoiseClass%3A_B_Noise%3A_70dB
  19. Here's a previous thread where a Kamiq owner was very pleased with the ride improvement when he changed from 215/45R18 tyres to 205/55R17 tyres. Can I change from 18" wheels to 16" wheels?
  20. Anyone who drives across muddy fields and muddy tracks in the summer could get stuck if they don't have all-terrain tyres. For winter it's probably best to change to something with the 3PMSF symbol. All-terrain tyres don't appear to be available in the 205/60R16, 205/55R17, and 215/45R18 tyre sizes...at least not Bridgestone or Yokohama.
  21. Although you still feel the road surface with 205/60R16 and 205/55R17 tyres, compared to 215/45R18 these bigger sidewalled tyre sizes will make the road bumps feel softer, ie. give a better ride. Keep going to even higher sidewalled 205/70R15 tyres, perhaps fitted to 6Jx15 ET35 or 6Jx15 ET38 rims, and the Kamiq could start to ride like a Rolls Royce. Compared to the 205/70R15 tyre size, the 215/45R18 tyre size is often twice the price. Vredestein Quatrac 5 205/70R15 96T (all-season tyre with the 3PMSF symbol, so good all year round including snow) https://www.camskill.co.uk/m138b0s7998p144823/Vredestein_Tyres_All_Season_Car_Vredestein_Quatrac5_Vredestein_Quatrac_5_-_205_70_R15_96T_TL_Fuel_Eff_%3A_C_Wet_Grip%3A_C_NoiseClass%3A_A_Noise%3A_69dB Yokohama Geolander A/T G015 205/70R15 96H (all-terrain tyre, so good on muddy tracks where normal road tyres can really struggle, ie. get stuck) https://www.blackcircles.com/catalogue/yokohama/geolandar-at-g015/205/70/R15/H/96/m?tyre=35841793 6Jx15 ET35 5/100 57.1 steel rim https://www.oponeo.pl/felga-stalowa/vw-w21-19547013091#20860106 6Jx15 ET38 5/100 57.1 alloy rims (from the Fabia MK3) https://eshop.skoda-auto.cz/cs_CZ/hlinikove-disky/c/alloyWheels?q=%3ApriceAsc%3AcarType%3AFabia%2BIII%2B%282014%2B%29&text=# The Kamiq uses 256mm or 276mm diameter front brakes discs, so 15" wheels will clear the front brake calipers on all models. The 205/70R15 tyre size was fitted to late model Jaguar E-type cars and early model Jaguar XJS cars. Jaguar E-type https://en.wikipedia.org/wiki/Jaguar_E-Type#/media/File:1972_Jaguar_E-Type_Series_3_5.3_Front.jpg Jaguar XJS https://en.wikipedia.org/wiki/Jaguar_XJS#/media/File:1989_Jaguar_XJS_Convertible_in_Signal_Red,_front_left.jpg
  22. All fast fit tyre places use a wheel balancer that dynamically balances the wheel. Using a dynamic wheel balancing machine is very simple, as the machine tells the operator where to put the wheel weights. If the wheel balancer is spinning the wheel around using an electric motor to work out where the two wheel weights need to go, then that is dynamic balancing.
  23. The Superb MK2 normally uses a 7Jx16 ET45 rim for its 205/55R16 tyre size. However, compared to a 225/45R17 tyre the 205/55R16 option can look a bit sunken in the wheelarch. Therefore, other rims that you might want to consider include the 6Jx16 ET40 rim from the Superb MK1 and the 6.5Jx16 ET41 rim from the Superb MK3. 6Jx16 ET40 5/112 57.1 steel rim (from the Superb MK1) https://www.mytyres.co.uk/rims/details?vehicleId=180495828815717488&rimCode=ALCAR9490 6.5Jx16 ET41 5/112 57.1 steel rim (from the Superb MK3) https://www.mytyres.co.uk/rims/details?vehicleId=1035468374024787056&rimCode=ALCAR8426 Superb MK2 16" alloy rims 1 3T0601025 Aluminium rim 7JX16 ET45 4 SPECTRUM - 3T0601025 7ZS chrome coloured metallic 2 3T0601025N Aluminium rim 7JX16 ET45 4 MOON 3T0601025N 7ZS chrome coloured metallic https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601060 Superb MK2 16" steel rims 1 3C0601027M Steel rim 7JX16H2 ET45 5/112 4 PR-CH3 - 3C0601027M 03C rally black - 1 3C0601027AQ Steel rim 7 JX16H2 ET45 5/112 4 - 3C0601027AQ03C rally black https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601010 Superb MK2 17" alloy rims 1 3T0601025B Aluminium rim 7JX17 ET49 4 VENUS - 3T0601025B 7ZS chrome coloured metallic 2 3T0601025C Aluminium rim D >> - 29.05.2011 7,5JX17 ET49 4 CALLISTO 3T0601025C 7ZS chrome coloured metallic D >> - 29.05.2011 2 3T0601025CA Aluminium rim D - 30.05.2011>> 7,5JX17 ET49 4 CALLISTO PR-C4F 3T0601025CAHA7 Anthracite metallic (grey) D - 30.05.2011>> 3 3T0601025D Aluminium rim 7,5JX17 ET49 4 TRIFID 3T0601025D 7ZS chrome coloured metallic 5 3T0601025G Aluminium rim 7,5JX17 ET49 4 LAUREL 3T0601025G 7ZS chrome coloured metallic https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/632/6/601/601070
  24. Skoda engine code decoder CHHB 2.0 petrol 162kW/220HP CJSA 1.8 petrol 132kW/180HP CJSC 1.8 petrol 132kW/180HP CRGA 2.0 diesel 130kW/177HP CRLB 2.0 diesel 110kW/150HP CZCA 1.4 petrol 92kW/125HP CZDA 1.4 petrol 110kW/150HP CZEA 1.4 petrol 110kW/150HP DCXA 1.6 diesel 88kW/120HP DCZA 1.6 diesel 88kW/120HP DDAA 2.0 diesel 140kW/190HP https://vag-codes.info/files/engines/skoda-engines.pdf
  25. Front stabilizer (anti-roll bar) for Superb MK3 3Q0411303 310411303C 3Q0411303D 16 3Q0411303 stabilizer, complete 24,0X3,8 1 PR-1X0 16 3Q0411303C stabilizer, complete 24,0X3,8 1 PR-1X1 16 3Q0411303D stabilizer, complete 25X4 1 PR-1X1+DF5, D14 1X0=FWD 1X1=4x4 D14=200kW/272HP engine DF5=206kW/280HP engine https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000 Rear stabilizer (anti-roll bar) for Superb MK3 FWD 5Q0511305AR 5Q0511305AS 5Q0511305AT 5Q0511305BA 16 5Q0511305AR Anti-roll bar 19,6X2,6 rear 1 PR-1X0+0BD 16 5Q0511305AS Anti-roll bar 20,7X2,8 1 CZCA,CZDA, CZEA,CJSA, CJSC,DCXA+ PR-1JA 16 5Q0511305AT Anti-roll bar 21,7X3,0 1 CHHB,CRLB, DDAA+ PR-1JA 16 5Q0511305AT Anti-roll bar 21,7X3,0MM rear 1 PR-UC7 16 5Q0511305AT Anti-roll bar 21,7X3,0 1 CZCA,CZDA, CZEA,CJSA, CJSC,DCXA+ PR-1JC 16 5Q0511305AT Anti-roll bar 21,7X3,0MM rear 1 PR-1JP 16 5Q0511305BA Anti-roll bar 21,7X3,6MM rear 1 PR-1JC CHHB,CRGA, 16 5Q0511305BA Anti-roll bar 21,7X3,6MM rear 1 PR-UC7 CHHB https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/501/501020 Rear stabilizer (anti-roll bar) for Superb MK3 4x4 3Q0511305 3Q0511305B 5Q0511305BC 5Q0511305BE 16 5Q0511305BE Anti-roll bar 21,7X3,0 rear 2 PR-1JA,UC7, 1JC+1X1 16 3Q0511305 Anti-roll bar 21,7X3,6 rear 1 PR-1JC+K8D 16 3Q0511305B Anti-roll bar D >> - 18.05.2015 21,7X3,0 rear 1 PR-1JA,1JP, UC7+K8D 16 5Q0511305BC Anti-roll bar 19,6X2,6 rear 1 PR-1JI,1JA+ 1X1+DE5,DG6, DN4 16 5Q0511305BC Anti-roll bar 19,6X2,6 rear 1 PR-1JP+1X1+ DE2,DE5,DF4, DG6,DN4,DN8, D33,D60 16 5Q0511305BE Anti-roll bar 21,7X3,0 rear 2 PR-1X1+1JP+ D14,DF5 16 5Q0511305BE Anti-roll bar 21,7X3,0 rear 2 PR-1JI+K8D+ 1X1+DF5 https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/501/501030 VW Codes Decoder 0BD = Rear stabilizer 1JA = Rear shock absorption, basic design 1 1JC = Rear shock absorption for sports design 1JP = Rear shock absorption 1X0 = Front wheel drive 1X1 = Four wheel drive D14 = 4-cyl. SI engine 2.0 l/200 kW 16V turbo FSI, homogeneous base engine is TA2/TT6 DE2 = 4-cyl. turbo dies. eng. 2.0 l/130 kW 4V TDI common rail Base engine TR1,TD1,TM4/TL4/TP4 DE5 = 4-cyl. turbo dies. eng. 2.0 l/140 kW 4V TDI common rail Base engine is TD1 DF4 = 4-cyl. SI engine 1.8 l/132 kW TFSI, homogeneous base engine is TA8/T1L DF5 = 4-cyl. gasoline engine 2.0 l/206 kW TFSIhomogeneous Base engine is TT6 DG6 = 4-cyl. SI engine 1.4 l/110 kW TSI base engine is TL9 DN4 = 4-cyl. turbo dies. eng. 2.0 l/110 kW 4V TDI common rail Base engine is TS1/TR1 D33 = 4-cyl. gasoline engine 1.4 l/92 kW 4V TFSI Base engine is TU0/TL1 D60 = 4-cyl. SI engine 2.0 l/162 kW 16V turbo FSI, homogeneous base engine is T61,TW6,TP6,T1P K8D = Station Wagon Variant/Avant UC7 = Rear shock absorption, chassis with increased ride height http://igorweb.org/equidec.aspx
