Carlston
Everything posted by Carlston
  1. I would let the Skoda parts department supply the correct part based on the car's VIN number. Sometimes the parts are updated with a new OEM part number. It depends what their VAG system shows.
  2. The facelift Scout should have the same ride height as the pre-facelift Scout. Maybe try fitting new springs and/or shock absorbers. This chart may help you with rear springs, as aftermarket Octavia MK2 Scout rear springs are often cheaper than the equivalent aftermarket Octavia MK3 Scout rear springs. Octavia MK2 Scout rear springs that are equivalent to Octavia MK3 Scout rear springs 1K0511115CR is the same as 5Q0511115AL (Wire Diameter 12.5mm, Length 378-380mm, Outer Diameter 114-115mm, Weight 2.4-2.45kg) 1K0511115CS is the same as 5Q0511115AM (Wire Diameter 12.75mm, Length 382-383mm, Outer Diameter 117mm, Weight 2.6kg) 1K0511115CT is the same as 5Q0511115AN (Wire Diameter 13mm, Length 382-383mm, Outer Diameter 117-118mm, Weight 2.75-2.8kg) Kilen 65073 and Lesjofors 4295087 are sold to replace both 1K0511115CS and 5Q0511115AM rear springs. Hence, why these Octavia MK2 Scout and Octavia MK3 Scout rear springs are interchangeable. Kilen 65073 and Lesjofors 4295087 1K0511115CS 5Q0511115AM https://www.autodoc.co.uk/car-parts/oem/1k0511115cs?search=OEN+1K0511115CS&supplier[0]=253&supplier[1]=246 Octavia MK3 Scout 5Q0411105HS front springs https://www.autodoc.co.uk/eibach/18112496 Octavia MK2 Scout 1K0511115CT rear springs (equivalent to Octavia MK3 Scout rear springs 5Q0511115AN) https://www.autodoc.co.uk/eibach/13828886 If you want new Scout shock absorbers, it might be best getting OEM Skoda ones as aftermarket might not be a good match to the original shock absorbers. This is because aftermarket shock absorbers are geared to the standard ride height market, so aftermarket increased ride height shock absorbers will often just be standard ride height shock absorbers. You can tell by looking at the huge number of OEM part numbers that the aftermarket shock absorber is being sold to replace.
  3. 5Q0413031FS front shock absorber G10 (8) 5Q0 413 031 FS gas shock absorber 54,6MM 2 PR-G10 1K0412303H 90mm rubber stop for shock absorber G10 3 1K0 412 303 H rubber stop for shock absorber 90MM 2 PR-G10 Ride height is measured from the centre of the wheel to the bottom of the wheelarch, when the car is unladen. This measurement allows you to compare with Skoda's official measurements, and see whether the unladen ride height is within specification, eg. whether the springs/shock absorbers are sagging.
  4. By reference to aftermarket spring catalogues you can work out some OEM part numbers for the Octavia MK3 2.0TDI 4x4 front springs. These include standard ride height front springs, reduced ride height front springs, and increased ride height front springs. Kilen spring catalogue https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp KYB spring catalogue https://kyb-europe.com/catalogue/ gknautomotive spring catalogue https://web.tecalliance.net/gkn/en/home?sessionArticleCountry=GB&sessionTargetCountry=GB Standard ride height front springs for Octavia MK3 2.0TDI 4x4 5Q0411105GL L06 https://www.autodoc.co.uk/car-parts/oem/5q0411105gl?search=OEN+5Q0411105GL 5Q0411105GM L07 https://www.autodoc.co.uk/car-parts/oem/5q0411105gm?search=OEN+5Q0411105GM 5Q0411105GN L08 https://www.autodoc.co.uk/car-parts/oem/5q0411105gn?search=OEN+5Q0411105GN (1) 5Q0 411 105 GL coil spring 1 paint mark 1 paint mark blue brown 2 PR-L06 (1) 5Q0 411 105 GM coil spring 1 paint mark 1 paint mark blue grey 2 PR-L07 (1) 5Q0 411 105 GN coil spring 1 paint mark 1 paint mark green white 2 PR-L08 Reduced ride height front springs for Octavia MK3 2.0TDI 4x4 5Q0411105HE L18 https://www.autodoc.co.uk/car-parts/oem/5q0411105he?search=OEN+5Q0411105HE 5Q0411105HF L19 https://www.autodoc.co.uk/car-parts/oem/5q0411105hf?search=OEN+5Q0411105HF (1) 5Q0 411 105 HE coil spring 1 paint mark 1 paint mark brown yellow 2 PR-L18 (1) 5Q0 411 105 HF coil spring 1 paint mark 1 paint mark brown orange 2 PR-L19 Increased ride height front springs for Octavia MK3 2.0TDI 4x4 5Q0411105HR L30 https://www.autodoc.co.uk/car-parts/oem/5q0411105hr?search=OEN+5Q0411105HR 5Q0411105HS L31 https://www.autodoc.co.uk/car-parts/oem/5q0411105hs?search=OEN+5Q0411105HS (1) 5Q0 411 105 HR coil spring 1 paint mark 1 paint mark grey violet 2 PR-L30 (1) 5Q0 411 105 HS coil spring 1 paint mark 1 paint mark grey blue 2 PR-L31 5Q0411105KM, 5Q0411105KN, and 5Q0411105KP might not be related to 5Q0411105HS. Even if they increased the ride height, you would have to find matching rear springs so that the car was level. However, the suspension and drivetrain isn't designed for a higher ride height than the Scout's ride height. It might be best to measure the current unladen ride height to determine if old springs and shock absorbers (or incorrect springs and shock absorbers) are causing the car to sag. It's unlikely that aftermarket shock absorbers would closely match the Scout's OEM shock absorbers, because the aftermarket is geared to standard ride height cars. If someone has already fitted aftermarket shock absorbers that might cause the car to have a lower ride height. To increase the ride height of a Scout, I would first look at whether the car is riding at it's correct ride height and not sagging, and then look at fitting oversize 215/65R16 tyres on 6Jx16 ET43 rims from the Karoq. Compared to 215/60R16 tyres, 215/65R16 tyres will increase the gearing by 3.2%. Compared to 225/50R17 tyres, 215/65R16 tyres will increase the gearing by 4.4%. Or maybe 225/55R17 on the standard 7Jx17 ET45 rims. 225/55/R17 will raise the gearing by 3.4% compared to 225/50R17. Changing 225/50R17 to 225/55R17 will raise the car by 11.25mm. Changing 225/50R17 to 215/65R16 will raise the car by 14.55mm.
  5. 7zap only goes up to 2016, and the Superb MK3 isn't included. Hence for the Superb MK3 I use "LLLParts Skoda". I haven't had any problems reading part numbers on 7zap, although I use a chromebook. Maybe it doesn't work properly with a mobile?
  6. google "LLLParts Skoda" to find the parts catalogue 5Q0411105GM Front coil spring G01+L07 1 paint mark blue 1 paint mark grey https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000 3Q0511115N Rear coil spring 1JA+0YF https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511005 3Q0413031BF and 3Q0413031BG front shock absorber OEM part numbers are shown against the G01 build code and up to 29.07.2018 build date. https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/4/411/411000 3Q0513049FQ and 3Q0513049FR rear shock absorber OEM part numbers are shown against the 1JA build code. https://www.lllparts.co.uk/catalogs/skoda/CZ/SUP/851/5/511/511005
  7. Octavia MK3 front springs 1 5Q0 411 105 GF coil spring 1 paint mark 1 paint mark blue orange 2 (1) 5Q0 411 105 GG coil spring 1 paint mark 1 paint mark blue red 2 PR-L02 (1) 5Q0 411 105 GH coil spring 1 paint mark 1 paint mark blue violet 2 PR-L03 (1) 5Q0 411 105 GJ coil spring 2 paint marks blue 2 PR-L04 (1) 5Q0 411 105 GK coil spring 1 paint mark 1 paint mark blue green 2 PR-L05 (1) 5Q0 411 105 GL coil spring 1 paint mark 1 paint mark blue brown 2 PR-L06 (1) 5Q0 411 105 GM coil spring 1 paint mark 1 paint mark blue grey 2 PR-L07 (1) 5Q0 411 105 GN coil spring 1 paint mark 1 paint mark green white 2 PR-L08 (1) 5Q0 411 105 GP coil spring 1 paint mark 1 paint mark green yellow 2 PR-L09 (1) 5Q0 411 105 GQ coil spring 1 paint mark 1 paint mark green orange 2 PR-L10 (1) 5Q0 411 105 GS coil spring 1 paint mark 1 paint mark green violet 2 PR-L12 (1) 5Q0 411 105 GT coil spring 1 paint mark 1 paint mark green blue 2 PR-L13 (1) 5Q0 411 105 HA coil spring 2 paint marks green 2 PR-L14 (1) 5Q0 411 105 HB coil spring 1 paint mark 1 paint mark green brown 2 PR-L15 (1) 5Q0 411 105 HC coil spring 1 paint mark 1 paint mark green grey 2 PR-L16 (1) 5Q0 411 105 HD coil spring 1 paint mark 1 paint mark brown white 2 PR-L17 (1) 5Q0 411 105 HE coil spring 1 paint mark 1 paint mark brown yellow 2 PR-L18 (1) 5Q0 411 105 HF coil spring 1 paint mark 1 paint mark brown orange 2 PR-L19 (1) 5Q0 411 105 HG coil spring 1 paint mark 1 paint mark 2 PR-L20 (1) 5Q0 411 105 HJ coil spring 1 paint mark 1 paint mark blue brown 2 PR-L23 (1) 5Q0 411 105 HK coil spring 1 paint mark 1 paint mark brown green 2 PR-L24 (1) 5Q0 411 105 HL coil spring 2 paint marks brown 2 PR-L25 (1) 5Q0 411 105 HM coil spring 1 paint mark 1 paint mark brown grey 2 PR-L26 (1) 5Q0 411 105 HN coil spring 1 paint mark 1 paint mark grey yellow 2 PR-L27 (1) 5Q0 411 105 HP coil spring 1 paint mark 1 paint mark grey orange 2 PR-L28 (1) 5Q0 411 105 HQ coil spring 1 paint mark 1 paint mark grey red 2 PR-L29 (1) 5Q0 411 105 HR coil spring 1 paint mark 1 paint mark grey violet 2 PR-L30 (1) 5Q0 411 105 HS coil spring 1 paint mark 1 paint mark grey blue 2 PR-L31 (1) 5Q0 411 105 HT coil spring 1 paint mark 1 paint mark grey green 2 PR-L32 (1) 5Q0 411 105 KM coil spring 1 paint mark 1 paint mark 1 paint mark white orange green 2 PR-L33 (1) 5Q0 411 105 KN coil spring 1 paint mark 1 paint mark 1 paint mark white orange brown 2 PR-L34 (1) 5Q0 411 105 KP coil spring 1 paint mark 1 paint mark 1 paint mark white orange grey 2 PR-L35 https://skoda.7zap.com/en/cz/octavia/oct/2016-753/4/411-411030/ 5Q0411105HS PR-L31 (1) 5Q0 411 105 HS coil spring 1 paint mark 1 paint mark grey blue 2 PR-L31 Length 326mm, Diameter 152mm, Weight 2.05kg, Wire Diameter 13.00mm 5Q0411105HS looks like a Scout front spring, as it's considerably longer and heavier than many of the other front springs on the Octavia MK3. There don't appear to be any aftermarket springs matching OEM part numbers 5Q0411105KM, 5Q0411105KN and 5Q0411105KP. However, on the chart above you can see that they correspond to build codes L33, L34, and L35, respectively. Your build codes would confirm what type of suspension the car left the factory with. The chart below shows that build code 2UB = Rough-road design, and build code 2UF = Chassis with increased ride height. VW Codes Decoder 2UA = Standard design 2UB = Rough-road design 2UC = Sports version 2UF = Chassis with increased ride height http://igorweb.org/equidec.aspx
  8. The Fabia MK3 uses either 256mm diameter front brake discs or 288mm diameter front brake discs. The Fabia MK3 uses 288mm diameter front brake discs if the engine has at least 105PS. For models with less than 105PS, the Fabia MK3 uses 256mm diameter front brake discs. 14" steel rims will clear the front brake calipers on cars that have 256mm diameter front brake discs. 15" steel rims will clear the front brake calipers on car that have 288mm diameter front brake discs.
  9. My preference is ATE over Brembo discs. The wavy line on the ATE discs look like a better design. If you follow the wavy line on the ATE disc, you will see that there is no break in the line. Surely kinder to the brake pads than the broken Brembo design. Also, ATE is now owned by Continental tyres and for me German brakes over Italian brakes is an easy choice. 288mm ATE front disc https://www.autodoc.co.uk/ate/958238 288mm Brembo front disc https://www.autodoc.co.uk/brembo/1657443
  10. If you know your car's build codes, you can look the parts up on a Skoda parts catalogue such as LLLParts Skoda Skoda parts catalogue https://www.lllparts.co.uk/catalogs/skoda/CZ 5Q0513049HM Rear shock absorber UC7 5Q0513049HM Gas shock absorber rear 2 PR-UC7 VW codes decoder UC7 = Rear shock absorption, chassis with increased ride height http://igorweb.org/equidec.aspx
  11. Fitting bump stops with a height of 105mm instead of the correct 133mm ones seems a bit extreme as that's 28mm more suspension travel. The car's not made to have that much suspension travel. There's a risk of damage to various parts of the car including the shock absorber, wheelarch, etc. You might get lucky and not damage anything, but there's a risk. I would have considered 118mm bump stops from the lowered/sports suspension models (ie. 15mm lower suspension) including the RS models. 118mm bump stop 3C0511359B (2) 3C0 511 359 B stop buffer D - 02.05.2006>> 118MM round 2 https://skoda.7zap.com/en/cz/octavia/oct/2007-419/5/511-511021/#2 https://www.autodoc.co.uk/febi-bilstein/1881025 133mm bump stop 3C0511359 (2) 3C0 511 359 stop buffer D - 03.05.2006>> 133MM 2 https://skoda.7zap.com/en/cz/octavia/oct/2007-419/5/511-511001/ https://www.autodoc.co.uk/topran/7066868
  12. On the Octavia MK3, the 288mm front discs are matched to the smallest 253mm rear discs. 276mm front discs are also matched to these small 253mm rear discs. 312mm front discs are matched to the bigger 272mm rear discs. By changing from 288mm front discs to 312mm, your front and rear disc sizes will be mismatched. 288mm front discs weigh about 7.3kg each, and 312mm front discs weigh about 8.6kg each. So by changing 288mm front discs to 312mm, you are adding about 2.6kg of unsprung weight to the front of the car. Skoda are very careful not to fit brakes that are too big or heavy for the car due to the increase in unsprung weight and increase in fuel consumption. The Skoda Scala 1.5TSI 150PS only uses 276x24mm front brake discs. 276x24mm front discs weigh about 6.5kg each, so are even lighter than the 7.3kg 288x25mm front discs. The Skoda Scala is a lighter car than the Octavia MK3, but the 288x25mm front discs are up to the job on the Octavia MK3 just like the 276x24mm front discs are up to the job on the most powerful versions of the Skoda Scala. Most versions of the Skoda Scala use smaller 256x22mm front discs which only weigh about 5.1kg each.
  13. Above 0 degrees Centigrade, the Vredestein Quatracs work better than the Michelin CrossClimate 2 tyres. For tyre sizes such as 225/45R17 and 225/40R18, the Vredestein Quatrac Pros are still available, which work better in the summer than most all-season tyres. If you're using summer tyres all year round, it will be easy to get caught out in the winter as summer tyres don't have the 3PMSF symbol. In the summer fitting UHP summer tyres may give you 10% more grip. However, come winter it will be easy to lose 50% of your grip with the wrong tyres. This means that you can gain a little in the summer, but lose a lot in the winter. If you use summer tyres in the summer, change to winter or all-season tyres in the winter. In the winter you really do need that 3PMSF symbol, as you never know when it might snow.
  14. The Skoda online parts catalogues only show one pair of front brake calipers for the 288mm discs on the Octavia MK3, whether it's an early 2013 car or a late 2021 car. 2013 Octavia MK3 with 288mm front brake discs Left caliper 8V0615123 Right caliper 8V0615124 1 8V0 615 123 brake caliper housing left 1 (1) 8V0 615 124 brake caliper housing right 1 https://skoda.7zap.com/en/cz/octavia/oct/2013-753/6/615-615020/ 2021 Octavia MK3 with 288mm front brake discs 1 8V0615123 Brake caliper housing left 1 1 8V0615124 Brake caliper housing right 1 https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/805/6/615/615020 TRW may have used different OEM part numbers for the front brake calipers on the 288mm and 312mm discs because that enables TRW to charge more for the 312mm version, even though they appear to be the same. This is due to market forces, where there's a price premium for calipers that fit bigger discs. Put the same calipers (except for the OEM part number) in different boxes, one marked 288mm and one marked 312mm. Then charge about 28% more for the 312mm versions. It makes great business sense for TRW. I haven't noticed ATE doing similar underhand tactics. They put the same OEM part number on their 288mm and 312mm calipers, and charge the same price. The Octavia MK3 1.6 110PS uses the smallest 276mm front discs and 253mm rear discs. Some of the other lower powered models also use these size brakes.
  15. Hub cap 5E0601151 FOD 7 5E0601151 Hub cap 4 PR-1NL - 5E0601151 FOD black/chrome - https://www.lllparts.co.uk/catalogs/skoda/CZ/OCT/585/6/601/601060 According to skoda-parts.com the inner diameter is 50mm and the outer diameter is 55mm. However, other sellers claim the inner diameter is 52mm and the outer diameter is 56mm. Search for them by using the 5E0601151 OEM part number or sometimes the full 5E0601151FOD OEM part number. FOD is the colour code, which is black/chrome. https://www.skoda-parts.com/spare-part/5e0601151fod-wheel-hub-centre-cap-with-a-skoda-logo-19744.html
  16. What OEM part number are the centre caps that you purchased off ebay? If they are genuine, they will have the OEM part number moulded into them on the back. If they don't have the OEM part number on them, maybe they are Chinese fakes? You could purchase a single secondhand one for the metal ring. Secondhand one on ebay 6U0601151L https://www.ebay.co.uk/itm/125296123757?hash=item1d2c3b1f6d:g:QYUAAOSw7gpicr1S Do they look like these? Centre cap with OEM part number 6U0601151L MHB 4 6U0 601 151 L hub cap 1 6U0601151L MHB black/bright chrome 2011.08 - 2006.13 https://eshop.skoda-auto.cz/cs_CZ/nahradni-stred-kola/p/6U0601151L+MHB Skoda 7zap https://skoda.7zap.com/en/cz/octavia/oct/2012-663/6/601-601050/
  17. Octavia MK3 Brakes TRW Front Brake Pads 1ZF 276mm TRW GDB2080 1ZE 288mm TRW GDB1956 1ZA 312mm TRW GDB1956 1ZB 312mm TRW GDB1956 1LG 340mm TRW GDB2114 TRW Rear Brake Pads 1KD 253mm TRW GDB1330 1KS 272mm TRW GDB2042 1KT 272mm TRW GDB2042 1KW 310mm TRW GDB1622 ATE Front Brake Discs 1ZF 276mm ATE 24012402581 1ZE 288mm ATE 24012501451 1ZA 312mm ATE 24012501581 1ZB 312mm ATE 24012501581 1LG 340mm ATE 24013002251 ATE Rear Brake Discs 1KD 253mm ATE 24011004201 1KS 272mm ATE 24011003561 1KW 310mm ATE 24012202191 Skoda Parts Catalogue LLLParts https://www.lllparts.co.uk/catalogs/skoda/CZ
  18. What brakes are fitted depends on the car's build codes. The Octavia MK3 2.0TDI 150PS might have 288mm front brakes and 253mm rear brakes, ie. build codes 1ZE and 1KD. The 288mm and 312mm front brakes use the same brake pads, eg. TRW GDB1956, ATE 13046027852, etc. Front Brakes 1ZF 276mm TRW 1ZE 288mm TRW 1ZA 312mm TRW 1ZB 312mm TRW (Same as 1ZA, except calipers are red) 1LG 340mm TRW (calipers are red) Rear Brakes 1KD 253mm TRW 1KS 272mm TRW 1KT 272mm TRW (Same as 1KS, except calipers are red) 1KW 310mm TRW (calipers are red)
  19. This might be better than the chrome 1/2" drive XZN (spline) bit socket M14 if you want to use a spanner on it. You can use a 24mm spanner on this Hazet 990S-14 Hazet 990S-14 https://www.amazon.co.uk/Hazet-990S-14-Internal-Serration-Screwdriver/dp/B004H4AMGM
  20. dtintecno.de claims a 150PS/320Nm maps to 195PS/430Nm, and a 184PS/380Nm maps to 220PS/450Nm. So the 184PS can remap to about 12.5% more power than a 150PS, but the increase in torque is only about 5%. Again, according to dtintecno.de the 184PS remaps to the same power and torque as the 190PS and 200PS versions of the 2.0TDI.
  21. You may be correct in your assumption of the 1.4TSI having 288mm front discs, and the 1.8T having 312mm front discs, although I would check the build codes or measure them to be sure of what is fitted. Pre-facelift, both the petrol and diesel RS models used 340mm front discs and 272mm solid rear discs. Post-facelift, the diesel RS dropped down to 312mm front discs, and the 245HP petrol RS went up to 310mm ventilated rear brake discs.
  22. What front brakes are fitted depends on the car's build codes. Build code 1ZE is for the 288x25 front brake discs. Build code 1ZA is for the 312mm front brake discs. Although both these are TRW brake systems, the 288mm and 312mm brake systems have different OEM part numbers listed for the front brake calipers. However, the front brake pads are interchangeable between the 288mm and 312mm brake calipers which would suggest the 288mm and 312mm brake calipers are very similar. TRW BHX583E left brake caliper for 288mm brake system TRW BHX585E left brake caliper for 312mm brake system TRW 288x25 front discs 1ZE Left brake caliper 8V0615123 1 8V0 615 123 brake caliper housing left 1 Right brake caliper 8V0615124 (1) 8V0 615 124 brake caliper housing right 1 Left brake carrier 8V0615125 6 8V0 615 125 brake carrier with pad retaining pin left 1 Right brake carrier 8V0615126 (6) 8V0 615 126 brake carrier with pad retaining pin right 1 Brake pads 8V0698151 10 8V0 698 151 1 set: brake pads with wear indicator for disc brake 1 PR-1ZE Brake disc 1K0615301T 12 1K0 615 301 T brake disc (vented) 288X25 5/112 2 https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/615-615020/ TRW 312x25 front discs 1ZA Left brake caliper 8V0615123A 1 8V0 615 123 A brake caliper housing left 1 Right brake caliper 8V0615124A (1) 8V0 615 124 A brake caliper housing right 1 Left brake carrier 8V0615125A 6 8V0 615 125 A brake carrier with pad retaining pin left 1 Right brake carrier 8V0615126A (6) 8V0 615 126 A brake carrier with pad retaining pin right 1 Brake pads 8V0698151B 10 8V0 698 151 B 1 set: brake pads with wear indicator for disc brake 1 PR-1ZA Brake disc 1K0615301AA 12 1K0 615 301 AA brake disc (vented) 312X25 5/112 2 PR-1ZA https://skoda.7zap.com/en/cz/octavia/oct/2016-753/6/615-615025/
  23. One inch is a big increase in ride height. When you order a new Skoda with increased ride height, it's normally about a 15mm increase from the standard ride height. When you order a new Skoda with sports/lowered suspension, it's normally about a 15mm decrease from the standard ride height. Do you need AT (All-Terrain) tyres for going down rough lanes? AT tyres are only readily available in certain sizes, so this could affect which size tyres to fit. If you wanted AT tyres and you have 288mm front brake discs (these are the smallest size on the Superb MK2), 205/70R15 would be a possibility and would raise your ride height by about 15mm. In combination with 15mm increased ride height springs, that's an increase in ride height of about 30mm. camskill list both Bridgestone and Yokohama AT tyres in size 205/70R15 https://www.camskill.co.uk/m53b0s2481p0/Car_Tyres_-_MPV_Tyres_-_People_Carrier_Tyres_-_15_inch_R15_inch_-_205_70_15_205_70R15 Unlike ordinary summer tyres, AT tyres give traction in wet mud. Yokohama AT tyres are also available in size 215/60R16, and that size would also raise the ride height by about 15mm compared to the standard 205/55R16 size. camskill list Yokohama AT tyres in size 215/60R16 https://www.camskill.co.uk/m62b0s111p0/Car_Tyres_-_MPV_Tyres_-_People_Carrier_Tyres_-_16_inch_R16_inch_-_215_60_16_215_60R16
  24. The rim will fit. The tyre won't fit, as the outside diameter of a 205/50R17 or 225/45R17 tyre is too big for the Fabia MK2. If you use a 205/40R17 tyre, the ride will be really hard, and the rim will have little protection from pothole damage. If the seller is selling the wheels with 205/40R17 tyres already fitted, some of the rims might already be buckled from pothole damage. If you fit them to the car and they vibrate, the seller might blame you for buckling them rather than admitting (and refunding you) that they were already buckled. So if you do really want 17" rims, make sure they were previously only used with 205/50R17 or 225/45R17 tyres, as these have much bigger sidewalls and are therefore much more resistant to pothole damage. Octavia RS MK1 7Jx17 ET38 5/100 57.1 alloy rims 16 1U0 601 025 P aluminium rim 7 JX17H2 ET38 4 RS 1U0601025P 7ZS chrome coloured metallic 2012.00 - 2001.06 (16) 1U0 601 025 P aluminium rim 7 JX17H2 ET38 4 RS-WRC 1U0601025P F9E candy white 2008.00 - 2008.03 https://skoda.7zap.com/en/cz/octavia/oct/2003-252/6/601-601050/
  25. Why do you want to raise the ride height? How much do you want to raise the car? Have you checked your current ride height? Sometimes, just fitting new springs/shocks to replace old sagging springs/shocks will raise the ride height back to the factory height. What are the OEM part numbers for the factory fit springs? If you've got the car's build codes, this is easy to find out by reference to a Skoda online parts catalogue such as 7zap. Skoda online parts catalogue https://skoda.7zap.com/en/cz/ Have you considered oversize tyres such as 215/55R16, 205/60R16, 215/60R16, etc.
