Everything posted by DieselMonte
logo recommendation please?
I got stick on ones from wish last year. They looked the part but the 2 back ones have fallen off over time. I checked ebay and honestly it was as cheap to get Oem looking pop in ones brand new.
Fabia 1.2 tdi remap and upgrades !
You won't be able to get much more out of a 1.2tdi. Those tuning boxes can be hit or miss. Some of those are just a load of resistors that trick the engine to dump fuel in to make power. A proper remap is your best bet to not have any issues. Low miles like that the stock clutch probably will hold up to a little bit of power. A vRS intake and modifying your stock airbox can help deliver alot more air to your engine than the stock stuff. I did them for my 1.6 tdi fabia last year. Worked out 25euro for the two bits brand new from skoda and I used some black screws to hold it properly in place. It looks OEM and it does feel a little bit quicker. Your car likely has 256mm brakes and in my experience they're fine as they are. 288mm brakes such as those found on a vRS or a monte carlo provide a bit more stopping power and would be plenty for a 1.2tdi. If you need to do disc and pads anyway this might be a cost effective OEM brake upgrade. For suspension a rarb is a good call. I have a whiteline bwr19z and mine is currently on the stiffest setting. This made my car much grippier and theres not a hint of oversteer (much to my disappointment, From what I was reading I expected it to make my car want to go through corners sideways, no such luck). You could replace the stock springs with diesel monte carlo springs (sports springs). They are a stiffer spring than stock and only lower the car 10-15mm iirc. What headlights does your car have? If you have projectors you might have luck getting monte carlo headlights in a scrapyard (Monte carlos have black headlight insides as standard) Monte Carlos are a facelift only model so you likely wouldnt be able to get them to fit on a pre facelift car. Welcome to the forum by the way. There are many people much more knowledgable than myself on this forum. Plenty of mk2's in the projects section to give you ideas. These are great because they're usually dirt cheap for parts and are easy enough to work on usually. If you want pictures of the vrs intake I can put some up later.
Upright storage of winter wheels?
Whats wrong with just having them one on top of the other, like the wheel tree but just sitting on top of eachother. I've not yet had a problem doing it this way.
Doran Motors Ltd - Magheracloone
Bought my vRS intake for my Monte Carlo from here. Even the people at the parts desk are helpful. The bits I needed were cheapest to get from them and they were brand new bits to boot. I would go to them again for parts. While I've not had my car serviced there nor did get either of my fabias there I have heard nothing but good things about them. The fact that they're only 5 minutes out the road from me is great too.
Diesel Monte's 2001 Skoda Fabia "Project vRSDI"
That is some nice fitment. I'll send you a pm now.
EBC Brakes - March pads giveaway
Painted the front brakes on this car, trying to use up the rest of the VHT before the can goes bad. They came out nice for a relatively quick job. Looking at the pictures i'm thinking of using a touch up pen to fill in the FS-III indent on the brakes. You can see I tried to tint the front fogs on this car too, they came out like ****. I couldnt get the tint to sit proper no matter what I tried. I tried my Monte Carlos 17" wheels on this for kicks. I think they look seriously good. Lastly, the brake warning light was on and I thought it was just the handbrake switch going bad. Turns out the rear drivers side drum is leaking fluid. Looks like the rear brake cylinder has gone bad. As if that wasnt bad enough I cant for the life of me undo the screw on either rear drum, The drill just skips around when I tried to drill it out so no luck there either.
DieselMonte's 2012 Monte Carlo Project. (175hp 6 speed swapped)
Tried the vRS spyders from my mk1 on this. I think they look good but they could do with some more tyre. Ticked over 95,000 miles this evening too.
SDI 1.9, lack of power, high fuel consumption erratic RPMs
Oem raised suspension? Wonder If I could find a set of those for my mk1.
Fabia 64 plate Monte Carlo ride quality
The wheels need refurbed no matter what car they're going on so I think a colour close to the monte carlo wheels on these will look good. These currently have a 195/45 r16 tyre on so if they had a 205/45 r16 put on them it would be almost perfect and I wouldnt need to fiddle with the speedo.
Ehh, maybe putting a bit more tyre would improve things a bit. More tyre is a welcome thing for the roads I'm driving on. I remember being told 'in England they drive on the left of the road, in Ireland we drive on whats left of the road'. Our roads are a joke.
I put on some 16" vRS wheels onto my monte carlo to try them, thought I should put them up here in case you were thinking of changing wheels still. I like them on this car but I'll probably paint them if I plan on running them proper.
Are Mk1 and Mk2 fabia wishbones the same?
Thank you again Wino.
Interesting, Mines a August 2012 registration so probably too new to be able change them over.
D3006494 is the last 8 digits of mine. Its a Facelift so it must be different. Good job I asked first then.
Hello again everyone. I plan on getting new bushes and ball joints for my 2012 Monte Carlo. I'm wondering if the mk1 fabias wishbones are the same as the mk2 as I know much of the common weakpoints are shared between them (i.e console bushes). I only ask as If they are the same part I could use my mk1s wishbones, clean them up and do all the bushes on them, then put those into my mk2 and put the mk2s back onto my mk1 to keep it rolling. I'm hoping that they are the same piece because it would leave it a case of just swapping in the refreshed wishbone, instead of having my Monte Carlo out of commission for a day or two getting it done. Also, I saw some console bushes made by PSB, are they a decent make of bush or should I just get the cupra ones instead? Thanks again.
MPH not showing on digital lcd display
My cars speedo is in mph but the digital display is in kmh. Most older irish spec cars read both kilometres and miles on the speedo, my mk1 fabia is like that.
AMD's 2 litre 304bhp 162mph Fabia Monte Carlo TDi *6 speed conversion*
For a car thats gotta be north of 100k miles making 3 times the power it was ever meant to on a stock gearbox (sans diff) i'd say it did well. I would've thought 5th would've gone first though. I'll miss the updates if you do decide to part ways with it.
I'll check next day I'm out, thank you. I cant imagine the alternators being different in anycase.
Glowplug light flashing
Noted.
My mk1 has a flashing glow plug light stemming from removing the brake light switch fuse so I could left foot brake. Brake lights still work but I can left foot brake, only after the cars been run for 10 minutes or so, for some reason.
The more you know lol.
At this point I could take the front of my car off blindfolded. Might make it easier to do. Looks like a PIG to do otherwise. I noticed when I crashed it that the alternator pulley hit the frame rail and left a dent. That cant be good for the its lifespan.
Bad condendation, already sealed doorcard
Silica packets stuffed down the windscreen vents work well too.
Theres your problem lol. How much is an alternator for one of these? I'll probably need to keep an eye out for one if I plan getting my car roadworthy.
