UndertheRadar
Everything posted by UndertheRadar
  1. As above, It looks like a wash product thats been hit by hot direct sunlight and dried/etched itself to the glass. I had some on the glass on mine when it arrived. I removed it with a foam cutting pad and DA polisher. A polish with a half decent cutting ability should shift it from the glass. You could also try a medium cut wool pad to shift it quicker.
  2. are you sure the water is not leaking through the tail light and running down the sealant to the boot floor?
  3. Looks really well. Hope it brings you many miles of happiness.
  4. The 800 vitesse was a very underrated car. They were a great driving good going thing. I’ve had an FDH coupe sitting in the garage for the last nearly 15 yrs. never take it out but still runs very well.
  5. Wee pic from tonight’s walk
  6. Posted on gumtree up here. Seems it has a few marks from use on the frame and dent on rear rim. still a decent carbon bike after some tlc though.
  7. don't know about 2015, but a mate told me not to hit mine (also silver), as he'd had to sort through 9 shades of the same colour on a 2018 superb.
  8. check and see if the system is holding vacuum pressure.
  9. Needs scanned to see where the communication error is. As suggested above, return it to the way you found it, and ring the dealer you’ve recently bought it from and tell them it just quit.
  10. Its a long shot, but if anything managed to hit a body panel when disconnecting its possible it tripped a module somewhere along the system. If it was more than a trip you'd have found a blown fuse before now.
  11. Have you tried a battery disconnect incase it has tripped a module? (I'm Assuming you don't have a diagnostic).
  12. You'd need to mix it stronger anyway, even with the heated washers. I have them on mine and they're sh............ not awesome!!
  13. It runs in order. 1 then 2 then 3 then 4. The injector numbering should not be confused with the firing order of those injectors though. But if you have a scanner saying injector ? faulty, then *1 is first from left, *2 is second from left, *3 is third from left, *4 is fourth from left.
  14. numbered from timing belt to flywheel. 1 is far left in pic, 4 is beside oil filler cap.
  15. does the noise change when your cornering?
  16. Rattles in doors on both sides of mine were from grill trim just above the door panel. I padded them very lightly. Just enough to stop them rubbing off the door panel. One of my other buzzing noises was coming from the clocks, where it meets the dashboard. Again, padded and refitted. To be honest, this car just seems to like making new noises, like it thinks I’m bored possibly.
  17. That looks more like etching from bird ****. I’d leave it with them to sort, as I’ve seen marks like that before that just won’t come out completely.
  18. Panel wipe the bonnet. Then touch them all in with your colour mix and a toothpick. Should key better and stand up to a power hose when washing.
  19. The dry and shine is fine. I’ve my lot coated with race glaze pro ceramic. So all your doing is topping up a quick spray wax over the coating. Your not getting near the paint. You don’t want anything with any sort of abrasives in it. I use Rupes Uno protect every few months over mine. It’s applied with a white foam finishing pad at speed 1 on the DA. The main reason for this is to help maintain the longevity of the coating and to aid beading and self cleaning properties. some of those so called spray ceramics are a PITA as they streak when applied. The spray and shine is a simple spray on wipe off product that lasts well. Britemax spray and shine is another good product for this sort of use. Buy some very nice, very soft cloths. Spray on and apply with one. Go over with another clean one to wipe off. Then go over the entire car with a third when finished. That’s my procedure anyway. 👍🏻
  20. Yes. Very much so. I’ll be using Autoskins N.I to do mine.
  21. I’m still trying to arrange getting all my chrome wrapped in gloss black on my L&K. Just need the time. Maybe when the school holidays start.
