Everything posted by fraz8888
Superb mk3 Passenger door handle again.
Spoke too soon. Did not work. Handle stays in, but does not pull the lock open. Will try adding more to the stack and then maybe heating and bending. Chap in Scandinavia seems to sell a mod / metal plate which is the same intended effect as the glued and stacked plastic addition but in metal. 50 dollars is a bit steep... https://www.ebay.com/itm/157210800201
Thanks for this. After another pop out, I have copied this. Cut an old credit card up, glued with gorilla glue and refitted. Hopefully that will sort for the foreseeable.
The 280PS Thread
went brembo's with matching pads with my local garage. awesomegti too busy to reply to let me know when they had a next slot in their schedule. prob saved myself some decent wedge in the end
Superb Mk4
Not sure about the present styling packages, seen the 265PS in the l and k, the orangey leather not too bad, would like another sportline if possible for MK4 if they improve the styling and choices a bit more.
Superb Mk4
is this for real? Skoda Superb RS and
The 280PS Thread
brake disc and pad replacement time awesome gti have recommended their own brand of drilled discs by rears 310mm https://www.awesomegti.com/shop-by-car/volkswagen/eos/vagbremtechnic-clubsport-replica-310mm-rear-brake-discs/ fronts 340mm https://www.vagbremtechnic.com/vbt-cross-drilled-340x30mm-front-brake-discs-5529844212d/ pads they are suggesting are EBC yellow stuff... https://www.awesomegti.com/temp/ebc-yellowstuff-front-pads-superb-3v/ https://www.awesomegti.com/ebc/ebc-yellowstuff-rear-pads-superb-3v/ the rears seem to say for 300mm discs though, need to check with them on this. edit: checked the EBC site and the same part number looks to be a match for the 310 on the EBC filters DP42173R and DP42127R has anyone else swapped out discs and pads to something they would recommend? RAC insurance say the above are fine with them as not classed as a modification.
New 19” tyres required, which ones
digging this one out again. Michelin, my independent, blackcircles, others recommended their primacy 4 tyres for my 280 superb. RAC insurance have ok'd them also even though they are the VOL homologated version.
The 280PS Thread
noting here that skoda now saying for petrols inc my 280 that cambelt / timing chain changes not needed to well over 100k miles now. was a bit of a surprise to me. Am still considering a change and perhaps waterpump also, as Skoda then followed up with if a failure does occur, as timing chain / cambelt is a wear and tear part then no warranty cover (i have extended warranty at present)
Timing belt shenanigans
found this thread after talking with my local dealer. 280 2018 4x4 estate Post recent service, the desk staff, ooh your timing chain will be needed next. Fast forward a month or so, with mileage / timing nearer the 50k or 5 years (car is on 33k miles now but at 5 years old). Rang up today and they quoted what is mentioned above re the change. Petrol not needed until well over 100k. Then only timing chain needed, water pump not generally needed Feels like a quite a shift. Asked for prices anyway if I prefer to get done. 575 for timing chain only, nearly 800 with waterpump. if a failure does happen in the meantime, they clarified to say as timing chain is a wear and tear item, then warranty would not cover! Whats the consensus re getting done or not? Esp for 280 petrols?
Fitting a cd player
sorry to say it, have you considered ripping your cd's onto a sd card? very easy with old and newer pc's, laptops etc and then you have all your cd's on the data card to browse and play. I use exact audio copy / EAC https://www.exactaudiocopy.de/
Superb 272 bhp 2018 - which DSG does it use?
mines a 2018 280 and 6 spd if defo a 272 then should be 7 speed
dealer was very helpful and adjusted / fixed for free. will see how long it lasts...
thanks, looks like this video to me from your description https://www.youtube.com/watch?v=mDYTALYbUtc
ouch did you have to remove the door card to access the handle from the inside I assume?
The 280PS Thread
will the 280 be discontinued at some point? thinking ahead and possible change in the future, i.e. get an order in for one in good time
this happened whilst on hols, wont go back in, thankfully the door and lock still works, just have to reach over to let the wife into the car car booked into dealer next week to see if they can fix / hopefully under warranty
Door handle stiff
looks to be the same issue as mentioned in the thread below?
thanks for posting this, looks like i have this issue, my passenger handle is stuck and wont open. Hoping I can put it in under warranty, if not then I will be looking at this fix.
THE Winter Tyres Thread
took my winters off today - a little later than planned
Tyre Inflators
i have that one / model. fits fine in front, and back cigar power sources gets a little warm when worked hard (i have just put summer tyres back on and inflated from 2.1 bar to 2.9) but no probs. had it over a year.
The 280PS Thread
hope you find a good turbo supplier. I have used turbo technics a long time ago for an audi A4 turbo, swapped myself, but would not have the time anymore to do such work. good luck
The 280PS Thread
sorry to hear that - how many miles does yours have? out of warranty? hope not too painful in the wallet for you
Winter wheels for Skoda Superb mkIII 4x4 sportline
https://www.briskoda.net/forums/forum/174-skoda-superb-guides/
roofbar & roofbox recommendations - kombi
