Everything posted by Former
Longevity of front dampers(?)
6 years and 40,000 miles and both front dampers were leaking - I was expecting a longer life from them. I know we don't have the best roads but the car isn't ever anywhere near heavily loaded and not used for Rallying. Is this about an average lifespan or was 2015 a poor year for front dampers?
Škoda Fabia III 2016 some kind of bars near the sunglass compartment
I've had a quick look but can't find anything, my (only) guess is sensors.
No Ignition
There are probably computer connections between ignition switch and lights interior lights. Car battery (and it's connections as AG Falco has put) are always at the front of my mind, along with the computer programs. Otherwise if it's not the car or key batteries or interference from anything near to the garage (adjoining garage, neighbours shed with 5G mast) then it might be a system fault not registering.
No Ignition
The interior light not coming on is a bit strange, are you sure it's not just that the interior light is turned off? For no ignition is this that neither key is recognised, if so do you get any error message (see below)? If the batteries in both keys are fine then it may be interference (strong electromagnetic field) caused by something in the car, or you have brought with you to the car, or in the garage. If you have decorative items around the key(s) or starter button try removing these just in case they are preventing the key being recognised.
Is having gearbox opened and condition assessed financially worth it?
CReese123, as you seem very open to questions and ideas. - Do others that drive the car find the same problem? Have you driven other 5-speed Fabias to compare? Here's an old one, footwell mats, not too many or too thick or loose so it folds over and restrict full clutch pedal push. On my wife's 2015 5-speed Fabia I find 1st (and reverse) a bit notchy and it feels like the 'cogs' are against each other rather than meshing - but some of that could be me, the driver's technique, you might be better than me. For 1st best to have the car stopped ,or near enough, and not have the engine revs too high, say at first running the engine or having a heavy right foot resting on accelerator pedal. I changed the gearbox oil on my wife's car and it helped with the feel of gear shifting but it still feels a little notchy but not that bad and is soon gotten used to. Driving my neighbour's car yesterday (28k-miles at 15 years old) the gear shift felt like putting the lever into slots and unconnected but not in a bad way and eased with use, an entirely different fell to our two cars. When my wife drove the cars as the pedals were vey direct and quick acting at first she was slightly dragging the clutch and not lifting off the accelerator enough and quick enough. As she's using that car today I bet she notices how different the Fabia is tomorrow.
Spare wheel / jack - polystyrene tray?
I guess K is for the kit, this is what I get (other than sites with distracting adverts). - https://www.hifygasx.com/index.php?main_page=product_info&products_id=35171
steering wheel grinding
Stop, you'll get me going on rolling circumference. 😊 Having had a few issues with tyre places over the decades always best to check, on a previous rear wheel drive Skoda I had a tyre place put a front wheel on the rear and vice-versa when the pressures where quite different front to rear, not good for straight braking.
Never trust garage (and tyre places?) or petrol station tyre pressure gauges for accuracy they can often be well out. I literally came in half-an-hour ago from resetting our eight tyres (no spare wheels) as they were 'cold' and all needed a bit adding as they were last done when the weather was warmer. I use the same pocket tyre pressure gauge all the time so that any very small discrepancies remain within the same (very tight) range. The Fabia having the fashion for larger wheels with lower profile wider tyres and higher pressures sometimes needs minor tyre pressure adding because of all the potholes, my car with 13" wheels and 155/80r13 (79 T) tyres at 24 and 26psi rarely vary in their pressure (nor did the previous 145/80r13 ,75 T).
Driving for a while on the new rack as it is is a good idea but not so with guessing numbers from codes, there's thread on here about codes have a look at that and research elsewhere but don't guess, steering not a system you want to guess with. If you've not already done so, I think it's also a good time to check all four/five tyre pressures with the change of weather. ETA: First edit wasn't to copy mfgf but to add explanation, seems we agree on tyres but not steering adjustment. 😄
Steering wheel airbag noise
Grd3105, see the first link and video for general clockspring info and the second video for Fabia specific (about halfway through for clockspring, I'm not sure why he had trouble with the steering lock, I never, but I'm not technical 😄). Youcanic - closckspring general, see text and video - https://www.youcanic.com/article/airbag-clock-spring Fabia (wiper stalk fix) video - https://youtu.be/w4CWH5p5VWM As you're going to disconnect the battery you might as well give it a long, slow and low recharge, you know it makes sense. 😁
Genuine laugh for your comment from me, I like witty. 😄 I was going on the limited info given by the first post and throwing up my usual first (and contentious) idea it usually encourages others in, and often the more technical, throw enough mud (opening there) and some will stick. Checking the battery state, connections and charge is always a good idea on cars particularly these modern cars, I'm not technical but I do have 42 years of experience of owning and using cars and the car battery (and charging system) is a very neglected important item on vehicles hence the very high level of breakdown recovery call-outs for battery/charging problems and rarely for faulty components rather use neglect or not understanding. The car can start fine and headlights seem bright enough and the battery still be low enough during the heavy use that many modern cars and driver's give it that it's low enough to get the car's computers and programming to start playing up in all sorts of ways. I've been told many times that a battery was "good" went it wasn't and getting it good has sorted the problem or at least helped. This problem now looks a lot less likely (than even before) to be a problem with the battery but a battery in a good condition and sate of charge will help confirm rectification whereas the reverse could actually hinder or delay progress.
(ETA: KenONeill posted whilst I was still typing, happens a lot to me as I'm a slow thinker and typist.) Basil, are you sure the spare wheel is correct to your particular vehicle, what size is it, what markings on it and what make model and size is the tyre? I wouldn't know if its correct but others might.
MOT advisories (high level brake light, park brake) advice sought
MOT inspection manual: cars and passenger vehicles 4. Lamps, reflectors and electrical equipment 4.3 Stop Lamps 4.3.3. Compliance with requirements - https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-3-3
Fabia mk iii - Can anyone point me to fault code list please?
Sorted, great. Who knows with computer programs, perhaps it's done a good job of warning you and you'll notice after the turbo actuator has been replaced, under warranty so a good thing to know about. Let us know if you notice the difference, give it the Italian tune-up (once car is fully warmed of course).
- Air Filter change
Air Filter change
Not a car I really remember. A mate had some SRi as company rep mobiles but I don't remember any being a 309, but I can't remember what numbers they might have been as he changed jobs and/or cars quite often. He had a couple of Cavalier SRi IIRC one leaded petrol that went like a rocket (compared to the cars I was used to) and the next was a Friday afternoon (unleaded) that highlighted how quick the previous one was - but it did have an 'i' on the boot (badge). 🙄
No Ignition
Battery seconded. I don't know KESSY key so might be wrongly assuming the with the following. Also don't have a secondary key, alternate the use of both keys. I'd also resynchronise both keys (see details in Driver's Handbook) after the battery is fully (long, low and slowly) recharged or if not that issue sorted.
Obviously it might not be - and I am not technical or mechanical, I just know how much the state of the battery is forgotten about and how important it is to the car and even more so with newer cars. If you can't charge it enough in one session then do more sessions, leaving the battery on the car to charge means some (a lot sometimes) of the recharging is lost because of all the systems on the car still working even when the car is parked up. Battery or charging issues as still one of the main reasons for Breakdown Recovery call-outs despite car batteries and charging systems being much better now, it's mostly (just about all?) down to the car users not knowing or neglect. Batteries are also one of the most oversold car parts, often they can be recovered but it can need long, slow and low charging whereas everyone wants instant solutions or at least very quick so don't have the patience or understanding. Good luck.
I would 100% fully charge the battery up, even if it was after anything else. Personally I'd remove the battery from the car and put it on a long slow low charge (not fast high) at least overnight, much longer if possible to fully charge the battery which will help the car in many ways. Also disconnecting the battery for many hours might give enough time for things to discharge (that's the wrong word but I can't think of the correct one) and reset themselves. After reconnecting the battery I's also synchronise both keyfobs (details in the Driver's Handbook). On my wife's 2015 car the only thing that needed resetting was the time of day - but I don't know with your car you'd need to check to be sure. Shorter days, longer nights, colder wetter weather in future weeks and months - you want to have your battery in good condition and state of charge not to join all those that need the Recovery at this coming time of year because they've not taken care of their car's battery, plus as I put a lthe computer programs are very fussy about battery level and will play up in all sorts of ways not always obvious as to why.
- Air Filter change
1.0TSI Monte Carlo Modifications
Slik, hi, welcome. Two bits of hopefully help, first you'll like second you probably won't. You'd probably find this thread useful for info you want, and to post on. - If the car is new to you don't want to spend any money on it making changes until you know for sure you don't need to the the money for other stuff and time for you to fully discover the car to see what you want to change and the priority - or after a while you might find you change your mind as to what you want or you think required. Best tuning is to carry out full servicing, maintenance and repairs and not just to the minimum service tickbox requirements. No good trying to get more out of the whole car, let alone the engine until you have a good point to start from. If there are any areas of the car that aren't good for whatever reasons then you can't put them under more strain until they are made good (not reasonable, good). Don't take offence (or a gate) but best tuning for any car after what's above is driver training, and you can swap that to another car with ease and without cost. Wheel size in itself doesn't give better handling and performance, (too) bigger wheels with (too) lower profile tyres generally can give a very crashy ride and give more damage to the tyres, wheels and car as our roads aren't racetrack smooth. Tyres, which effect the braking, steering, road holding, handling, ride comfort and noise, are very important, their lower profile and wider width can be bettered by a different tyre composition and compounds (of a smaller size), too wider wheels and tyres can be detrimental rather than an improvement and different size and widths of wheels and tyres can have pros and cons in different driving, roads, weather and environments. Don't just follow the crowd do research for what applies to you and your car. Good luck.
- Air Filter change
Which air bag light come on, where is it? There's a "clock" mechanism to the bag and all sorts of stuff to the steering wheel (depending on which you have) the bag has a detonator that as you can imagine either detonators or doesn't. Anything to do with the airbags wants sorting ASAP, a scantool and/or dealers. You need someone technical for this query, which ain't me.
Was you turning the steering wheel when the noise started and light came on? Are you sure the noise was from the airbag and airbag light? My first thoughts always with these modern cars is that the car battery is in good condition and battery in a good state of charge (and that's not just the car starts and the headlights seem bright), also that the terminal post clamps are secure and tight. The car battery being low has a big effect on the cars computers throwing wobbles. I doubt the battery is the cause of this but with computer programs who knows, has the steering wheel been taken off before (I had to to repair a fault on the wiper stalk)?
Oil viscosity
Simon, simple answer - CASTROL MAGNATEC STOP-START 5W-30 A3/B4. - https://www.castrol.com/en_gb/united-kingdom/home/car-engine-oil-and-fluids/engine-oils/engine-oil-brands/castrol-magnatec-brand/castrol-magnatec-stop-start.html But there are loads of alternatives if you can't get that for any reason. WHY do you need oil? My wife's car is 6 years old only does mainly very short journeys but it doesn't need oil adding between annual services.
