Everything posted by nta16
Skoda Felica magnetic oil drain plug
Just the usual difficulty of pinning down exact and correct part numbers and the confusing information and misinformation in conflicting suppliers databases including very probably VW's. This is why I always put you have check, double check, and cross reference any information you get from any source with other (hopefully) reliable sources and, if you can, compare new part(s) to old and how well or not the new part(s) might fit but also bearing mind the part already fitted may not be correct, or fully correct, even if it is, or appears to be, working. Very annoying but not the end of the world, at least the wrong part didn't leave your car out of action and was soon sorted. I note that your link has it as "Gearbox screw plug, oil pans." - my table show M22 needs a 32mm spanner / socket which seems large for a engine oil sump plug, did the oil change guy use a 32mm socket on your existing engine drain plug or can you try a 32mm socket on the existing engine drain plug yourself or measure the head of the plug in anyway to confirm.
Best Windscreen Wipers for Fabia
The ones I ordered and got for my wife's Mk3 are Aerotwin for front and Bosch non-aerotwin at rear, been on 9 months now and still fine AFAIK. I don't know what the VWŠkoda rear wiper blade make actually is but it was a slightly better fit to arm than the Bosch non-aerotwin but nothing to worry about and IIRC the Bosch non-aerotwin is a better fit than the Halford's own rear blade.
Felicia pick up running hot 🔥
Be sure to follow the instructions on the coolant flush if it is a cleaner, after flushing it out I find another back-flush (with water) and then flush and drain gets more crud out that just a flush drain but most don't bother to go that far stopping at the first flush drain. On old cars I also remove and clean and do the flushing and back flushing at engine block (drain plug aperture) radiator and heater matrix separately as a first clean of a system that is new to me. All so much easier with a vacuum pump rather than tap water pressure, gravity and lungs power. On an old simple car I once connected up the two heater matrix hoses the wrong way round by mistake but it still gave lots of heat.
£299 2 year Service Plan
The oil is dependant on its use, or lack of usual expected range of usual use. The fixed terms are just guesses the oil may be best or needing change before or after those fixed terms, it depends on the actual oil used and the use it's put to. The VWŠkoda oil "service" measure is trying to calculate use for when to change the oil. Then there are different types and grades of synthetic oil but that's another matter. Synthetic oil isn't that expensive, we in UK like to pay more for car stuff that's partly why VW doesn't mind going to all the effort of making RHD cars to sell over here plus all the profit on their spare parts and oils for those that buy their VW labelled oils and other fluids. I'm more aware of oils like 1980s Castrol GTX than many here as until a few years ago my one and only everyday use car for the previous 16 years was a 1973 MG Midget (the Mk3 is my wife's car) and having various other old over-priced and over-valued old cars called "classics" as everyday cars (used all year round) including three other MGs over the decades I got to know the MG Owners Club spare parts well and they have the franchise for Castrol Classic Oils (including now GTX). And having many old farts in the "classic" car world I had to justify when I used and suggested Mobil 1 and other synthetic oils, instead of traditional "mineral" oils (with loads of ZZDP), in my "classics" and that others could do the same, decades back. Up to you but if you want to this professional expert might help you understand (I am NOT an expert in oil or anything else). First a video from him you will like then another you probably won't agree with. (2026 VW 😄) - 'The Accuracy of OIL LIFE Indicators REVEALED!' - https://www.youtube.com/watch?v=t4e0oDBseqo (2,000 miles in first year) (and I am a BIG Fan of Owner's Manuals) - 'The FACTS About Oil Changes (What The Owner's Manual DIDN'T Tell You)' - https://www.youtube.com/watch?v=QDxn3mRTOfg
2013 rapid with 4 electric windows, but only 2 buttons in drivers door, can i upgrade?
In that case it might be that other stuff wasn't fitted to enable four-button control at the driver's door or it is there but needs scan tool 'coding' to operate with four-button switch, but again I don't know, but the source I gave you probably will be able to get that build information given your VIN. Good luck.
That is not what I put, in fact I put they're usually reasonably accurate but VW parameters aren't always the best for the car owner particularly if you want to keep the car longer term. You seem to be saying, the representatives at least, in 2026 of that multi billion dollar, decades old, car giant wrote a sentence that doesn't actually make sense, perhaps they used AI. 😁 It's your car, your choice if you want to wait over 18 months / 18k-miles before "Inspection" and a bit under 18 months / 18k-miles / 16k-miles before having the "Oil change" then that is up to you. I agree with you that the paragraph you have quoted implies the car dictates the requirement but there might be a further explanation not quoted and/or in the small print of the agreement. I still wish you luck, it's each to their own for their choices, let us know how you get on with the service plan.
Passenger A-Pillar rattle
I had a really annoying rattle (aren't they all) on a car and I spent ages and trying lots of things (old car so I found a few fixing I could nip up, in the end it was one of the things I thought I had already checked at the very beginning, but obviously hadn't. In this case it was bonnet brackets bolts but the rattle seemed to move or be at different places for the three of us that heard it. Rattles like leaks can be difficult to pin down exactly sometimes. Good luck, let us know how you get on.
Weber & Exhaust Manifold
Other than a FoMoCo I've never had Weber (not that I know much about carbs and then only SU) see if one of the chaps below is able and willing to identify it (these guys tend to be at shows I think). https://weber-carbs.co.uk/ https://classiccarbs.co.uk/ https://www.webcon.co.uk/ I have dealt with Eurocarb once and they seemed fine. - (Eurocarb) - https://www.dellorto.co.uk/ HTH.
Are you sure the two-buttons switch is correct and original for your car (I don't know, just seems very odd) - and are you sure it is the buttons that are making it hard to wind the window up? Best always to have the engine running when using electric motors (in case your battery is in a lower state of charge or health). Have you tried cleaning (and lubricating) the window channels as that can help at least easy things a bit. If the motor(s) are tired or it's other issues have a look and ask here, free advice willingly given. - https://www.briskoda.net/forums/topic/497084-window-motor-repair-service/page/8/#comments Good luck.
Does it? Based on what- if it has one of the oil life readouts then they can be fairly good but if it's just a countdown calendar of days to next schedule possibly not so good or good at all, depends on your driving and car use. Lots of short journeys doesn't allow the engine oil to heat up enough. Use your engine oil temperature rather than coolant gauge to see when the engine is warm, 90+c on the oil not coolant. Always check, double check and cross reference any information you get from any source but much more so with A (so-called, it's not) I, what sensors are there on the car that actually measure engine oil quality - none. - https://www.valvolineglobal.com/en-eur/oil-life-monitors-are-they-really-accurate/ They are A but the language systems are definitely not I - like "smart" devices, they're just the usual very dumb computers and programing. That is not a good thing for many bits on the car including the engine, have the engine serviced annually if you intend to keep the car longer term. Unless you send the oil for for analysist Although VWŠkoda don't seem to fully appreciate it with their sales and marketing service and "maintenance" schedules there is more to whole car servicing than just an engine oil and filter change and a look to find chargeable work that may or may not actually need doing. Get the car "serviced" hopefully they will do the ticksheet checks too, more than 12 months is too long to leave a car without it being looked at, just because it's new doesn't mean there can't be issue(s) that should at least be noted if not attended to. Ask the Dealership to set the car for annual "services" (fixed) instead of flexible unless you do ten times your current annual milage. (year ago I worked out it was less expensive to have taxi/bus rides than a new car for less than 3,000 miles a year) As the driver you want to keep on top of the driver's maintenance too don't leave things for once a year (or more) (possibly) checks. Good luck.
Looking for a 17" Steel Rim
I got some brand new wheels and tyres set from a specialist marque supplier, I fitted them after changing front brake pads, I had just pulled away on a test run when I heard scraping from the front, so I stopped worrying about the brakes. It was the new wheels, the stick-on balancing wheel weights had been placed on all four wheels where the trackrod ends fixing caught them. Wheels from a marque specialist, how I wished I had remembered to spin the new wheels before lowing the car to the ground. One quick run round the block and the weights were sufficiently grooved, I had the wheels rebalanced with weights further inboard.
Bosch are alright, I couldn't get the specific ones so general size but they're fine. I think, but might be wrong there were/are counterfeits about on the old internet so buy from a reliable source. Don't forget you have to put the wiper arms in the annoying "service" position to fit the blades comfortably (instructions on how to set to annoying "service" position are in the car's 'Owner's Manual'.
You can get a pictorial idea from the following website but only certain way is to offer the wheel up or fit it, unless someone has the same car as you with same suspension (steering), same setup and sitting position, and same brakes. - https://www.willtheyfit.com/
Backup battery trouble code B1916F4
Good news - what fixed it in the end, so that others will know the solution.
Other than removing the plastic A-pillar trim, always risky great 'fun' and checking it for damage and fit or something loose behind it, then no from me. That is of course if that is the actual location source of the rattle, sitting as a passenger with some sort of DIY stethoscope or just go by delicate touch with fingers. Rattles are always great 'fun' to locate and solve. Good luck, let us know how you get on.
- hello
Has your car had a VW update type of glitch by any chance. By those readings isn't that it, it's done. Have you driven the car since whatever you have done to let the very dumb computer systems know and confirm things are OK and no need to panic. If the doom light has remained on or remains on after driving the car perhaps through a few stop/start and/or ignition on/off cycle over a reasonable distance drive then your best bet might be to have a look at the OBDElevern forum for what other OBDEleven user found and done. Of course you will need the correct OBDEleven hardware and software systems and may want to do a full back-up before pressing any buttons. Good luck, let us know how you get on.
If they are manufactured correctly with correct reasonable quality materials then I am sure they are good but this is modern times, were these genuine OE parts, would storage aging have effected them at all. Personally if not OE and/or rubber inner part then I would bin them personally or recycle or use them on something that doesn't matter or as a spacer washer perhaps - just not on your engine as you would be very unhappy IF they leaked. Someone else might be less critical about them if so they can have them. €1.50 - that's what happens when something like this is packaged and sold individually, be interesting to see how much a box of 1,000 would cost.
@MikeTheThinker do just check that the information on that website is correct by cross reference or simply physically measuring the actual wheel you have as all databases have errors and omissions, and you and I aren't the only ones to mistype / incorrect data entry. Great of you to make the offer and great for Gammyleg if it comes off.
@DerekU thanks for finding that. Location in Scala - https://www.briskoda.net/forums/topic/533271-backup-battery-service-life-critical/#findComment-5952186 - [ETA: I was still typing and checking hyperlinks work when you posted] @peter77 See this for solution (yet another 12v battery charging need) - [ETA: if AI isn't correct on this one unique occasion of course] "The solution, according to the workshop manual and today's words from a technician at a Škoda car service, is this: With the ignition on, let the vehicle battery charge for two hours." - https://www.briskoda.net/forums/topic/533271-backup-battery-service-life-critical/#findComment-5952375 HTH.
IIRC they look like ones possibly used on Fords, personallly I would throw them away, unless the middle bit is plastic and then I might use them on something not to important but not for engine sump plug use.
(Very) short errands with a Kamiq 1.0TSi 116?
I was looking at proper (forget the correct or marketing term) hybrid and "mild" (different ideas of what that might be) for my wife and all her short journeys and came to the same conclusion as Evolution13 that they're not best suited at all. 6k-milkes a year is low but not that low, or as I've put nowhere near as low as I see from neighbour's and looking at some new-ish replacement cars I've seen advertised, more like 1k-3k-miles a year, or less. It's the odd very occasional long journeys that would make electric only costings more difficult to pin down, at home or near(er) home should be easier to know and calculate. Servicing an electric car electric engine is something to look forward to compared to the messy, costly, farting about servicing an ICE engine which isn't.
You can do a smoke test to see if the fan is sending the air in the correct direction (good point about fan guide/cowl being present and fitted correctly. I was once sent a wrong eclectic fan motor (with blades) and fitted it after checking it worked but forgot to check in which direction, as it was part of a kit the manufacturer supplier took a lot of convincing they had sent the wrong fan in an otherwise correct kit and I practically had to stand on my head to read an upside down label through the recessed rad grille to give them the model number. They apologised and sent the replacement to arrive next day but the fan kit installation was little involved so I wasn't best pleased to have to do it twice. It did teach me to fully check items delivered next time (after this) and there was a next time but the fan was correct. Sod's Law always apply check and it will be correct forget to check and it will be wrong.
I agree but not what I was referring to or meant to imply. Many people take a spare wheel out of the boot and it has never been checked and sitting in there many years so without checking there's no telling what pressure it might be at. Possibly overinflated or more likely under inflated or as the with the 2012 car I helped put the spare wheel on, tyre almost completely flat. Not the first time I've had a spare taken from the boot that is well under inflated or flat - and a spare wheel in a boot but not a jack or wheel brace and certainly not a pump or accurate pressure gauge, that's how things are. I've no idea how old Gammyleg's wheel and tyre are or what pressure it might be at but if it wasn't checked then neither does anyone and I wondered if that might be the cause, or the system not reset from other tyre going down. Has Scotland fully adopted the metric systems, by sheer coincidence 20 year ago I had trouble with an electronic tyre pressure gauge lent to me as it was being used by the owner on his "classic" MBG and I expected it to be set to psi and not Bar as he had it, with the gauge details of bar on it too small for me to notice as the Scottish wet "sun rays" covered me and the gauge. Just damp enough to potentially make the road surfaces greasy. The type of cars I used to drive made things like tyres being correct even more important and they lacked all these bottom-wiping electronic driver aids and assists on modern cars so even more importance on the driver actually doing driver checks and maintenance, so I do have some experience. My last car, three years ago, for the previous 16 years, used as an everyday car through all seasons, was a 1973 MG Midget which was a basic and old design in 1973 let alone 2023 but I also drove/drive my wife's, friends and neighbours' modern cars so not entirely out of touch with today's cars.
If you have a new washer available why wouldn't you use it. Perhaps if you have one of the old copper washers you might just turn it over but that's a bit of a risk too. Or anneal it but that's a lot of effort and would only be used if that was the only washer you had. Crush washers, copper or whatever, are only designed for one use so should be replaced each time. What lazy, sloppy, untrustworthy paid workers in the motor trade do is one thing but if you are doing the work yourself you want to do the work once and not have the possibility of leaks so why take chances, the washers used to be very inexpensive now of course is a different matter but buying them in packs of x-number can work out a lot less expensive.
