East_Yorkshire_Retrofits
Sponsor
Everything posted by East_Yorkshire_Retrofits
  1. Skoda won't be able to help you You'll need the necessary software activations and an ADAS calibration. We can assist with both, or carry out the jobs in full The activation code's feature up to 8 features. So the same one could be used for the features on the camera and the radar, with some spare. I'm sure your insurance company would be overjoyed to find that in the case of an accident, nice easy way to wriggle out of paying out MQBEVO FECS.pdf
  2. If you send us a message with your reg or VIN, we can take a look for you!
  3. It’s possible you’ll need replacement door control modules, not all of them support power folding mirrors The wiring you’ll need will come with the replacement mirrors, and plugs into the door control modules
  4. They never install unused wiring, they must have done the maths and found it to be more cost effective to have X amount of different harnesses with varying options 🙂
  5. It doesn’t need to be “mapped out” We can add the option to switch between ACC and standard cruise control for you. That way nothing is lost, and the option is always there
  6. Yes it can be done No, it won’t be cheap Thankfully MXB isn’t SWaP
  7. https://eastyorkshireretrofits.co.uk/products/octavia-iv-reversing-camera?_pos=1&_sid=67efd7eb2&_ss=r
  8. Unfortunately it looks like moisture has gotten behind the lens
  9. What year is your car? If it's an early one, it'll have an absolute tonne of updates outstanding, one of which will fix (or atleast massively improve) this issue
  10. We’re in Bridlington 🙂 The codes will still be there until cleared, they’re stored for future diagnostic purposes. However as you’ll have noticed, they won’t affect anything
  11. If you’re in the UK, we can install this properly for you 🙂
  12. Even if it was, a good independent would update the digital history We always do 🤓
  13. You can find 0870 here https://eastyorkshireretrofits.co.uk/products/mib3-software-updates-seat
  14. We can permanently fix this for you, and prevent any additional adblue issues. However I’d try get it dealt with via a warranty claim first We’d also be happy to investigate the other issues you’re having
  15. Your car 100% has a battery management system. The configuration for it is within the adaptations in the diagnostic gateway It needs to know the battery type, capacity and a serial number
  16. Does it seem to sit really high & feel really crashy? If so, it’s worth checking they haven’t left the transport blocks in place
  17. If your car has a rear washer, and you've got a wash button on screen; the camera is incorrectly coded. The camera will be washed with the rear wiper so there's 0 need for the button. The button is for cars without a rear washer. If your car doesn't have a rear wiper, then the above part isn't going to work for you as you'll need to run a hose to the washer bottle. We have them in stock, we can make them to any length. Do you know what length you need?
  18. The vehicles above were type approved for towing, so there weren’t any paperwork changes necessary I believe there are a couple of companies who can help you though
  19. 2024 Skoda Kodiaq VRS We activated adaptive cruise control, and adaptive lane guidance New genuine parts used for a factory finish ✔️
  20. For those who don’t mind manually removing the towball, here’s the manually removable variant. The 13 pin socket rotates up behind the bumper. The tow ball can be locked in place.
  21. The infotainment information is a drop in the ocean really. There's 20+ other control modules on the vehicle Again, There's 20+ other control modules on the vehicle. They all have their own software
  22. ACC is a licensed feature. We charge £1200 inc. VAT for an activation code for up to 8 features. You'd then require replacement stalks, trim and software changes MQBEVO FECS.pdf
  23. The parking sensor control module is located in the drivers footwell next to the accelerator pedal as mentioned above We’d be happy to take a look at this for you
  24. It will take you hours to manually code it with VCDS There are 6 adaptation channels for each colour, so 180 in total. That’s assuming your BCM supports 30 colours, it may need a software update first
  25. It could be thousands of things. If you’re lucky, it’ll just be a software bug that’s easily fixed. You'll need to perform a diagnostic scan
