Everything posted by igrozan
Help needed to change car skin
No problem... https://www.drive2.ru/l/587595782509559952/
Everything can be done/changed. But honestly, I don't remember all the details... I can send you a link to the instructions, but they're in Russian. The image was adjusted to match the car's appearance.
Superb no f*&%ks given
I did the same thing
How to: Retrofit Virtual Cockpit
Before 2019 AID is 3VD920790, without a letter. After 2019 comes 3VD920790A! It is very important. There will be a different immobilizer. This is what I bought, a 2018 model year car
- VCDS options on Superb III
Unfortunately, I have no information on the F block. If this parameter does not have an effect, then I cannot help. For block 5Q4959593E Software version 0032 Odis: (Vcds will be similar) Block 09: Adaptation: Code: 31347 [LO]_Signalisierung_Spiegelanklappung - [VN]_not_active OBD11: On-board network control unit 09 → Secure access (Login: 31347) → Coding: Access control - Signalisierung_Spiegelanklappung: Activate I haven’t tried it via OBD11!!!- VCDS options on Superb III
I activated it on these blocks, but haven’t tried it on others. 5Q4959593E Sup 2017, 5Q0959593E Tiguan 2018, 5Q0959592K Tiguan 2020- VCDS options on Superb III
Yes, yes, I understand, if you are not afraid to cut the door trim with a knife and you understand at least a little about auto electrics, I can give you all the links to spare parts.- VCDS options on Superb III
What version do you have for 42 blocks?- VCDS options on Superb III
I bought flashlights, connectors, pins on Ali. I did the wiring. To install, you need to remove the door card and, worst of all, make a hole for the light. At the same time, cut into the ambiline wiring and code it. Nothing complicated😁 If there are blocks in the rear doors, then you can easily illuminate the passenger exit area.- VCDS options on Superb III
On all S3 mirrors open after the alarm is removed, they can easily be changed to open after ignition.- VCDS options on Superb III
Can be enabled only if there is a 360-degree camera view- VCDS options on Superb III
If this is about the trunk lid, I made my own 2018 model- VCDS options on Superb III
got it from here https://vi.aliexpress.com/item/1005005345672636.html?spm=a2g0o.order_list.order_list_main.51.2cab1802TWBNo7&gatewayAdapt=glo2vnm + connectors, wires and pins- VCDS options on Superb III
This means that the auto closing did not activate! When washing, when the key is nearby, the water activates the sensor on the door handle.- VCDS options on Superb III
I studied this question for a long time, but never found an answer. I know for sure that the Skoda Enyaq has this from the factory. We need to get a scan of block 9.- VCDS options on Superb III.FL
https://github.com/olli991/mib-std2-pq-zr-toolbox Here you can find out whether it is suitable for MIB or not- VCDS options on Superb III.FL
Yes, that's right. This only works on MIB 2.5.- VCDS options on Superb III.FL
The main thing in MIB was navigation. Then the toolbox is installed. The patch is stitched and the swap is transferred. Everything is working.- VCDS options on Superb III.FL
- S3 owners - electric tailgate / hatch closing from inside
